    VM Disk Full - 50 GiB in 4 months
    19 Posts 2 Posters 484 Views 2 Watching
      JohnGalt
      Query: What would cause a MagicMirror installed on a VM to fill up the 50 GiB VM virtual disk over 4 months?
      I have an instance of MagicMirror installed in a Linux VM running under TrueNAS, which is mostly used to try out modules, configurations or layouts without disturbing the main MagicMirror. When I went to look at it yesterday I found the VM running, but not MM. PM2 status did not show it running, and it would [re]start. MagicMirror is the only thing installed on the VM, and running modules were newsfeed and default weather [5 instances],
      Some searching tells me the virtual disk of 50 GiB is full! I have expanded the virtual disk size [resized the zvol], but am unable to extend the partition and filesystem as I get an error. I think it was along the lines of “you don’t have enough free space in /var/cache/apt/archives”.
      At this point it appeared the best route would be to just build a new VM and install MM, but when I went to start making notes to record what I was doing - I found this same thing happened some months ago. The current VM is an upsized VM that similarly locked up.
      Since starting over will not apparently solve the underlying root cause, I need some help. Thanks in advance.
        sdetweil @JohnGalt
        @JohnGalt from MagicMirror the only thing could be the output of the console log. If debugging is enabled ( logLevel:[ “debug”]), calendar can generate a bunch of output
        If this is a vm, logon and look at the
        .pm2/logs folder
        Get the file sizes
        ls -laF
          JohnGalt @sdetweil
          @sdetweil – Thanks Sam. See below for the output of the file sizes there.
          JohnGalt@MM-Dev-VM:~/.pm2/logs$ ls -laF
          total 32988
          drwxrwxr-x 2 al al     4096 Apr 12 11:24 ./
          drwxrwxr-x 5 al al     4096 Aug 19 12:09 ../
          -rw-rw-r-- 1 al al 27348992 Aug 17 23:33 MagicMirror-error.log
          -rw-rw-r-- 1 al al  6413424 Aug 17 23:27 MagicMirror-out.log
            sdetweil @JohnGalt
            @JohnGalt said:
            27348992
            error log is 27 meg… not gig
            after that you would have to use something like ncdu
            ncdu (NCurses Disk Usage) is a fast, text-based command-line tool used to analyze disk space.
            It scans your file system and shows which folders and files use the most space, letting you easily navigate and delete large items directly inside an interactive terminal screen.
            How to Install ncdu
            Ubuntu / Debian: sudo apt install ncdu
            CentOS / RHEL / Fedora: sudo dnf install ncdu or sudo yum install ncdu
            macOS: brew install ncdu
            Arch Linux: sudo pacman -S ncdu
            Common Commands
            ncdu — Scan the current folder.  sudo ncdu / --Scan your entire hard drive.
            ncdu /home --Scan a specific folder.
            ncdu -x --Scan only the current disk (ignore mounted external drives).
            Useful Keyboard Shortcuts
            Up / Down arrows or j / k — Move through the list.
            Enter / Right arrow — Open a folder to see files inside.
            Left arrow — Go back to the parent folder.
            d — Delete the highlighted file or folder.
              JohnGalt @sdetweil
              @sdetweil – Thanks, Sam. It looks like that won’t work - for the same reason as above. I need to give this some more thought… I can’t be the first person to encounter this issue. See below for the output of trying to install ncdu:
              JohnGalt@MM-Dev-VM:~/.pm2/logs$ sudo apt install ncdu
              Reading package lists... Done
              Building dependency tree... Done
              The following NEW packages will be installed:
                ncdu
              0 upgraded, 1 newly installed, 0 to remove and 33 not upgraded.
              Need to get 50.7 kB of archives.
              After this operation, 117 kB of additional disk space will be used.
              E: You don't have enough free space in /var/cache/apt/archives/.
                sdetweil @JohnGalt
                @JohnGalt erase the files in the .pm2/logs folder, they are not the cause
                  JohnGalt @sdetweil
                  @sdetweil – I will do that. I was just down the rabbit hole, using df. It looks like a huge amount is taken up by /var/lib/apport/coredump. See below:
                  JohnGalt@MM-Dev-VM:~/.pm2/logs$ df -h
                  Filesystem      Size  Used Avail Use% Mounted on
                  tmpfs           794M  1.1M  793M   1% /run
                  /dev/sda2        49G   49G     0 100% /
                  tmpfs           3.9G     0  3.9G   0% /dev/shm
                  tmpfs           5.0M     0  5.0M   0% /run/lock
                  efivarfs         56K   27K   25K  52% /sys/firmware/efi/efivars
                  /dev/sda1       300M  7.8M  292M   3% /boot/efi
                  tmpfs           794M   92K  794M   1% /run/user/1000
                  JohnGalt@MM-Dev-VM:~/.pm2/logs$ cd ..
                  JohnGalt@MM-Dev-VM:~/.pm2$ cd ..
                  JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var | sort -h | tail -n 10
                  4.0K    /var/metrics
                  4.0K    /var/opt
                  28K     /var/crash
                  40K     /var/spool
                  68K     /var/tmp
                  5.4M    /var/backups
                  49M     /var/cache
                  617M    /var/log
                  39G     /var
                  39G     /var/lib
                  JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib | sort -h | tail -n 10
                  772K    /var/lib/systemd
                  2.0M    /var/lib/fwupd
                  3.8M    /var/lib/command-not-found
                  4.2M    /var/lib/aspell
                  7.5M    /var/lib/ubuntu-advantage
                  40M     /var/lib/swcatalog
                  92M     /var/lib/dpkg
                  276M    /var/lib/apt
                  38G     /var/lib/apport
                  39G     /var/lib
                  JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib/apport | sort -h | tail -n 10
                  38G     /var/lib/apport
                  38G     /var/lib/apport/coredump
                  JohnGalt@MM-Dev-VM:~$ sudo du -h --max-depth=1 /var/lib/apport/coredump | sort -h | tail -n 10
                    sdetweil @JohnGalt
                    @JohnGalt next is who’s dump is it… electron?
                      JohnGalt @sdetweil
                      @sdetweil – true. I’m not sure I know to find that out…
                        JohnGalt @JohnGalt
                        is that file [just] a record of the dump[s]?
                        Put differently, would it be safe to delete the file or directory?
                        [Edit]: On further recollection - this appears to be happening only on the two VMs running MM, and not on the two Raspberry Pis that I have MM running on.
                        Does this represent a clue as to what is happening?
                          sdetweil @JohnGalt
                          @JohnGalt in the folder with the core dump files do
                          sudo file * >>~/somefile.txt
                          then ~/somefile.txt will have a line for each which should contain the failing code name
                          from
                          https://stackoverflow.com/questions/13308922/find-which-program-caused-a-core-dump-file
                            JohnGalt @sdetweil
                            Well, there’s this under /var/lib/apport/coredump:
                            Name:
                            core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                            Size:
                            40,486,436,864
                              sdetweil @JohnGalt
                              @JohnGalt well then… electron crashed…
                              which MM version are you on
                              grep version package.json
                              and for electron
                              grep version node_modules/electron/package.json
                                JohnGalt @sdetweil
                                JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version package.json
                                        "version": "2.35.0",
                                JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version node_modules/electron/package.json
                                  "version": "41.2.0"
                                  sdetweil @JohnGalt
                                  @JohnGalt if you hadn’t erased the logs, the pm2 log MIGHT have had a fault listed…
                                  2.37 is the current release, 6 months newer… electron at 42.5.2
                                  supposedly this could help find cause
                                   Analyze the Crash Dump
                                  Because Electron code is pre-compiled, looking at a raw dump file yields only unreadable memory addresses.
                                  You need to symbolicate the dump using matching Electron debugging symbols.
                                  The CLI Tool (electron-minidump)
                                      The easiest open-source way to inspect a .dmp file locally is using the electron-   minidump CLI tool.
                                  It automatically fetches the matching Electron symbols and outputs a readable stack trace.
                                  Install the utility:
                                  sudo  npm install -g electron-minidump
                                  Analyze your file:
                                  electron-minidump -f /path/to/your/file.dmp
                                    JohnGalt @sdetweil
                                    @sdetweil – OK, well… The program DID install (I was surprised , given what has been happening…). This resulted in an error. I specified that large file we identified earlier. Do let me know if I did the wrong thing. See results below.
                                    While you are looking at this, I am going to fire up the other, older VM that also crashed and see if there is similar evidence there that might shed light.
                                    JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo  npm install -g electron-minidump
                                    [sudo] password for JohnGalt:
                                    added 29 packages in 34s
                                    1 package is looking for funding
                                      run `npm fund` for details
                                    npm notice
                                    npm notice New major version of npm available! 10.9.4 -> 12.0.2
                                    npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2
                                    npm notice To update run: npm install -g npm@12.0.2
                                    npm notice
                                    JohnGalt@MM-Dev-VM:~/MagicMirror$ electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                                    Error: EACCES: permission denied, open '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464'
                                        at async Object.open (node:internal/fs/promises:641:25)
                                        at async electronMinidump (/usr/local/lib/node_modules/electron-minidump/index.js:11:14) {
                                      errno: -13,
                                      code: 'EACCES',
                                      syscall: 'open',
                                      path: '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464'
                                    JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                                    Not a minidump file (MDMP header not found): /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464
                                      sdetweil @JohnGalt
                                      @JohnGalt you need sudo in front of the mini dump. Line cause the file is in the /var folder
                                        JohnGalt @sdetweil
                                        @sdetweil – Yes, I did.
                                        The output I pasted included 2 runs. The first returned an access error as expected. The 2nd run says ‘not a minidump file’.
                                        I guess I confused things by pasting all that. Sorry.
                                          sdetweil @JohnGalt
                                          @JohnGalt no problem… thx… I have not tried to examine them myself either
