    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
    • zman3Z
      zman3
      I have those installed still not seeing where i would get a host to put in there .
      if I say alexa, on the wall. she says theres a problem with the requested skills respones the lambda cloud watch error shows the following
      17:21:45
      START RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Version: $LATEST
      17:21:45
      Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.
      17:21:45
      END RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d
      17:21:45
      REPORT RequestId: 931bbc00-e710-11e6-b7a7-b3bf469e814d Duration: 36.31 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
      17:21:45
      START RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Version: $LATEST
      17:21:45
      Unable to import module 'index': Error at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/MirrorMirror.js:1:76) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (modul
      17:21:45
      END RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261
      17:21:45
      REPORT RequestId: 9342f35b-e710-11e6-872c-f9454aa4f261 Duration: 0.61 ms Billed Duration: 100 ms Memory Size: 128 MB Max Memory Used: 17 MB
      • zman3Z
        zman3
        so another thing in your skill code theres
        var MirrorMirror = require(‘./MirrorMirror’); does that expect the MMM-MirrorMirrorOnTheWall module folder to be called MirrorMirror because mines call MMM-MirrorMirrorOnTheWall
          joanaz
            Journeytojah
            I can’t get the module to work, I get this error:
            { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
                at errnoException (dns.js:28:10)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
              code: 'ENOTFOUND',
              errno: 'ENOTFOUND',
              syscall: 'getaddrinfo',
              hostname: 'data.iot.us-east-1.amazonaws.com',
              host: 'data.iot.us-east-1.amazonaws.com',
              port: 8883 }
            • lucallmonL
              lucallmon
              @joanaz I really want to get excited about this but the install info is confusing at best. Could you please post a video demo of how it’s working currently and a more step-by-step installation guide? This sound like exactly what I’m looking for, but… I just don’t need more info.
                joanaz
                I’ve updated my readmes and code, you can do a git pull to get the latest files.
                lucallmonL 1 Reply Last reply
                • lucallmonL
                  lucallmon @joanaz
                  @joanaz I have AlexaPi working great right now. I’m a bit reluctant to stop it and try something else right now. Can you post a video of how it’s currently working?
                  J 1 Reply Last reply
                    Journeytojah
                    Okay, i will try again with the new instructions.
                    Do you have any advice regarding names for the certs or other names that would need changing?
                      joanaz @lucallmon
                      @lucallmon Where do I say you have to use something else? You definitely need AlexaPi to get it working.
                        joanaz @Journeytojah
                        @Journeytojah I think names do not matter, but make sure the names in MirrorMirror.js match with your certs. I called my AWS IoT Device “MagicMirror”.
                          Journeytojah @joanaz
                          @joanaz Okay, thanks.
                          Do you have any idea why i got that error? The function runs in lambda when testing but in the logs i see that application ID is missing.
                          I made sure to put my app ID in the js script and update the lambda function.
                          It would get an error on 3s timeout so i set it to 15.
                          Ill try setting it up from scratch again and let you know how it goes. Thanks!
                          • zman3Z
                            zman3
                            So i have to have alexapi?
                            Because I’m running this
                            https://github.com/alexa/alexa-avs-sample-app
                            Which works great you said earlier that it should work with that. Do I need both
                              @Journeytojah do you still have the same error? I thought you got it running.
                                joanaz @zman3
                                @zman3 no you just need one Alexa app running. The Alexa sample app is perfectly fine.
                                • zman3Z
                                  zman3
                                  So my orginal error was when I said Alex on the wall she would say there was a problem with the skill, I redid the version right before you added YouTube now when I say alexa on the wall it dings then freezes and I have to reboot the raspberry to get her to work again. I did Amazon’s hello world skill example and that one works fine. I’ll try your newest version again tonight after work.
                                    @joanaz I’m cloning my SD card because i ran out of free space installing AlexaPi last night.
                                    Will start fresh and let you know if it works.
                                    • lucallmonL
                                      lucallmon
                                      Setting up the AWS IoT service… what support plan to choose? Basic is free right? I’m not paying $30 for developer. Is this even required?
                                      J J 2 Replies Last reply
                                        joanaz @lucallmon
                                        @lucallmon yes you must setup an AWS IoT device, it should be free, I don’t know where you are seeing basic or developer whatever.
                                        You should see something like this
                                          Journeytojah @lucallmon
                                          @lucallmon afaik you get 12 months for free, you just need to use a credit card to register, and they “use” 1$ to confirm its your account, kinda like PayPal does.
                                            @joanaz Now i get this error for the Lambda function… tried 3/10/15 seconds.
                                              "errorMessage": "2017-02-04T20:11:41.538Z 1b87c832-eb16-11e6-a281-33f14ad1f615 Task timed out after 15.00 seconds",
                                              "errorType": "Error"
                                            This is the error in the Amazon Skill :
                                            Lambda Response
                                            The remote endpoint could not be called, or the response it returned was invalid.
                                            Cloud watch log
                                            20:46:58
                                            START RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998 Version: 1
                                            20:46:58
                                            Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object.<anonymous> (/var/task/index.js:24:22) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
                                            20:46:58
                                            2017-02-04T20:46:58.805Z	11e4a442-eb1b-11e6-a7b3-3361f5194998	connect
                                            20:47:13
                                            END RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998
                                            20:47:13
                                            REPORT RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998	Duration: 15003.64 ms	Billed Duration: 15000 ms Memory Size: 128 MB	Max Memory Used: 26 MB
                                            20:47:13
                                            2017-02-04T20:47:13.618Z 11e4a442-eb1b-11e6-a7b3-3361f5194998 Task timed out after 15.00 seconds Error
                                            at Function.Module._load (module.js:300:12)
                                            • 10
                                            • 2 / 10
