    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.9k Views 23 Watching
      joanaz
        Journeytojah
        I can’t get the module to work, I get this error:
        { Error: getaddrinfo ENOTFOUND data.iot.us-east-1.amazonaws.com data.iot.us-east-1.amazonaws.com:8883
            at errnoException (dns.js:28:10)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
          code: 'ENOTFOUND',
          errno: 'ENOTFOUND',
          syscall: 'getaddrinfo',
          hostname: 'data.iot.us-east-1.amazonaws.com',
          host: 'data.iot.us-east-1.amazonaws.com',
          port: 8883 }
        • lucallmonL
          lucallmon
          @joanaz I really want to get excited about this but the install info is confusing at best. Could you please post a video demo of how it’s working currently and a more step-by-step installation guide? This sound like exactly what I’m looking for, but… I just don’t need more info.
            joanaz
            I’ve updated my readmes and code, you can do a git pull to get the latest files.
            lucallmonL 1 Reply Last reply
            • lucallmonL
              lucallmon @joanaz
              @joanaz I have AlexaPi working great right now. I’m a bit reluctant to stop it and try something else right now. Can you post a video of how it’s currently working?
              J 1 Reply Last reply
                Journeytojah
                Okay, i will try again with the new instructions.
                Do you have any advice regarding names for the certs or other names that would need changing?
                  joanaz @lucallmon
                  @lucallmon Where do I say you have to use something else? You definitely need AlexaPi to get it working.
                    joanaz @Journeytojah
                    @Journeytojah I think names do not matter, but make sure the names in MirrorMirror.js match with your certs. I called my AWS IoT Device “MagicMirror”.
                      Journeytojah @joanaz
                      @joanaz Okay, thanks.
                      Do you have any idea why i got that error? The function runs in lambda when testing but in the logs i see that application ID is missing.
                      I made sure to put my app ID in the js script and update the lambda function.
                      It would get an error on 3s timeout so i set it to 15.
                      Ill try setting it up from scratch again and let you know how it goes. Thanks!
                      • zman3Z
                        zman3
                        So i have to have alexapi?
                        Because I’m running this
                        https://github.com/alexa/alexa-avs-sample-app
                        Which works great you said earlier that it should work with that. Do I need both
                          @Journeytojah do you still have the same error? I thought you got it running.
                            joanaz @zman3
                            @zman3 no you just need one Alexa app running. The Alexa sample app is perfectly fine.
                            • zman3Z
                              zman3
                              So my orginal error was when I said Alex on the wall she would say there was a problem with the skill, I redid the version right before you added YouTube now when I say alexa on the wall it dings then freezes and I have to reboot the raspberry to get her to work again. I did Amazon’s hello world skill example and that one works fine. I’ll try your newest version again tonight after work.
                                @joanaz I’m cloning my SD card because i ran out of free space installing AlexaPi last night.
                                Will start fresh and let you know if it works.
                                • lucallmonL
                                  lucallmon
                                  Setting up the AWS IoT service… what support plan to choose? Basic is free right? I’m not paying $30 for developer. Is this even required?
                                  J J 2 Replies Last reply
                                    joanaz @lucallmon
                                    @lucallmon yes you must setup an AWS IoT device, it should be free, I don’t know where you are seeing basic or developer whatever.
                                    You should see something like this
                                      Journeytojah @lucallmon
                                      @lucallmon afaik you get 12 months for free, you just need to use a credit card to register, and they “use” 1$ to confirm its your account, kinda like PayPal does.
                                        @joanaz Now i get this error for the Lambda function… tried 3/10/15 seconds.
                                          "errorMessage": "2017-02-04T20:11:41.538Z 1b87c832-eb16-11e6-a281-33f14ad1f615 Task timed out after 15.00 seconds",
                                          "errorType": "Error"
                                        This is the error in the Amazon Skill :
                                        Lambda Response
                                        The remote endpoint could not be called, or the response it returned was invalid.
                                        Cloud watch log
                                        20:46:58
                                        START RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998 Version: 1
                                        20:46:58
                                        Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object.<anonymous> (/var/task/index.js:24:22) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
                                        20:46:58
                                        2017-02-04T20:46:58.805Z	11e4a442-eb1b-11e6-a7b3-3361f5194998	connect
                                        20:47:13
                                        END RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998
                                        20:47:13
                                        REPORT RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998	Duration: 15003.64 ms	Billed Duration: 15000 ms Memory Size: 128 MB	Max Memory Used: 26 MB
                                        20:47:13
                                        2017-02-04T20:47:13.618Z 11e4a442-eb1b-11e6-a7b3-3361f5194998 Task timed out after 15.00 seconds Error
                                        at Module.load (module.js:343:32)
                                        at Function.Module._load (module.js:300:12)
                                          Journeytojah
                                          By the way, I was unable to upload the .zip from the RPi, it would just say “must not exist”, so i did it from my laptop, could this be the issue?
                                          I ran the .sh script and downloaded dependencies on the raspberry, archived the src folder contents and used my laptop to upload them.
                                            @Journeytojah it usually happens when you zip the src folder, you have to go inside the src folder, and select all the files and folder, including node_modules, and certs, and compress them to a zip file.
                                            J G 2 Replies Last reply
                                            • 10
                                            • 2 / 10
