    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
    • G
      Gunwoody
      OK fixed the sound issue. So i can talk to Alexa but it doesn’t seem to invoke the Mirror at all - any ideas??
        savage_gr1nd @Gunwoody
        @Gunwoody it only invokes mirror if you ask her to ask mirror.
        Alexa, ask mirror to show me a video of…
        Alexa, ask mirror to close calendar…
        Etc.
        • G
          Gunwoody
          I’m missing something fundamental - I can talk to Alexa (with the three terminals running). I can start Magic Mirror but they don’t seem to be connected. If i ask the question “alexa ask mirror find snow white” on the developer console i get the correct response "“ssml”: " Yes, my Queen, showing images of snow white. "
          Some where i’m missing a link?? Back to the drawing board!!
          • G
            Gunwoody
            I’ve got
            MMM-MirrorMirrorOntheWall in MagicMirror modules - check
            Certs inside MMM-MirrorMirrorOntheWall - check
            Is the Skill supposed to be inside the MagicMirror module somewhere???
            Is npm install for aws-iot-device-sdk run in 2 places???
            MirrorMirrorOnTheWallSkill/src
            and where else???
            Sorry for all the questions :)
            S 2 Replies Last reply
              @Gunwoody also inside MMM-Mirrormirroronthewall located inside magicmirror/modules
                @Gunwoody sorry and no. Skill stays in your root. I was just saying the other thing about installing IoT
                • G
                  Gunwoody
                  Does the skill in your root actually get referenced or is it just a workspace to create the certs and zip file?
                    @Gunwoody I belive a workspace. Because everything in it is essentially code to import to lambda. So opening a YouTube video runs the youtube-node imported into the function itself.
                    • G
                      Gunwoody
                      Hi Savage, that’s what i figured. I need to figure out a way to test connectivity between all the different elements.
                      Do you know where the wake word is set?
                        @Gunwoody there too many moving parts I think to see it all in one spot. But could be wrong lol
                        And where wake word runs depends on which program/version of alexa-sdk you’re using. Like I use alexa-avs-sample-app so mine runs in its own terminal. But that’s soon to change. Gonna run Alexapi so it runs right off of boot instead. That’s my project for tonight lol
                        • G
                          Gunwoody
                          I’m using the same. You’ll have to let me know how it goes with AlexaPi - might be an easier route to take :)
                            @Gunwoody will do :)
                            • zman3Z
                              zman3
                              holy crap I finally got the skill part working. took me doing the whole install npm and everything and uploading the zip all from windows instead of the raspberry. weird
                              • zman3Z
                                zman3
                                of course now i have the problem of it not doing anything with the mirror :/
                                • G
                                  Gunwoody
                                  Exactly the same here
                                    @Gunwoody @zman3 while you were running npm install on the skills dependencies you didn’t sudo npm install right? That blocks amazons access.
                                    • zman3Z
                                      zman3
                                      Nope just regular pi usr
                                        savage_gr1nd @zman3
                                        Hmm. Add MMM-mirrormirror I to MagicMirror config.js? And also have it installed in the magicmirror/modules folder?
                                        • zman3Z
                                          zman3
                                          Yes and yes I’ll try again tonight ,I’m at work which interferes with my play time
                                          • zman3Z
                                            zman3
                                            tried it from the start again the skill its self works but when she says closing module it doesnt close ,no text gets displayed or if I search for snow white images she says displaying but i never see anything.
                                            J 1 Reply Last reply
                                            • 10
                                            • 8 / 10
