    Calendar modification
    35 Posts 15 Posters 49.1k Views 12 Watching
    • G
      garnett @KirAsh4
      @KirAsh4
      uh yes, sorry! thats right. i was confused by the message from the google calendar.
      works with private and public ;)
      • A
        aarinsingh
        Can somebody please post their config file with the maximumNumberOfDays line inserted. I’m not sure what I’m doing wrong but everytime I try to adjust this I crash my config file. Everything else is working perfect.
        • MichMichM
          MichMich
          @aarinsingh Could you copy paste your config including the maximumNumberOfDays (so I can try to find what you’re doing wrong). Don’t forget to remove sensitive data.
            brad
            Here is my info @aarinsingh , it doesn’t crash but it is also not limiting the number of days. From what I can see at a quick glance is that this was using a method that may have been replaced in the load process for this module, because it seems to only be using the default for this setting. I may follow to code later and see how this is loading and why my setting is being ignored.
            			module: 'calendar',
            			header: 'Events',
            			position: 'top_left',
            			maximumNumberOfDays: 7,
            						symbol: 'calendar-check-o ',
            						url: 'https://calendar.google.com/calendar/ical/your-info'
            Note from admin: Please use Markdown on code snippets!
            • W
              Wilco89
              Put it after config: { and it will work
              • MichMichM
                MichMich
                maximumNumberOfDays should be part of the config object:
                			module: 'calendar',
                			header: 'Events',
                  brad
                  That makes perfect sense. :) sorry didn’t catch that…
                    MagicCrumps1 @KirAsh4
                    @KirAsh4 Weird. I had to make mine public or else the dashboard wont be able to display saying “No Events”
                    • K
                      KirAsh4 Moderator @MagicCrumps1
                      @MagicCrumps1, perhaps you were using the wrong URL? There’s both a public and a private one. If you use the public URL, then you must also set your calendar to public view. But the private URL has the authentication key in it. No need to make the calendar public.
                        @KirAsh4 Of course that worked. Thanks for the silver bullet
                        • 0
                          00conman
                          Hey guys sorry I’ve been away so I haven’t seen all these posts but I would recommend putting the calendar in monthly mode so events to disappear prematurely.
                          K 1 Reply Last reply Reply Quote -1
                          • K
                            KirAsh4 Moderator @00conman
                            @00conman, care to explain what you mean?
                            0 1 Reply Last reply Reply Quote 0
                            • 0
                              00conman @KirAsh4
                              @KirAsh4 I keep my calendar in month mode because it makes sure that events don’t delete halfway through a day and when in month mode it prevents a glitch from occurring. In that glitch on the mirror itself events will be assigned random times, in my case the newest event would be assigned 4:00 am and then each event after that would increase by the hour to 5:00 and so on. There is also an occurrence that events will randomly delete themselves from the actual mirror, not the online calendar, so putting this in month mode will cause them to remove themselves, or stop displaying, on the mirror at 12:00 o’clock midnight the day that they were assigned. It is certainly not necessary but I would do it because it take just a few seconds.
                              • 0
                                00conman
                                To anyone wondering how to switch the calendar to month mode here is a few images.
                                Main calendar:
                                https://gyazo.com/52f994a4b33968c8a0ebe2effe349179
                                And where you switch it:
                                https://gyazo.com/81e42213091d63b75e4bb9798e01d4ac
                                Please note that it might not work the first time in that case either try again and reload the page or try again and go to settings and save the calendar.
                                • K
                                  KirAsh4 Moderator
                                  That’s something that is outside of the scope of MM itself. They don’t have anything to do with the MM calendar module itself. When you said to keep the calendar in monthly mode, my first reaction was, ‘Uh, the calendar doesn’t have a monthly view’, hence my request for clarification.
                                  It’s helpful to others who are using that specific service to host a calendar, and trying to incorporate it into MM, but you needed to specify what you were referring to.
                                  Thanks for the clarification.
                                  • A
                                    aarinsingh
                                    Wow, Thanks Guys.
                                    I took a couple days of from the project and hit the lake, so sorry for the slow replies.
                                    @MichMIch - That cured it, I had the maximunNumberOfDays Line to far down.
                                    I have a couple other questions but I won’t clutter up the calendar Module board with them.
                                      Plati
                                      How to get ICAL for a Facebook calendar:
                                      https://www.facebook.com/help/152652248136178/
                                      2 different ICAL for birthdays and upcoming events :)
                                      Useful config part: “maximumEntries: X”
                                      And holidays calendars for many countries: https://www.mozilla.org/en-US/projects/calendar/holidays/
                                        CCoates
                                        Anyone had any luck with Outlook 365 or Iphone calendars?
                                        L Y 2 Replies Last reply Reply Quote 0
                                        • L
                                          lolobyte @CCoates
                                          @CCoates
                                          iphone calendar is not a big problem.
                                          U must go to iCloud Calendar and make the calendar of your choice usable for public access.
                                          After that copy the link of your public calendar and insert this link into the config.js in your calendar module.
                                          restart your magicmirror
                                          • Y
                                            yawns Moderator @CCoates
                                            @CCoates said in Calendar modification:
                                            I use my outlook.com calendar without any problems
