Solved Monthly Calendar View
Oh I suppose …
Keep in mind that the styling can be changed by the user to whatever they want it to look like. The sky isn’t the limit … it’s their imagination. :)
@KirAsh4 I understand. But I think this is the best default style … 😈
It won’t be the “default” style, but the config will set it as'default'
. The reason is because the actual'styleDefault.css'
file needs to be clean and not have anything in it other than setting the proper margin, padding, and table/cell views for the calendar and it gets included always. Custom CSS files are pulled in on top of that. That way, the user doesn’t need to set any of that themselves, but rather just over ride what they want with their own styles. So I can have a'styleMichMich'
[*] that I can set as the default style to have today highlighted in a white box.[*] actual name to be determined still …Never mind, went a slightly different route …
@KirAsh4 Don’t you just love it when you type loads of useless text online … LOL.
I left it all for posterity. :)
Ok all, for all intents and purposes, the current state of the monthly view calendar is done. While I do plan on incorporating more features in it, there’s really nothing that is preventing me from releasing it … except maybe a proper name for the module. And the reason I say that is because of the future plans I have. I could easily call it ‘monthlycalendar’, however when I roll in the weekly view as well, that makes the name not accurate anymore. So yeah … bit of a conundrum. Either I will split out the weekly one into a separate module all together, or I will end up naming this ‘that-calendar-thats-not-the-default-but-has-other-features-in-it’ … you get what I’m saying here.
Time to ponder some things I guess …
name it “AliceInCalendarLand.module”
I have solved the problem.
Spent the day wrangling code. Apparently I have a lot of ‘sumptinks’ coming up! :)
This is just raw data processing. Stuff comes in, gets processed, and placed in the array which I then fetch. There’s no formatting in the code yet. Just don’t ask. -
I really like that running week of events!!
Much better than the current calendar list
Great work!
Thanks. It’s still in it’s very early stages. A lot can and will change still.
