    New Module to download photos from Apple iCloud
    11 Posts 3 Posters 597 Views 4 Watching
    • msimon360M
      msimon360
      I have a new module MMM-iCloudPhotos That will sync an Album from your Apple iCloud to your Magic Mirror. The Album does NOT need to be public and can be Personal or Shared.
      With a Shared Album you and anyone you invite can add or remove photos from any Apple Device and they will appear on your mirror.
      B 1 Reply Last reply
        Bungle68 @msimon360
        @msimon360 Thats brilliant, I’ve been hoping for this for a while.
        Will give it a go.
        msimon360M 1 Reply Last reply
        • msimon360M
          msimon360 @Bungle68
          @Bungle68 Thanks let me know how it works for you. A few things I have found so far. I am using it with MMM-ImagesPhotos. When I add photos to the Album they sync to the uploads directory but they don’t display until I restart mm. It may just be my config values. Still testing. Also if I remove a photo from the Album a blank is shown for the removed photo until MMM-ImagesPhotos refreshes. I guess this is expected. I am looking into sending a Notification to force a refresh.
            sdetweil @msimon360
            @msimon360 imagesphotos should refresh its list of images every 60 seconds by default
            I use it linked to a file share on my nas
            Because there are so many pics no idea when the new pic will appear, add random on to that and it’s worse for predictably
            • msimon360M
              msimon360 @sdetweil
              @sdetweil I was testing on an album with only 4 photos and set to sequential. What I found, with help of Claude, was Before the Dec 2023 fetch rewrite, every completed request did:
              if (retry) {
                self.scheduleUpdate(self.loaded ? -1 : self.config.retryDelay);
              After the rewrite it became:
              if (!photosResponse.ok) {
                if (retry) self.scheduleUpdate(...);
              So the directory list only refreshed on HTTP failure, not every getInterval. I have an updated MMM-ImagesPhotos.js with a fix but I don’t know the best way to send it. Would you like a diff, patch, GitHub branch, other?
                sdetweil @msimon360
                @msimon360 ImagePhotos isn’t mine, I have a fork…
                so, generally how you do this , for any change to any repo on github
                on github, find the source module repo
                make a fork (copy on YOUR github)
                checkout your fork
                make a new branch
                make the changes
                commit to local branch
                push to your github fork
                github will see this and offer to create a PULL request to the original source , and the author can execute that PULL , from yours to theirs (merge is the operation)
                once its merged, then you can delete your branch
                and then sync the source to your fork (if you still want the fork)
                git pull on your fork to get the update,
                OR
                delete your local copy of the fork, and redownload the original repo again
                and maybe delete your fork on github, if you think you will never need it again
                as for the bug
                retry is a bad choice of variable, if its not in a failure path!.. lol…
                • msimon360M
                  msimon360 @sdetweil
                  @sdetweil Thanks for the detailed instructions. I am using your fork and I made the pull request. The only files changed are MMM-ImagesPhotos.js and I put my GitHub link in the README.md.
                    sdetweil @msimon360
                    @msimon360 merged… also merged support for apple HEIC images…
                    git pull
                    to get the latest
                    or sync your fork, then git pull
                    • msimon360M
                      msimon360 @sdetweil
                      @sdetweil I gave it a try and no photos displayed. I went back to my repo. The explanation I got from AI was this;
                      Why photos disappeared
                      non-fullscreen (bottom_center) crashes in getDomnotFS because EXIF is appended to this.wrapper (fullscreen-only) instead of the local wrapper. With default showExifDate: true, getDom throws → blank module.
                        sdetweil @msimon360
                        @msimon360 ok. Set the showexif: false
                        Will review
                          I fixed the crash, git pull
