VM Disk Full - 50 GiB in 4 months
@sdetweil – Thanks Sam. See below for the output of the file sizes there.
JohnGalt@MM-Dev-VM:~/.pm2/logs$ ls -laF total 32988 drwxrwxr-x 2 al al 4096 Apr 12 11:24 ./ drwxrwxr-x 5 al al 4096 Aug 19 12:09 ../ -rw-rw-r-- 1 al al 27348992 Aug 17 23:33 MagicMirror-error.log -rw-rw-r-- 1 al al 6413424 Aug 17 23:27 MagicMirror-out.log -
27348992
error log is 27 meg… not gig
after that you would have to use something like ncdu
ncdu (NCurses Disk Usage) is a fast, text-based command-line tool used to analyze disk space. It scans your file system and shows which folders and files use the most space, letting you easily navigate and delete large items directly inside an interactive terminal screen. How to Install ncdu Ubuntu / Debian: sudo apt install ncdu CentOS / RHEL / Fedora: sudo dnf install ncdu or sudo yum install ncdu macOS: brew install ncdu Arch Linux: sudo pacman -S ncdu Common Commands ncdu — Scan the current folder. sudo ncdu / --Scan your entire hard drive. ncdu /home --Scan a specific folder. ncdu -x --Scan only the current disk (ignore mounted external drives). Useful Keyboard Shortcuts Up / Down arrows or j / k — Move through the list. Enter / Right arrow — Open a folder to see files inside. Left arrow — Go back to the parent folder. d — Delete the highlighted file or folder. -
@sdetweil – Thanks, Sam. It looks like that won’t work - for the same reason as above. I need to give this some more thought… I can’t be the first person to encounter this issue. See below for the output of trying to install ncdu:
JohnGalt@MM-Dev-VM:~/.pm2/logs$ sudo apt install ncdu Reading package lists... Done Building dependency tree... Done Reading state information... Done The following NEW packages will be installed: ncdu 0 upgraded, 1 newly installed, 0 to remove and 33 not upgraded. Need to get 50.7 kB of archives. After this operation, 117 kB of additional disk space will be used. E: You don't have enough free space in /var/cache/apt/archives/. JohnGalt@MM-Dev-VM:~/.pm2/logs$ -
@JohnGalt erase the files in the .pm2/logs folder, they are not the cause
@sdetweil – I will do that. I was just down the rabbit hole, using df. It looks like a huge amount is taken up by /var/lib/apport/coredump. See below:
JohnGalt@MM-Dev-VM:~/.pm2/logs$ df -h Filesystem Size Used Avail Use% Mounted on tmpfs 794M 1.1M 793M 1% /run /dev/sda2 49G 49G 0 100% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock efivarfs 56K 27K 25K 52% /sys/firmware/efi/efivars /dev/sda1 300M 7.8M 292M 3% /boot/efi tmpfs 794M 92K 794M 1% /run/user/1000 JohnGalt@MM-Dev-VM:~/.pm2/logs$ cd .. JohnGalt@MM-Dev-VM:~/.pm2$ cd .. JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var | sort -h | tail -n 10 4.0K /var/metrics 4.0K /var/opt 28K /var/crash 40K /var/spool 68K /var/tmp 5.4M /var/backups 49M /var/cache 617M /var/log 39G /var 39G /var/lib JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib | sort -h | tail -n 10 772K /var/lib/systemd 2.0M /var/lib/fwupd 3.8M /var/lib/command-not-found 4.2M /var/lib/aspell 7.5M /var/lib/ubuntu-advantage 40M /var/lib/swcatalog 92M /var/lib/dpkg 276M /var/lib/apt 38G /var/lib/apport 39G /var/lib JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib/apport | sort -h | tail -n 10 38G /var/lib/apport 38G /var/lib/apport/coredump JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib/apport/coredump | sort -h | tail -n 10 38G /var/lib/apport/coredump JohnGalt@MM-Dev-VM:~$ -
@JohnGalt next is who’s dump is it… electron?
@sdetweil – true. I’m not sure I know to find that out…
is that file [just] a record of the dump[s]?
Put differently, would it be safe to delete the file or directory?
[Edit]: On further recollection - this appears to be happening only on the two VMs running MM, and not on the two Raspberry Pis that I have MM running on.
Does this represent a clue as to what is happening?
@JohnGalt in the folder with the core dump files do
sudo file * >>~/somefile.txt
then ~/somefile.txt will have a line for each which should contain the failing code name
from
https://stackoverflow.com/questions/13308922/find-which-program-caused-a-core-dump-file -
Well, there’s this under /var/lib/apport/coredump:
Name:
core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464Size:
40,486,436,864 -
@JohnGalt well then… electron crashed…
which MM version are you on
grep version package.jsonand for electron
grep version node_modules/electron/package.json -
JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version package.json "version": "2.35.0", JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version node_modules/electron/package.json "version": "41.2.0" -
@JohnGalt if you hadn’t erased the logs, the pm2 log MIGHT have had a fault listed…
2.37 is the current release, 6 months newer… electron at 42.5.2
supposedly this could help find cause
Analyze the Crash Dump Because Electron code is pre-compiled, looking at a raw dump file yields only unreadable memory addresses. You need to symbolicate the dump using matching Electron debugging symbols. The CLI Tool (electron-minidump) The easiest open-source way to inspect a .dmp file locally is using the electron- minidump CLI tool. It automatically fetches the matching Electron symbols and outputs a readable stack trace. Install the utility: sudo npm install -g electron-minidump Analyze your file: electron-minidump -f /path/to/your/file.dmp -
@sdetweil – OK, well… The program DID install (I was surprised , given what has been happening…). This resulted in an error. I specified that large file we identified earlier. Do let me know if I did the wrong thing. See results below.
While you are looking at this, I am going to fire up the other, older VM that also crashed and see if there is similar evidence there that might shed light.
JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo npm install -g electron-minidump [sudo] password for JohnGalt: added 29 packages in 34s 1 package is looking for funding run `npm fund` for details npm notice npm notice New major version of npm available! 10.9.4 -> 12.0.2 npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2 npm notice To update run: npm install -g npm@12.0.2 npm notice JohnGalt@MM-Dev-VM:~/MagicMirror$ electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 Error: EACCES: permission denied, open '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464' at async Object.open (node:internal/fs/promises:641:25) at async electronMinidump (/usr/local/lib/node_modules/electron-minidump/index.js:11:14) { errno: -13, code: 'EACCES', syscall: 'open', path: '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464' } JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 Not a minidump file (MDMP header not found): /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 JohnGalt@MM-Dev-VM:~/MagicMirror$ -
@JohnGalt you need sudo in front of the mini dump. Line cause the file is in the /var folder
