    Converting an old JS file into a module
    20 Posts 3 Posters 13.7k Views 3 Watching
    • yawnsY Offline
      yawns Moderator
      Okay, looks rather simple. Do you want to develop it yourself and just need a push into the right direction? Or do you want one of us to do the conversion?
      ooom416354O 1 Reply Last reply Reply Quote 1
      • ooom416354O Offline
        ooom416354 @yawns
        @yawns I think maybe if you guys are able to do the conversion I can then dive in and figure out how to go from one to the other. If I try to do it I think I’d get stuck too many times as I am pretty poor in JS. I really appreciate it!
        • cowboysdudeC Offline
          Looks like it just needs a vehicle to display the info in the MM…
          ooom416354O 1 Reply Last reply Reply Quote 0
            ooom416354 @cowboysdude
            @cowboysdude for the old MM we ended up using the other function that the developer wrote to refresh and display it on the page. I’m just not sure how I can display it on the MM2 or what I’d need to rewrite to get it to work.
            • yawnsY Offline
              yawns Moderator @ooom416354
              @ooom416354
              ok. Do you have an api key you could provide to me via chat/pm? Then I don’t need to request an own one just for testing purposes
              Nevermind, I got one :)
                cowboysdude Module Developer @ooom416354
                @ooom416354 If you know js it’s easy…
                https://github.com/MichMich/MagicMirror/tree/develop/modules
                  @cowboysdude problem is I am so new to it and I don’t really know the best way to test without actually uploading everything to the Pi. I was using notepad++ to write but for testing I had used xampp for the MM1. That doesn’t work with node I don’t think right? I am a programmer but work mostly as a SQL developer so I never had a need for learning JavaScript. Is there any particular class, site, etc. I can start out with to learn and actually develop myself? Thanks.
                  • yawnsY Offline
                    yawns Moderator
                    @ooom416354
                    Could you please tell me your sStation code? I just did some testing with the JSON and noticed I don’t get up-to-date data.
                    When I run this I always get data from this morning: https://traintime.lirr.org/api/Departure?loc=CLP&api_key=XXXXXXXXXXXXXXXXX
                    I need to take a closer look into this later.
                      ooom416354 @yawns
                      @yawns yes that’s the local station to my house, CLP. The morning ride is CLP to NYK then reverse in the afternoon. It should show the closest train departures and if there’s a delay so this morning would make sense (there were no delays today that I know of). So when I test I would just set a delay of like 8 minutes to see if anything showed up.
                      • yawnsY Offline
                        @ooom416354
                        Do you know of a list of all stations with their LOC code for api requests? They have a list of stations, but I can’t find the codes
