    VM Disk Full - 50 GiB in 4 months
    24 Posts 2 Posters 756 Views 2 Watching
      JohnGalt @sdetweil
      @sdetweil – Thanks, Sam.
      When I get back from my travels next week I hope to have time to look at this.
      IIRC, my primary stumbling block is how full the disk is, meaning I don’t recall if the machine even still boots. I hope it still has room to boot and load the script! That would be great.
        sdetweil @JohnGalt
        @JohnGalt if you have a usb carrier for the sd card, you could make and boot another one and mount the old one to erase the files
        J 1 Reply Last reply
          JohnGalt @sdetweil
          @sdetweil – Just as a reminder, this is an instance of Magic Mirror installed on Linux in a Virtual Machine, running under TrueNAS Scale.
          I just confirmed that the VM will start and run and I can SSH into it from my desktop. As such, I should be able to upload the script.
          Query: Do we expect the script to run as intended under a VM?
            sdetweil @JohnGalt
            @JohnGalt it should under a VM… under a docker container no
