    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
      joanaz @schlachtkreuzer6
      @schlachtkreuzer6 yes, but you need to install my Alexa skill
        joanaz @lucallmon
        @lucallmon I changed my Alexa wake word to “Mirror mirror” instead of “Alexa”, and my Skill’s invocation name is “on the wall”, but you can change them to whatever you want. It displays the text you say after the command word “say”. Look at my sample utterances for the commands you can use. It doesn’t show text for other Alexa skills or Alexa general commands. But you can change my Alexa skill to do that.
        • zman3Z
          zman3
          welll I just cannot seem to get this to work she always says she doesnt understand I think it tried just once because she said there was a error with the skill that one time. :/
          any ideas of what i can look for?
          • zman3Z
            zman3
            well i guess one thing i didnt do is in your directions it says
            open MirrorMirror.js, replace the keyPath, certPath, and host to your own
            where am I getting the host information from?
            lucallmonL J 2 Replies Last reply
            • lucallmonL
              lucallmon @zman3
              @zman3 from the Lambda site maybe?
                joanaz @zman3
                @zman3 From AWS IoT, the instructions are in the readme in my repo. You also need to install my Alexa skill, by following the instructions in that repo.
                • zman3Z
                  zman3
                  I have those installed still not seeing where i would get a host to put in there .
                  if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
                  17:21:45
                  START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
                  17:21:45
                  Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
                  17:21:45
                  END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
                  17:21:45
                  REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                  17:21:45
                  START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
                  17:21:45
                  Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
                  17:21:45
                  END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
                  17:21:45
                  REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
                  • zman3Z
                    zman3
                    so another thing in your skill code theres
                    var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
                      joanaz
                        Journeytojah
                        I can’t get the module to work, I get this error:
                        { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
                            at errnoException (dns.js:28:10)
                            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
                          code: 'ENOTFOUND',
                          errno: 'ENOTFOUND',
                          syscall: 'getaddrinfo',
                          hostname: 'data.iot.us-east-1.amazonaws.com',
                          host: 'data.iot.us-east-1.amazonaws.com',
                          port: 8883 }
                        • lucallmonL
                          lucallmon
                          @joanaz I really want to get excited about this but the install info is confusing at best. Could you please post a video demo of how it’s working currently and a more step-by-step installation guide? This sound like exactly what I’m looking for, but… I just don’t need more info.
                            joanaz
                            I’ve updated my readmes and code, you can do a git pull to get the latest files.
                            lucallmonL 1 Reply Last reply
                            • lucallmonL
                              lucallmon @joanaz
                              @joanaz I have AlexaPi working great right now. I’m a bit reluctant to stop it and try something else right now. Can you post a video of how it’s currently working?
                              J 1 Reply Last reply
                                Journeytojah
                                Okay, i will try again with the new instructions.
                                Do you have any advice regarding names for the certs or other names that would need changing?
                                  joanaz @lucallmon
                                  @lucallmon Where do I say you have to use something else? You definitely need AlexaPi to get it working.
                                    joanaz @Journeytojah
                                    @Journeytojah I think names do not matter, but make sure the names in MirrorMirror.js match with your certs. I called my AWS IoT Device “MagicMirror”.
                                      Journeytojah @joanaz
                                      @joanaz Okay, thanks.
                                      Do you have any idea why i got that error? The function runs in lambda when testing but in the logs i see that application ID is missing.
                                      I made sure to put my app ID in the js script and update the lambda function.
                                      It would get an error on 3s timeout so i set it to 15.
                                      Ill try setting it up from scratch again and let you know how it goes. Thanks!
                                      • zman3Z
                                        zman3
                                        So i have to have alexapi?
                                        Because I’m running this
                                        https://github.com/alexa/alexa-avs-sample-app
                                        Which works great you said earlier that it should work with that. Do I need both
                                          @Journeytojah do you still have the same error? I thought you got it running.
                                            joanaz @zman3
                                            @zman3 no you just need one Alexa app running. The Alexa sample app is perfectly fine.
                                            • 10
                                            • 2 / 10
