    MMM-EventCountdown - A countdown for holidays, birthdays, anniversaries, and other upcoming events
    7 Posts 3 Posters 438 Views 3 Watching
    • T
      trnitz
      A customizable MagicMirror² module for counting down to birthdays, holidays, anniversaries, appointments, trips, and other events.
      The nearest event is presented as a stable, live days/hours/minutes/seconds countdown with an optional emoji. A rotating, days-only summary of the later upcoming events fades in and out beneath it; the active main event is excluded from that rotation.
      Features
      • Displays the nearest upcoming event as the main countdown.
      • Shows days, hours, minutes, and seconds.
      • Offers digital, flip-clock, progress-ring, and hourglass counter styles.
      • Rotates through days-only summaries of later upcoming events without repeating the active main event.
      • Supports fixed dates, calculated Easter dates, and weekday-based rules.
      • Repeats events annually by default.
      • Supports one-time events with repeatYearly: false.
      • Displays an optional emoji for the main event and its rotating summary.
      Screenshot
      See https://github.com/trnitz/MMM-EventCountdown
      Installation and usage instructions are in the project’s README.md
      Project origins
      This project combines and extends ideas from two open-source MagicMirror modules:
      TouaregWarrior/MMM-HolidayCountdown provides the original holiday/trip countdown module on which this project is based.
      double-ratchet/MMM-AnimatedCountdowns, by ElliAndDad, provides the basis for the digital, flip, progress-ring, and hourglass counter styles adapted here.
      The resulting module adds four selectable counter styles, rotating event summaries, reusable yearly events, one-time events, movable-date rules, calculated Easter dates, and per-event emojis.
      plainbrokeP 1 Reply Last reply
      • plainbrokeP
        plainbroke @trnitz
        @trnitz
        You need to add a link to the module.
        T 1 Reply Last reply
        • T
          trnitz @plainbroke
          @plainbroke said:
          @trnitz
          That would be helpful, wouldn’t it :-)
          Download and additional details available on project’s github repository.
            sdetweil @trnitz
            @trnitz I added the link to your announcement page
            • plainbrokeP
              plainbroke @sdetweil
              @trnitz
              Pretty cool little module, Do you have a way to enlarge it 2 or 3 times as large???
              • T
                trnitz @plainbroke
                @plainbroke said:
                @trnitz
                You can do this using your custom.css file.
                If you have a single instance of this module running, simply add this to your custom.css file:
                 .MMM-EventCountdown .event-countdown {
                      zoom: 2; /* fractional number also accepted */
                If you have more than a single instance of this module running, add a unique classes value in config.js:
                    module: "MMM-EventCountdown",
                    classes: "countdown-large",
                Then, in your custom.css file:
                 .MMM-EventCountdown.countdown-large .event-countdown {
                      zoom: 2; /* or 1.5, 3, etc... */
                Any fraction of a number, such as 1.5, 2.25, etc, will also work.
                Screen shot of it set to 2:
                • plainbrokeP
                  plainbroke @trnitz
                  @trnitz
                  Thank you for the information. really makes a difference.
