    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.9k Views 23 Watching
    • zman3Z
      zman3
      well i guess one thing i didnt do is in your directions it says
      open MirrorMirror.js, replace the keyPath, certPath, and host to your own
      where am I getting the host information from?
      lucallmonL J 2 Replies Last reply
      • lucallmonL
        lucallmon @zman3
        @zman3 from the Lambda site maybe?
          joanaz @zman3
          @zman3 From AWS IoT, the instructions are in the readme in my repo. You also need to install my Alexa skill, by following the instructions in that repo.
          • zman3Z
            zman3
            I have those installed still not seeing where i would get a host to put in there .
            if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
            17:21:45
            START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
            17:21:45
            Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
            17:21:45
            END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
            17:21:45
            REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
            17:21:45
            START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
            17:21:45
            Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
            17:21:45
            END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
            17:21:45
            REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
            • zman3Z
              zman3
              so another thing in your skill code theres
              var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
                joanaz
                  Journeytojah
                  I can’t get the module to work, I get this error:
                  { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
                      at errnoException (dns.js:28:10)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
                    code: 'ENOTFOUND',
                    errno: 'ENOTFOUND',
                    syscall: 'getaddrinfo',
                    hostname: 'data.iot.us-east-1.amazonaws.com',
                    host: 'data.iot.us-east-1.amazonaws.com',
                    port: 8883 }
                  • lucallmonL
                    lucallmon
                    @joanaz I really want to get excited about this but the install info is confusing at best. Could you please post a video demo of how it’s working currently and a more step-by-step installation guide? This sound like exactly what I’m looking for, but… I just don’t need more info.
                      joanaz
                      I’ve updated my readmes and code, you can do a git pull to get the latest files.
                      lucallmonL 1 Reply Last reply
                      • lucallmonL
                        lucallmon @joanaz
                        @joanaz I have AlexaPi working great right now. I’m a bit reluctant to stop it and try something else right now. Can you post a video of how it’s currently working?
                        J 1 Reply Last reply
                          Journeytojah
                          Okay, i will try again with the new instructions.
                          Do you have any advice regarding names for the certs or other names that would need changing?
                            joanaz @lucallmon
                            @lucallmon Where do I say you have to use something else? You definitely need AlexaPi to get it working.
                              joanaz @Journeytojah
                              @Journeytojah I think names do not matter, but make sure the names in MirrorMirror.js match with your certs. I called my AWS IoT Device “MagicMirror”.
                                Journeytojah @joanaz
                                @joanaz Okay, thanks.
                                Do you have any idea why i got that error? The function runs in lambda when testing but in the logs i see that application ID is missing.
                                I made sure to put my app ID in the js script and update the lambda function.
                                It would get an error on 3s timeout so i set it to 15.
                                Ill try setting it up from scratch again and let you know how it goes. Thanks!
                                • zman3Z
                                  zman3
                                  So i have to have alexapi?
                                  Because I’m running this
                                  https://github.com/alexa/alexa-avs-sample-app
                                  Which works great you said earlier that it should work with that. Do I need both
                                    @Journeytojah do you still have the same error? I thought you got it running.
                                      joanaz @zman3
                                      @zman3 no you just need one Alexa app running. The Alexa sample app is perfectly fine.
                                      • zman3Z
                                        zman3
                                        So my orginal error was when I said Alex on the wall she would say there was a problem with the skill, I redid the version right before you added YouTube now when I say alexa on the wall it dings then freezes and I have to reboot the raspberry to get her to work again. I did Amazon’s hello world skill example and that one works fine. I’ll try your newest version again tonight after work.
                                          @joanaz I’m cloning my SD card because i ran out of free space installing AlexaPi last night.
                                          Will start fresh and let you know if it works.
                                          • lucallmonL
                                            lucallmon
                                            Setting up the AWS IoT service… what support plan to choose? Basic is free right? I’m not paying $30 for developer. Is this even required?
                                            J J 2 Replies Last reply
                                            • 10
                                            • 2 / 10
