    Converting an old JS file into a module
    20 Posts 3 Posters 14.5k Views 3 Watching
    • O Offline
      ooom416354 @yawns
      @yawns I think maybe if you guys are able to do the conversion I can then dive in and figure out how to go from one to the other. If I try to do it I think I’d get stuck too many times as I am pretty poor in JS. I really appreciate it!
      • cowboysdudeC Offline
        Looks like it just needs a vehicle to display the info in the MM…
        • O Offline
          ooom416354 @cowboysdude
          @cowboysdude for the old MM we ended up using the other function that the developer wrote to refresh and display it on the page. I’m just not sure how I can display it on the MM2 or what I’d need to rewrite to get it to work.
          • Y Offline
            yawns Moderator @ooom416354
            @ooom416354
            ok. Do you have an api key you could provide to me via chat/pm? Then I don’t need to request an own one just for testing purposes
            Nevermind, I got one :)
              cowboysdude Module Developer @ooom416354
              @ooom416354 If you know js it’s easy…
              https://github.com/MichMich/MagicMirror/tree/develop/modules
              • O Offline
                @cowboysdude problem is I am so new to it and I don’t really know the best way to test without actually uploading everything to the Pi. I was using notepad++ to write but for testing I had used xampp for the MM1. That doesn’t work with node I don’t think right? I am a programmer but work mostly as a SQL developer so I never had a need for learning JavaScript. Is there any particular class, site, etc. I can start out with to learn and actually develop myself? Thanks.
                • Y Offline
                  yawns Moderator
                  @ooom416354
                  Could you please tell me your sStation code? I just did some testing with the JSON and noticed I don’t get up-to-date data.
                  When I run this I always get data from this morning: https://traintime.lirr.org/api/Departure?loc=CLP&api_key=XXXXXXXXXXXXXXXXX
                  I need to take a closer look into this later.
                  O 1 Reply Last reply Reply Quote 1
                  • O Offline
                    ooom416354 @yawns
                    @yawns yes that’s the local station to my house, CLP. The morning ride is CLP to NYK then reverse in the afternoon. It should show the closest train departures and if there’s a delay so this morning would make sense (there were no delays today that I know of). So when I test I would just set a delay of like 8 minutes to see if anything showed up.
                    • Y Offline
                      @ooom416354
                      Do you know of a list of all stations with their LOC code for api requests? They have a list of stations, but I can’t find the codes
                      • O Offline
                        ooom416354 @yawns
                        @yawns there used to be a ton of documentation on the API which for some reason is now offline. I found a list that was downloaded, here is the link
                        https://docs.google.com/viewer?a=v&pid=forums&srcid=MTI4MTUwMDQ0Mzg3NzE4MjExMDUBMTQyOTI2NzA2MDkyODAxMjI5MDABbmJnanZROTlFUUFKATAuMQEBdjI&authuser=0
                        Y 1 Reply Last reply Reply Quote 1
                        • Y Offline
                          @ooom416354
                          Exactly what I was looking for. Thanks alot!
                          O 2 Replies Last reply Reply Quote 0
                          • O Offline
                            ooom416354 @yawns
                            @yawns no problem, I am still trying to find working link where this can be pulled, although there won’t be any new stations anytime soon.
                            • O Offline
                              ooom416354 @yawns
                              @yawns Here’s all of the feeds, the site is down but I have the links:
                              Full Station Listing with details:
                              https://traintime.lirr.org/api/Stations-All
                              Schedules based on Starting Station input (startsta=) and Ending Station input (endsta=) along with date/time (can be future dated)
                              https://traintime.lirr.org/api/TrainTime?startsta=CLP&endsta=NYK&year=2017&month=02&day=04&hour=05&minute=00&datoggle=d
                              Actual Train Schedules closest to the current time (passing in the 3 letter station code after loc=). This is different from the other link that I used for the JS file as it doesn’t show the ETA of the train.
                              https://traintime.lirr.org/api/Departure?api_key=&loc=
                              • O Offline
                                ooom416354
                                @yawns Hey I saw on git, MMM-MTA, not sure if that is all working or not though. Still working on configuring some stuff on my end but wanted to see if that was usable?
                                • Y Offline
                                  @ooom416354
                                  Hi, right that is the module I was working on. Over the last days I was completely busy doing cable stuff in my house and the weekend was blocked with dog training annual tax declaration.
                                  I try to complete it today or tomorrow.
                                  • O Offline
                                    ooom416354 @yawns
                                    @yawns that’s amazing, thanks! I was going to start using it to try to teach myself by comparing the two. Thank you again!
