VM Disk Full - 50 GiB in 4 months
@JohnGalt in the folder with the core dump files do
sudo file * >>~/somefile.txt
then ~/somefile.txt will have a line for each which should contain the failing code name
from
https://stackoverflow.com/questions/13308922/find-which-program-caused-a-core-dump-file -
Well, there’s this under /var/lib/apport/coredump:
Name:
core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464Size:
40,486,436,864 -
@JohnGalt well then… electron crashed…
which MM version are you on
grep version package.jsonand for electron
grep version node_modules/electron/package.json -
JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version package.json "version": "2.35.0", JohnGalt@MM-Dev-VM:~/MagicMirror$ grep version node_modules/electron/package.json "version": "41.2.0" -
@JohnGalt if you hadn’t erased the logs, the pm2 log MIGHT have had a fault listed…
2.37 is the current release, 6 months newer… electron at 42.5.2
supposedly this could help find cause
Analyze the Crash Dump Because Electron code is pre-compiled, looking at a raw dump file yields only unreadable memory addresses. You need to symbolicate the dump using matching Electron debugging symbols. The CLI Tool (electron-minidump) The easiest open-source way to inspect a .dmp file locally is using the electron- minidump CLI tool. It automatically fetches the matching Electron symbols and outputs a readable stack trace. Install the utility: sudo npm install -g electron-minidump Analyze your file: electron-minidump -f /path/to/your/file.dmp -
@sdetweil – OK, well… The program DID install (I was surprised , given what has been happening…). This resulted in an error. I specified that large file we identified earlier. Do let me know if I did the wrong thing. See results below.
While you are looking at this, I am going to fire up the other, older VM that also crashed and see if there is similar evidence there that might shed light.
JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo npm install -g electron-minidump [sudo] password for JohnGalt: added 29 packages in 34s 1 package is looking for funding run `npm fund` for details npm notice npm notice New major version of npm available! 10.9.4 -> 12.0.2 npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2 npm notice To update run: npm install -g npm@12.0.2 npm notice JohnGalt@MM-Dev-VM:~/MagicMirror$ electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 Error: EACCES: permission denied, open '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464' at async Object.open (node:internal/fs/promises:641:25) at async electronMinidump (/usr/local/lib/node_modules/electron-minidump/index.js:11:14) { errno: -13, code: 'EACCES', syscall: 'open', path: '/var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464' } JohnGalt@MM-Dev-VM:~/MagicMirror$ sudo electron-minidump -f /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 Not a minidump file (MDMP header not found): /var/lib/apport/coredump/core._home_al_MagicMirror_node_modules_electron_dist_electron.1000.f1d1264a-f2d2-4a44-8b27-e2f3182e030f.380943.121091464 JohnGalt@MM-Dev-VM:~/MagicMirror$ -
@JohnGalt you need sudo in front of the mini dump. Line cause the file is in the /var folder
@sdetweil – Yes, I did.
The output I pasted included 2 runs. The first returned an access error as expected. The 2nd run says ‘not a minidump file’.
I guess I confused things by pasting all that. Sorry.
@JohnGalt no problem… thx… I have not tried to examine them myself either
@JohnGalt there is a new script in my package , cleanup.sh
intended to erase all the electron binary downloads and
any npm cache -
@sdetweil – Thanks, Sam.
When I get back from my travels next week I hope to have time to look at this.
IIRC, my primary stumbling block is how full the disk is, meaning I don’t recall if the machine even still boots. I hope it still has room to boot and load the script! That would be great.
