    MMM-Fuel
    8 Posts 3 Posters 1.9k Views 3 Watching
      Redicaljk
      I have seen a number of posts stating that this module no longer works. Can someone confirm this?
      I have set up the module but no data is showing so I assume it’s not able to pull data from gasbuddy.
        p1lspeda
        I’m have similar problems using MMM-Fuel and tankerkönig.
        My API Key (tankerkönig) runs fine on my OpenHAB installation but MMM-Fuel replies with
        [2026-07-14 16:36:19.744] [ERROR] [MMM-Fuel] MMM-Fuel: Failed to retrieve prices FetchError: Invalid response body while trying to fetch https://creativecommons.tankerkoenig.de/json/list.php?lat=49.994944&lng=8.278279&rad=5&type=all&apikey=[I-wont-give-you-my-apikey]&sort=dist: Premature close
            at Gunzip.<anonymous> (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:217:52)
            at Gunzip.emit (node:events:521:24)
            at emitErrorNT (node:internal/streams/destroy:170:8)
            at emitErrorCloseNT (node:internal/streams/destroy:129:3)
            at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
          type: 'system',
          errno: 'ERR_STREAM_PREMATURE_CLOSE',
          code: 'ERR_STREAM_PREMATURE_CLOSE'
        Would love to see a fix
          sdetweil @p1lspeda
          @p1lspeda best to open and issue on the module github page to engage the module author, most don’t visit the forum often
            sdetweil @Redicaljk
            @Redicaljk there is an open issue, on the module repo… looks like Gasbuddy removed the api the module used
              sdetweil @p1lspeda
              @p1lspeda ah, node-fetch… there is an electron bug in the 2.37 version of Electron
              do this
              stop MagicMirror
              npm install electron@43.1.0
              start MagicMirror
              please advise
                p1lspeda @sdetweil
                You are the GOAT.
                Thanks, your hint fixed my issue.
                  sdetweil @p1lspeda
                  @p1lspeda awesome!!
                  second module impacted…
                    sdetweil @p1lspeda
                    I opened issue on the MMM-Fuel repo
                    https://github.com/fewieden/MMM-Fuel/issues/128
