    Upgrade
    27 Posts 6 Posters 7.1k Views 6 Watching
      sdetweil @mumblebaj
      @mumblebaj if you have nvm or n installed (I detect nvm, install n )
      do this
      sudo n
      it might give you a list, then pick the right one 22.21.1
      if not there, then
      sudo n 22.21.1
      to install it
      mumblebajM msimon360M 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        @sdetweil Just ran it quickly and it seems like it installed 22.22.2
        mumble@pi:~ $ sudo n
             copying : node/22.21.1
           installed : v22.21.1 (with npm 10.9.4)
        mumble@pi:~ $ node -v
        v22.21.1
        mumble@pi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        update log will be in /home/mumble/MagicMirror/installers/upgrade.log
        doing test run = false
        Minimum Node version: v22.22.2
        Installed Node version: v22.21.1
        installing correct version of node and npm, please wait
        Minimum Node version: v22.21.1
        Installed Node version: v22.22.2
        No Node.js upgrade necessary.
        Minimum npm version: V10.9.7
        Installed npm version: V10.9.7
        No npm upgrade necessary.
        upgrading from version 2.37.0 to 2.37.0
        force: line 762: pm2: command not found
        some node app still running, please shutdown those apps, maybe MagicMirror, and restart
        here is a list of those processes
        • msimon360M Offline
          msimon360 @sdetweil
          @sdetweil Just and FYI, I just tried a fresh install and got the same issue with node.
          marksimon@digiframe:~ $ git clone https://github.com/MagicMirrorOrg/MagicMirror.git
          Cloning into ‘MagicMirror’…
          remote: Enumerating objects: 31023, done.
          remote: Counting objects: 100% (5/5), done.
          remote: Compressing objects: 100% (3/3), done.
          remote: Total 31023 (delta 2), reused 2 (delta 2), pack-reused 31018 (from 2)
          Receiving objects: 100% (31023/31023), 26.41 MiB | 2.15 MiB/s, done.
          Resolving deltas: 100% (19515/19515), done.
          marksimon@digiframe:~ $ cd MagicMirror/
          marksimon@digiframe:~/MagicMirror $ node --run install-mm
          npm error code EBADENGINE
          npm error engine Unsupported engine
          npm error engine Not compatible with your version of node/npm: eslint-plugin-package-json@1.5.0
          npm error notsup Not compatible with your version of node/npm: eslint-plugin-package-json@1.5.0
          npm error notsup Required: {“node”:“^22.22.2 || >=24.15.0”}
          npm error notsup Actual: {“npm”:“10.9.4”,“node”:“v22.21.1”}
          Then I tried using the script and it installed node v22.22.2 and looks like it is working.
          marksimon@digiframe:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
          update log will be in /home/marksimon/MagicMirror/installers/upgrade.log
          Check current Node installation …
            sdetweil @msimon360
            yes, you didn’t use the install script you did it manually
              @sdetweil I see some major changes coming down the line for npm v12.
              https://github.blog/changelog/2026-07-08-npm-install-time-security-and-gat-bypass2fa-deprecation/
                sdetweil @mumblebaj
                @mumblebaj yeh, I was working on a mobile app last weekend
                It had npm 11 installed ( windows) and had all the acceptscript problems
                  @sdetweil Yeah, warnings come from 11.16.0+
                    sdetweil @mumblebaj
                    @mumblebaj on windows these were NOT warnings… I actually had to run different tasks to get the scripts allowed/approved… I hadn’t expected that in npm 11…
                    same problem as always, some scammers leveraged the automation tools to do damage and now we all have to pay for it…
                      MyMirror
                      Moin (as we say here in Hamburg),
                      I’ve just reinstalled my MM using Sam’s “Install MagicMirror²” script. The script displayed and verified Node version 22.22.1.
                      I then ran Sam’s upgrade script, which expected Node version 22.22.2 and installed it.
                      If that’s how it’s meant to be – everything’s fine.
                      pimaster@MM0626:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      update log will be in /home/pimaster/MagicMirror/installers/upgrade.log
                      local version 2.37.0 already same as master 2.37.0
                      moving css contents to config
                        MyMirror @MyMirror
                        There might also be a minor error in Sam’s restore script here.
                        The “MMM-MyWastePickup” directory was the only one that triggered the “folder already exists” error following a fresh installation.
                        restoring MMM-MyWastePickup
                        module MMM-MyWastePickup contains package.json, doing npm install
                        there were files saved for this module , restoring
                         MMM-MyWastePickup folder already exists, skipping restore from https://github.com/jclarke0000/MMM-MyWastePickup.git
                        restoring MMM-NearCompliments
                        module MMM-NearCompliments contains package.json, doing npm install
                          sdetweil @MyMirror
                          @MyMirror can you provide me the
                          ~/MagicMirror/installlers/restore.log
                          open an issue and attach it there
                          In the issue. Please explain the steps you used up to restore
                          edit
                          | thanks… see it
                            this was a bug in backup and restore when multiple ‘module’ folders were sourced from the same git repo (multi- instance copy type problem)
                            the two scripts are fixed now… if you used these scripts, please run another backup to make sure the module_list file is updated…
