    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 400.5k Views 23 Watching
      joanaz @zman3
      @zman3 From AWS IoT, the instructions are in the readme in my repo. You also need to install my Alexa skill, by following the instructions in that repo.
      • Z
        zman3
        I have those installed still not seeing where i would get a host to put in there .
        if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
        17:21:45
        START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
        17:21:45
        Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
        17:21:45
        END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
        17:21:45
        REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
        17:21:45
        START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
        17:21:45
        Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
        17:21:45
        END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
        17:21:45
        REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
        • Z
          zman3
          so another thing in your skill code theres
          var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
            joanaz
              Journeytojah
              I can’t get the module to work, I get this error:
              { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
                  at errnoException (dns.js:28:10)
                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
                code: 'ENOTFOUND',
                errno: 'ENOTFOUND',
                syscall: 'getaddrinfo',
                hostname: 'data.iot.us-east-1.amazonaws.com',
                host: 'data.iot.us-east-1.amazonaws.com',
                port: 8883 }
              • L
                lucallmon
                @joanaz I really want to get excited about this but the install info is confusing at best. Could you please post a video demo of how it’s working currently and a more step-by-step installation guide? This sound like exactly what I’m looking for, but… I just don’t need more info.
                  joanaz
                  I’ve updated my readmes and code, you can do a git pull to get the latest files.
                  • L
                    lucallmon @joanaz
                    @joanaz I have AlexaPi working great right now. I’m a bit reluctant to stop it and try something else right now. Can you post a video of how it’s currently working?
                      Journeytojah
                      Okay, i will try again with the new instructions.
                      Do you have any advice regarding names for the certs or other names that would need changing?
                        joanaz @lucallmon
                        @lucallmon Where do I say you have to use something else? You definitely need AlexaPi to get it working.
                          joanaz @Journeytojah
                          @Journeytojah I think names do not matter, but make sure the names in MirrorMirror.js match with your certs. I called my AWS IoT Device “MagicMirror”.
                            Journeytojah @joanaz
                            @joanaz Okay, thanks.
                            Do you have any idea why i got that error? The function runs in lambda when testing but in the logs i see that application ID is missing.
                            I made sure to put my app ID in the js script and update the lambda function.
                            It would get an error on 3s timeout so i set it to 15.
                            Ill try setting it up from scratch again and let you know how it goes. Thanks!
                            • Z
                              zman3
                              So i have to have alexapi?
                              Because I’m running this
                              https://github.com/alexa/alexa-avs-sample-app
                              Which works great you said earlier that it should work with that. Do I need both
                                @Journeytojah do you still have the same error? I thought you got it running.
                                  joanaz @zman3
                                  @zman3 no you just need one Alexa app running. The Alexa sample app is perfectly fine.
                                  • Z
                                    zman3
                                    So my orginal error was when I said Alex on the wall she would say there was a problem with the skill, I redid the version right before you added YouTube now when I say alexa on the wall it dings then freezes and I have to reboot the raspberry to get her to work again. I did Amazon’s hello world skill example and that one works fine. I’ll try your newest version again tonight after work.
                                      @joanaz I’m cloning my SD card because i ran out of free space installing AlexaPi last night.
                                      Will start fresh and let you know if it works.
                                      • L
                                        lucallmon
                                        Setting up the AWS IoT service… what support plan to choose? Basic is free right? I’m not paying $30 for developer. Is this even required?
                                        J J 2 Replies Last reply Reply Quote 0
                                          joanaz @lucallmon
                                          @lucallmon yes you must setup an AWS IoT device, it should be free, I don’t know where you are seeing basic or developer whatever.
                                          You should see something like this
                                            Journeytojah @lucallmon
                                            @lucallmon afaik you get 12 months for free, you just need to use a credit card to register, and they “use” 1$ to confirm its your account, kinda like PayPal does.
                                            • 10
                                            • 2 / 10
