    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.6k Views 47 Watching
      SebTota @Mar
      @Mar I’ll send you the link to the mega file download. You will have to unzip it and write the ISO file onto your SD card. I also have a version that has amazon Alexa built in but that takes a little bit of setup.
        Mar @SebTota
        @SebTota Thanks so much!!! I’ll download it over night and try it in the morning and get back to you. Hopefully there is no difference between pi zeros?
          SebTota @Mar
          @Mar I have shared it with someone else already and it worked completely fine. I have PM you the download link.
            Mar @SebTota
            @SebTota Thats good to know, downloading now but its quite slow on mega for some reason. Will report back in the morning as its 2am here on a work night ;( though you saved me another night of hopeless tinkering lol
              Mar @SebTota
              @SebTota Thanks somuch Seb everything works amazing!! I owe you a beer!
                SebTota @Mar
                @Mar Not quite old enough to take you up on that offer yet. :) Really glad to hear that its working. Like I said if anyone needs the image of just the MagicMirror, MagicMirror with Alexa, and hopefully soon MagicMirror with Jasper AI just let me know and I can send you a link to my download.
                  Mar @SebTota
                  @SebTota Great job with all these Seb! Suppose I’ll drink your beer for you right now ;) I’d love to give the AI one a chance once everything is up and running.
                    bmarofsky @Kobie
                    • O
                      ottobot
                      sorry for asking something that I can google, but I’m on lunch and trying to be quick. after I have everything up and running can I:
                      dd if=/dev/sdf of=/functioning_mm_image.iso
                      that way I only have to fiddle with a few config options for the rest of the mirrors that I’m making?
                      • FallandeGubbeF
                        FallandeGubbe @Wieber
                        @Wieber Thanks a lot for this tutorial! Now I have my Raspberry Pi 1 up and running with Magic mirror. … with some inspiration from https://maxkorlaar.com/post/?i=43&lang=en
                        I also added the functionality to have the monitor to shut down when no one is using the mirror i.e. during night and when no one is at home! :)
                          Mitchfarino Module Developer @SebTota
                          @SebTota
                          Do you still have the image you can share? I’m struggling to follow the guide here…
                          • A
                            ArkantosArk
                            @SebTota
                            I tried to follow your guide (which is really well explained) but for some reason I´m having a few errors at the last step…Could you share your “Magic Mirror” only image with me please?
                              braik @Mar
                              @Mar
                              Hi there,
                              I had the same problem and the I have realized that node serveronly was not launched.
                              The problem is that the command :
                              cd ~/MagicMirror was not working, so I have changed it for
                              cd /home/pi/MagicMirror
                              and that’s it.
                              Hope this can help
                                bmarofsky
                                OK, so i am trying this again on a Pi Zero W
                                I got stuck on Step 4
                                so I ran:
                                sudo apt-get remove nodered
                                sudo apt-get remove nodejs nodejs-legacy
                                sudo apt-get remove npm   # if you installed npm
                                wget http://node-arm.herokuapp.com/node_archive_armhf.deb
                                sudo dpkg -i node_archive_armhf.deb
                                sudo apt-get install -y build-essential python-dev npm
                                then again on Step 5 i got a ton of these:
                                pi@raspberrypi:~/MagicMirror $ sudo npm install
                                npm WARN engine feedme@1.0.0: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                npm WARN engine request@2.81.0: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                npm WARN engine eslint@3.17.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                Are the updated steps or an Image that can be downloaded?
                                • H
                                  Hawking @bmarofsky
                                  @bmarofsky
                                  I’m also trying to install Magic Mirror on a Pi Zero W.
                                  I think one reason for the problems might be that as far as I can tell
                                  sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
                                  sudo dpkg -i node_latest_armhf.deb
                                  got me node v4.2.1 which is quite outdated (the regular installer of MM2 updates nodes if the version of node is below 5.1.0).
                                  I therefore tried to install a more recent version of node following the commands here
                                  https://github.com/sdesalas/node-pi-zero
                                  However, the compilation of Magic Mirror worked neither with node 7.7.1 nor with node 6.9.1.
                                  Before I go into details, did anybody got Magic Mirror working on Raspberry Pi Zero W?
                                  Which node version (and npm version) did you use and how you he install it? Which browser did you use (I read that Midori has some problems)?
                                    Mitchfarino Module Developer @ArkantosArk
                                    @ArkantosArk
                                    This is @SebTota 's link https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
                                    • H
                                      Hawking
                                      I could fix my issue with the blank screen by simply doing
                                      cd ~/MagicMirror/vendor
                                      npm install
                                      Then it seem to work (even with the node v 4.2.1). Nevertheless I will try to update to a more recent version of node, just to avoid other problems that are likely to exist in this old node version.
                                      • L
                                        longod
                                        Hi! I have followed this guide step by step and so precisely, however I am still getting an error when I type in DISPLAY=:0 npm start through SSH. This is the output:
                                        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                        > magicmirror@2.1.1 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
                                        npm ERR! Linux 4.4.50+
                                        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                                        npm ERR! node v4.2.1
                                        npm ERR! npm  v2.14.7
                                        npm ERR! file sh
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! errno ENOENT
                                        npm ERR! syscall spawn
                                        npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
                                        npm ERR! spawn ENOENT
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                                        npm ERR! This is most likely a problem with the magicmirror package,
                                        npm ERR! not with npm itself.
                                        npm ERR!     sh run-start.sh
                                        npm ERR! You can get their info via:
                                        npm ERR!     npm owner ls magicmirror
                                        npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                        Any help on what to do to solve this would be greatly appreciated!
                                        • H
                                          Hawking @longod
                                          @longod
                                          I didn’t try your way of starting the MagicMirror. However, is there a reason that you don’t use the commands in the guide to start the MagicMirror (using the start.sh and startMidori scripts)? There is no DISPLAY=:0 npm start mentioned in this thread.
                                            RV @randombullet
                                            @randombullet i followed those steps but i got a error it says that he cannot connect with localhost: 8080 webpage?
                                            • 10
                                            • 11
                                            • 4 / 11
