    VM Disk Full - 50 GiB in 4 months
    19 Posts 2 Posters 485 Views 2 Watching
      sdetweil @JohnGalt
      @JohnGalt next is who’s dump is it… electron?
        JohnGalt @sdetweil
        @sdetweil – true. I’m not sure I know to find that out…
          JohnGalt @JohnGalt
          is that file [just] a record of the dump[s]?
          Put differently, would it be safe to delete the file or directory?
          [Edit]: On further recollection - this appears to be happening only on the two VMs running MM, and not on the two Raspberry Pis that I have MM running on.
          Does this represent a clue as to what is happening?
            sdetweil @JohnGalt
            @JohnGalt in the folder with the core dump files do
            sudo file * >>~/somefile.txt
            then ~/somefile.txt will have a line for each which should contain the failing code name
            from
            https://stackoverflow.com/questions/13308922/find-which-program-caused-a-core-dump-file
              JohnGalt @sdetweil
              Well, there’s this under /var/lib/apport/coredump:
              Name:
              core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
              Size:
              40,486,436,864
                sdetweil @JohnGalt
                @JohnGalt well then… electron crashed…
                which MM version are you on
                grep version package.json
                and for electron
                grep version node_modules/electron/package.json
                  JohnGalt @sdetweil
                  JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version package.json
                          "version": "2.35.0",
                  JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version node_modules/electron/package.json
                    "version": "41.2.0"
                    sdetweil @JohnGalt
                    @JohnGalt if you hadn’t erased the logs, the pm2 log MIGHT have had a fault listed…
                    2.37 is the current release, 6 months newer… electron at 42.5.2
                    supposedly this could help find cause
                     Analyze the Crash Dump
                    Because Electron code is pre-compiled, looking at a raw dump file yields only unreadable memory addresses.
                    You need to symbolicate the dump using matching Electron debugging symbols.
                    The CLI Tool (electron-minidump)
                        The easiest open-source way to inspect a .dmp file locally is using the electron-   minidump CLI tool.
                    It automatically fetches the matching Electron symbols and outputs a readable stack trace.
                    Install the utility:
                    sudo  npm install -g electron-minidump
                    Analyze your file:
                    electron-minidump -f /path/to/your/file.dmp
                      JohnGalt @sdetweil
                      @sdetweil – OK, well… The program DID install (I was surprised , given what has been happening…). This resulted in an error. I specified that large file we identified earlier. Do let me know if I did the wrong thing. See results below.
                      While you are looking at this, I am going to fire up the other, older VM that also crashed and see if there is similar evidence there that might shed light.
                      JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo  npm install -g electron-minidump
                      [sudo] password for JohnGalt:
                      added 29 packages in 34s
                      1 package is looking for funding
                        run `npm fund` for details
                      npm notice
                      npm notice New major version of npm available! 10.9.4 -> 12.0.2
                      npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2
                      npm notice To update run: npm install -g npm@12.0.2
                      npm notice
                      JohnGalt@MM-Dev-VM:~/MagicMirror$ electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                      Error: EACCES: permission denied, open '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464'
                          at async Object.open (node:internal/fs/promises:641:25)
                          at async electronMinidump (/usr/local/lib/node_modules/electron-minidump/index.js:11:14) {
                        errno: -13,
                        code: 'EACCES',
                        syscall: 'open',
                        path: '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464'
                      JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                      Not a minidump file (MDMP header not found): /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                        sdetweil @JohnGalt
                        @JohnGalt you need sudo in front of the mini dump. Line cause the file is in the /var folder
                          JohnGalt @sdetweil
                          @sdetweil – Yes, I did.
                          The output I pasted included 2 runs. The first returned an access error as expected. The 2nd run says ‘not a minidump file’.
                          I guess I confused things by pasting all that. Sorry.
                            sdetweil @JohnGalt
                            @JohnGalt no problem… thx… I have not tried to examine them myself either
