    Calendar Heading Changes
    22 Posts 5 Posters 17.5k Views 4 Watching
    • O
      ooom416354 @strawberry 3.141
      @strawberry-3.141 so add the hello world module under the clock in the config.js and code it up to add the color coded “legend”, right?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @ooom416354
        @ooom416354 put it right above the calendar module in the config with the same position
                module: 'helloworld',
                position: 'top_left',
                    text: '<div>John</div><div>Jane</div>'
        EDIT it wont let me do adding styling add style=“color: blue;” for John example behind the open div tag
        O B 3 Replies Last reply Reply Quote 0
        • O
          @strawberry-3.141 perfect, I will do that. thanks again!
          • O
            @strawberry-3.141 I see that, is it possible to just add 5 separate helloworld modules each stacked on top of each other, each with a different color?
            strawberry 3.141S B 2 Replies Last reply Reply Quote 0
            • strawberry 3.141S
              @ooom416354 you could do that but each module has a margin around which takes up more space than adding all in one
              • O
                @strawberry-3.141 Yea, I saw that, I guess I could modify the module itself to shrink the margin but that would cause a problem with pulling latest updates, right?
                  billp100 @strawberry 3.141
                  @strawberry-3.141 I am said friend that @ooom416354 is helping. I appreciate the help, I will be able to do some testing of my own tonight and tomorrow with the impending storm coming.
                  My ideal setup is to have the 5 members in my family share 1 calendar module, each using a separate icon. For my wife and I it’s fairly easy, because there is a male icon and female. For the kids, there is no way do differentiate them.
                  My other question would be, rather than using a font-awesome symbol, could I just use a letter or name in place of that?
                    broberg Project Sponsor @ooom416354
                    @ooom416354
                    If you want it all in a row above the calender then use < span >, < div > usually stacks on top of each other.
                    < span style="color: blue">Dude, < /span>
                    < span style="color: pink">Dudette, < /span>
                    < span style="color: green">Tiny dude, < /span>
                    < span style="color: yellow">Tiny dudette, < /span>
                    < span style="color: purple">Tiniest thingymajigg< /span>
                    That should give you “Dude, Dudette, Tiny dude, Tiny dudette, Tiniest thingymajigg”
                    O 1 Reply Last reply Reply Quote 1
                    • O
                      ooom416354 @broberg
                      @broberg Yes, that makes sense but would that be added as part of the helloworld module which @strawberry-3-141 mentioned to use above?
                        @ooom416354 Yes, if you put that inside the text: ' ... ' it should work nicely,
                        But since the module doesn’t have any width constraints it could stretch the top_left area, but that depends on number of characters and font-size ofc.
                        • O
                          ooom416354 @broberg
                          @broberg perfect, got it, thanks.
                          @billp100 this should work but may need some formatting with the margins to get it to look good.
                          • strawberry 3.141S
                            @ooom416354 you can also add <br /> to force a line break where you want
                              billp100
                              Guys,
                              Thanks for the help, using your suggestions I was able to actually accomplish what I was looking for in the header of the calendar module itself.
