    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 391.3k Views 23 Watching
    • G Offline
      Gunwoody
      Thanks Savage - all that seems to be ok as far as i can see. I’ve got new problem now (that didn’t exist before) and i can’t seem to get to the bottom of it. When i start the wakeword engine i get this.
      INFO:main: Starting Wake Word Agent
      INFO:WakeWordAgent: State set to IDLE(2)
      INFO:Initializing Sensory library | library name: TrulyHandsfree | library version: 5.0.0-avs.1 | model file: …/ext/resources/spot-alexa-rpi.snsr
      WARNING:Library expires on: License expires on 28 May 2017 00:00:00 GMT
      wakeWordAgent: pcm.c:694: snd_pcm_close: Assertion `pcm’ failed.
      Aborted
      • G Offline
        Gunwoody
        OK fixed the sound issue. So i can talk to Alexa but it doesn’t seem to invoke the Mirror at all - any ideas??
          savage_gr1nd @Gunwoody
          @Gunwoody it only invokes mirror if you ask her to ask mirror.
          Alexa, ask mirror to show me a video of…
          Alexa, ask mirror to close calendar…
          Etc.
          • G Offline
            Gunwoody
            I’m missing something fundamental - I can talk to Alexa (with the three terminals running). I can start Magic Mirror but they don’t seem to be connected. If i ask the question “alexa ask mirror find snow white” on the developer console i get the correct response "“ssml”: " Yes, my Queen, showing images of snow white. "
            Some where i’m missing a link?? Back to the drawing board!!
            • G Offline
              Gunwoody
              I’ve got
              MMM-MirrorMirrorOntheWall in MagicMirror modules - check
              Certs inside MMM-MirrorMirrorOntheWall - check
              Is the Skill supposed to be inside the MagicMirror module somewhere???
              Is npm install for aws-iot-device-sdk run in 2 places???
              MirrorMirrorOnTheWallSkill/src
              and where else???
              Sorry for all the questions :)
                @Gunwoody also inside MMM-Mirrormirroronthewall located inside magicmirror/modules
                  @Gunwoody sorry and no. Skill stays in your root. I was just saying the other thing about installing IoT
                  • G Offline
                    Gunwoody
                    Does the skill in your root actually get referenced or is it just a workspace to create the certs and zip file?
                      @Gunwoody I belive a workspace. Because everything in it is essentially code to import to lambda. So opening a YouTube video runs the youtube-node imported into the function itself.
                      • G Offline
                        Gunwoody
                        Hi Savage, that’s what i figured. I need to figure out a way to test connectivity between all the different elements.
                        Do you know where the wake word is set?
                          @Gunwoody there too many moving parts I think to see it all in one spot. But could be wrong lol
                          And where wake word runs depends on which program/version of alexa-sdk you’re using. Like I use alexa-avs-sample-app so mine runs in its own terminal. But that’s soon to change. Gonna run Alexapi so it runs right off of boot instead. That’s my project for tonight lol
                          • G Offline
                            Gunwoody
                            I’m using the same. You’ll have to let me know how it goes with AlexaPi - might be an easier route to take :)
                              @Gunwoody will do :)
                              • Z Offline
                                zman3
                                holy crap I finally got the skill part working. took me doing the whole install npm and everything and uploading the zip all from windows instead of the raspberry. weird
                                • Z Offline
                                  zman3
                                  of course now i have the problem of it not doing anything with the mirror :/
                                  • G Offline
                                    Gunwoody
                                    Exactly the same here
                                      @Gunwoody @zman3 while you were running npm install on the skills dependencies you didn’t sudo npm install right? That blocks amazons access.
                                      • Z Offline
                                        zman3
                                        Nope just regular pi usr
                                          savage_gr1nd @zman3
                                          Hmm. Add MMM-mirrormirror I to MagicMirror config.js? And also have it installed in the magicmirror/modules folder?
                                          • Z Offline
                                            zman3
                                            Yes and yes I’ll try again tonight ,I’m at work which interferes with my play time
                                            • 10
                                            • 8 / 10
