    MMM-PiLights - Control a LPD8806 Led Strip on a Raspberry Pi
    17 Posts 7 Posters 16.9k Views 9 Watching
      jc21
      Specifically for MagicMirrors on a Raspberry Pi with a LPD8806 led strip, this module allows other modules to trigger light sequences or trigger from a http endpoint.
      github/jc21/MMM-PiLights
      • K Offline
        KirAsh4 Moderator
        May I suggest you add a section on how to actually connect the LED strips to the pi, which pins, etc.? Not everyone is as technical as some of us … :)
          jc21
          This guide should cover it. Although that is for older raspberry pi models but still worth a read.
          For raspberry pi 3 I’ve connected the pins [DI to 20] and [CI to 24] as labelled in this image.
          • K Offline
            KirAsh4 Moderator
            I’m referring to adding it to the repository README.md file.
            • K Offline
              KirAsh4 Moderator
              And technically speaking, the LPD8806 chipset requires 4 wires for input: VCC, GND, DATA_IN (DI), and CLOCK_IN (CI). On a Raspberry Pi 3, the SPI port is on pins:
              MOSI    P1-19  (Master Out Slave In)
              MISO    P1-21  (Master In Slave Out)
              SCLK    P1-23
              GND     P1-25
              CE0     P1-24
              CE1     P1-26
              For DATA_IN, you should use the MOSI (19) pin, and for CLOCK_IN, the SCLK (23) pin. Pins 24 and 26 are chip select pins if you happen to have several SPI slave devices and needed to select which one you’re addressing.
                jc21
                Ahh you are correct that is how I have it connected, I just had a dyslexic moment and named the opposing pins by accident :/
                  schmo90
                  Hy
                  i changed your module to work with the common W2801 Led Strips.
                  Now i wanted to add some new sequences.
                  I modified the switch case but everytime i will go to this sequence with the http request i get the answer, squence not found.
                  this.expressApp.use(bodyParser.urlencoded({extended: true}));
                      this.expressApp.get('/PiLights', (req, res) => {
                          console.error('[PiLights] Incoming:', req.query);
                          if (typeof req.query.sequence !== 'undefined') {
                              // Sequence
                              this.runSequence(req.query.sequence)
                                  .then(function () {
                                      res.status(200)
                                          .send({
                                              status: 200
                                  .catch(function (err) {
                                      res.status(400)
                                          .send({
                                              status: 400,
                                              error: err.message
                          } else {
                              res.status(400)
                                  .send({
                                      status: 400,
                                      error: 'Sequence not specified'
                  So if i send a new sequence then i will get the answer 400 sequence not specified.
                  Where do you specify the available sequences?
                  With Best regards
                  Schmo
                    jc21
                    Hi schmo90, good to see you’re contributing :)
                    Assuming your tests with curl -X GET "http://yourmagicmirror/PiLights?sequence=blue_pulse" still don’t work, I think I’d need to see all of your changes. If you’ve forked my repo on github can you please link it?
                      schmo90
                      Hy
                      yeah i made a infinite mirror behind the magic mirror :-)
                      your animations are working fine with my change of your led strip class to my w2801 class.
                      But if i add some squences in the switch case, for example ‘off’ then i get the request error.
                      is there some hidn node.js thing where you define the possible sequences?
                      I have to say i am a C# developer and it is the first time with node.js…
                      No debugging and intellisense with nano is realy painfull^^
                        jc21 @schmo90
                        @schmo90 It should work fine, there is no logic prior to that switch that filters possible values.
                        What does the server console log report after the text [PiLights] Incoming: ?
                        req.query.sequence should contain the string name of the sequence you’re requesting.
                          Ashidian @schmo90
                          @schmo90 I bought a WS2801 LED strip as well. What did you changed to use this module with your strip?
                          I think it would be great for this module to implement both possibilities of LED strips so one can set the type in the properties, wouldn’t it?
                            schmo90
                            hy i found out that node.js will not allow to call some functions.
                            it jumped everytime into the try catch.
                            but now it is working fine…
                            and you need to install the ws2801 npm packages from
                            https://www.npmjs.com/package/rpi-ws2801
                            here is the file:
                            (but i dont know if the uplaod worked…)
                            [0_1485084948629_node_helper.js](Uploading 100%)
                            /* global require */
                            const _ = require('lodash');
                            const Color = require('color');
                            const NodeHelper = require('node_helper');
                            const bodyParser = require('body-parser');
                            const LPD8806 = require('lpd8806-async');
                            //const WS2801	 = require('rpi-ws2801');
                            const async = require('async');
                            var ajv = require('ajv')({
                                allErrors: true,
                                format: 'full',
                                coerceTypes: true
                                config: {},
                                animationRunning: false,
                                stopAnimationRequest: false,
                                defaultSpeed: 100,
                                 * node_helper start method
                                start: function () {
                                    console.log('[PiLights] Starting node_helper');
                                    this.expressApp.use(bodyParser.json());
                                    this.expressApp.use(bodyParser.urlencoded({ extended: true }));
                                            // Sequence
                                                .then(function () {
                                                    res.status(200)
                                                        .send({
                                                            status: 200
                                                    res.status(400)
                                                        .send({
                                                            status: 400,
                                                            error: err.message
                                        } else {
                                            res.status(400)
                                                .send({
                                                    status: 400,
                                 * @param {String} notification
                                 * @param {*}      payload
                                socketNotificationReceived: function (notification, payload) {
                                    if (notification === 'START') {
                                        this.config = payload;
                                        try {
                                            console.info('Trying to load leds');
                                            // Internal reference to rpi-ws2801
                                            this.leds = require("rpi-ws2801");
                                            this.leds.connect(this.config.ledCount, this.config.device);
                                            // Initialize off
                                            this.leds.fill(0x00, 0x00, 0x00);
                                            //this.leds.setMasterBrightness(this.config.brightness);
                                            console.log('[PiLights] Leds connected ok');
                                        } catch (err) {
                                            console.error('[PiLights] Unable to open SPI (' + this.config.device + '), not supported?', err.message);
                                            this.leds = null;
                                    } else if (notification === 'SEQUENCE') {
                                        Promise.resolve(this.runSequence(payload)
                                                console.log('[PiLights] Sequence error: ' + err.message);
                                 * Runs a light sequence
                                 * @param   {String}  sequence
                                 * @param   {Integer} [iterations]
                                 * @returns {Promise}
                                runSequence: function (sequence, iterations) {
                                    var self = this;
                                    iterations = iterations || 20;
                                    return new Promise(function (resolve, reject) {
                                        var colors = [0, 0, 0];
                                        switch (sequence) {
                                            case 'blue_pulse':
                                                colors = [0, 0, 255];
                                                break;
                                            case 'white_pulse':
                                                colors = [255, 255, 255];
                                                break;
                                            case 'lightblue_pulse':
                                                colors = [0, 255, 255];
                                                break;
                                            case 'red_pulse':
                                                colors = [255, 0, 0];
                                                break;
                                            case 'green_pulse':
                                                colors = [0, 255, 0];
                                                break;
                                            case 'orange_pulse':
                                                colors = [255, 170, 0];
                                                break;
                                            case 'pink_pulse':
                                                colors = [255, 0, 255];
                                                break;
                                            case 'off':
                                                colors = [0, 0, 0];
                                                iterations = 1;
                                                break;
                                            default:
                                                reject(new Error('Unknown sequence: ' + sequence));
                                                return;
                                                break;
                                        resolve(self.pulse(colors[0], colors[1], colors[2], iterations, 20));
                                 * @param {Function} cb
                                 * @returns {*}
                                switchAnimation: function (cb) {
                                    if (!this.animationRunning) {
                                        return this.startAnimation(cb);
                                    this.stopAnimationRequest = true;
                                    if (this.animationRunning) {
                                        //console.log('animation was running, delaying new animation');
                                        var self = this;
                                        setTimeout(function () {
                                            self.switchAnimation(cb);
                                        }, 100);
                                    } else {
                                 * @returns {Function}
                                startAnimation: function (cb) {
                                    //console.log('[PiLights] Starting animation..');
                                    this.stopAnimationRequest = false;
                                    this.animationRunning = true;
                                    return cb();
                                stopAnimation: function () {
                                    //console.log('[PiLights] Animation stopped.');
                                    this.animationRunning = false;
                                update: function () {
                                    //        if (this.leds) {
                                    //            this.leds.update();
                                 * @param {Integer} red
                                 * @param {Integer} green
                                 * @param {Integer} blue
                                 * @param {Integer} [speed]
                                pulse: function (red, green, blue, iterations, speed) {
                                    if (this.leds) {
                                        this.switchAnimation(() => {
                                            console.log('[PiLights] Pulse (' + red + ',' + green + ', ' + blue + ') Iterations: ' + iterations + ', Speed: ' + speed);
                                            this.flashEffect(red, green, blue, iterations, speed);
                                 * @param r
                                 * @param g
                                 * @param b
                                fillRGB: function (r, g, b) {
                                    if (this.leds) {
                                            //console.log('[PiLights] Filling leds with', r, g, b);
                                            this.leds.fill(r, g, b);
                                            this.stopAnimation();
                                off: function () {
                                    if (this.leds) {
                                        //console.log('[PiLights] Setting Leds Off');
                                flashEffect: function (r, g, b, iterations, speed) {
                                    var self = this;
                                    var step = 0.05;
                                    var total_iterations = 0;
                                    speed = speed || 10; // ms
                                    iterations = iterations || 99999;
                                    var level = 0.00;
                                    var dir = step;
                                    function performStep() {
                                        if (level <= 0.0) {
                                            level = 0.0;
                                            dir = step;
                                            total_iterations++;
                                        } else if (level >= 1.0) {
                                            level = 1.0;
                                            dir = -step;
                                        level += dir;
                                        if (level < 0.0) {
                                            level = 0.0;
                                        } else if (level > 1.0) {
                                            level = 1.0;
                                        if (self.stopAnimationRequest || total_iterations > iterations) {
                                            self.stopAnimation();
                                            return;
                                        self.leds.fill(r * level, b * level, g * level);
                                        setTimeout(performStep, speed);
                                    if (this.leds) {
                                        performStep();
                              aspartame
                              Has anyone tried using one of the voice control modules to change color or control the light strip? I am new to this and would be interested in some ideas on how to point the correct modules.
                              • F Offline
                                fabrang
                                Hello :), I buyed a WS2801 LED-Chain and now I try to get the module running. I Installed the library via. “npm install rpi-ws2801” but I dont know what I Need to Change to get it work.
                                var leds = require(“rpi-ws2801”);
                                Putting this in my js.File I only get an error message in my developer console?
                                Can somebody help me please?
                                  Ashidian
                                  yes, and you need to check the dependencies in your package.json file.
                                  The WS2801 library uses lightly other function-names, you probably need to check that out
                                  https://www.npmjs.com/package/rpi-ws2801 vs.
                                  https://www.npmjs.com/package/lpd8806-async
                                  I work on an own repository for this one but unfortunaly do not have much time at the moment, you can check that out as well. I thought of an option which sais that you are using ws2801 or lpd8806 and the module handles it … but a lot stuff to do.
                                  https://github.com/Ashidian/MMM-PiLights
                                  • O Offline
                                    orayoflighto Project Sponsor
                                    Does anyone know if APA102 (or DOTSTAR) can be used without modification of the code?
                                    • O Offline
                                      I ordered these:
                                      https://www.amazon.com/gp/product/B01COEJST8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
                                      FYI - for those that are reading this in the future, make sure that your power supply ground is grounded to the RPi ground. That tripped me up.
