sample config and clock
7 Posts 2 Posters 5.1k Views 2 Watching
  • E Offline
    emos
    Hello, I came a cross a topic on this forum saying that all you need to remove the second from the clock is
    displaySeconds: false,
    I stared out with the sample.config, added the info for seconds. When i start up the mirror now it just says i need to create a config. wtf?
    This is the full config
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config = {
            port: 8080,
            ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120"],
            language: 'nb',
            timeFormat: 24,
            units: 'metric',
                            module: 'alert',
                            module: "updatenotification",
                            position: "top_bar"
                            module: 'clock',
                            position: 'top_left'
                            module: 'calendar',
                            header: 'US Holidays',
                            position: 'top_left',
                                                    symbol: 'calendar-check-o ',
                            module: 'compliments',
                            position: 'lower_third'
                            module: 'currentweather',
                            position: 'top_right',
                                    locationID: '',  //ID from http://www.openweathermap.org
                                    appid: 'YOUR_OPENWEATHER_API_KEY'
                            module: 'weatherforecast',
                            header: 'Weather Forecast',
                                    locationID: '5128581',  //ID from http://www.openweathermap.org
                            module: 'newsfeed',
                            position: 'bottom_bar',
                                    feeds: [
                                                    title: "New York Times",
                                    showSourceTitle: true,
                                    showPublishDate: true
    S 1 Reply Last reply Feb 8, 2017, 3:55 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @emos
      @emos you forgot an , behind the position
        module: 'clock',
      E 1 Reply Last reply Feb 8, 2017, 4:02 PM Reply Quote 1
      • E Offline
        emos @strawberry 3.141
        @strawberry-3.141
        Thank you, it did the trick :)
        I see that you have removed the ‘,’ behind ‘false’. The last argument, or string, is that the only one that’s not suppose to have an ‘,’ at the end?
        S 1 Reply Last reply Feb 8, 2017, 4:12 PM Reply Quote 0
          @emos that’s correct it’s like writing a list you seperate them by comma except the last item
          E 1 Reply Last reply Feb 8, 2017, 4:47 PM Reply Quote 1
          • E Offline
            @strawberry-3.141 Thank you so much, that helped me alot :thumbsup:
            • E Offline
              emos
              one more question regarding the last ‘,’
              Does the same rule apply with the ‘[’ and ‘]’?
                                      position: 'lower_third',
                                              compliments: {
                                                      day_sunny: [
                                                              'Today is a sunny day',
                                                              'It\'s a beautiful day',
                                                      snow: [
                                                              'Snowball battle!',
                                                      rain: [
                                                              'Don\'t forget your umbrella'
              Or does each square bracket count as individual values. So if there’s only one you don’t need to close it?
              S 1 Reply Last reply Feb 8, 2017, 5:08 PM Reply Quote 0
                @emos you have to seperate each level with commas things day_sunny, snow, rain has to be seperated with commas
                thats what inside the square brackets has to be seperated by commasas well
