Unsolved Total n00b and can't get this thing to work. Please help!
I’ll give that a shot!
Ok, so that all went well until I got to:
Get and install MagicMirror with the Automatic Installer: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
At which point, I get “No such file or directory”.
That feels like a small error that I should be able to figure out, but I just can’t seem to get past that point :/
@EttVenter and if you run
Without the bash cd command? -
@broberg Then i get this:
# This is an installer script for MagicMirror2. It works well enough # that it can detect if you have Node installed, run a binary script # and then download and run MagicMirror2. echo -e "\e[0m" echo '$$\ $$\ $$\ $$\ $$\ $$\ $$$$$$\' echo '$$$\ $$$ | \__| $$$\ $$$ |\__| $$ __$$\' echo '$$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ \__/ $$ |' echo '$$\$$\$$ $$ | \____$$\ $$ __$$\ $$ |$$ _____|$$\$$\$$ $$ |$$ |$$ __$$\ $$ __$$\ $$ __$$\ $$ __$$\ $$$$$$ |' echo '$$ \$$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ \$$$ $$ |$$ |$$ | \__|$$ | \__|$$ / $$ |$$ | \__|$$ ____/' echo '$$ |\$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |\$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |' echo '$$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ | $$ | \$$$$$$ |$$ | $$$$$$$$\' echo '\__| \__| \_______| \____$$ |\__| \_______|\__| \__|\__|\__| \__| \______/ \__| \________|' echo ' $$\ $$ |' echo ' \$$$$$$ |' echo ' \______/' echo -e "\e[0m" # Define the tested version of Node.js. NODE_TESTED="v5.1.0" #Determine which Pi is running. ARM=$(uname -m) #Check the Raspberry Pi version. if [ "$ARM" != "armv7l" ]; then echo -e "\e[91mSorry, your Raspberry Pi is not supported." echo -e "\e[91mPlease run MagicMirror on a Raspberry Pi 2 or 3." echo -e "\e[91mIf this is a Pi Zero, you are in the same boat as the original Raspberry Pi. You must run in server only mode." exit; fi #define helper methods. function version_gt() { test "$(echo "$@" | tr " " "\n" | sort -V | head -n 1)" != "$1"; } function command_exists () { type "$1" &> /dev/null ;} # Installing helper tools echo -e "\e[96mInstalling helper tools ...\e[90m" sudo apt-get install curl wget git build-essential unzip || exit # Check if we need to install or upgrade Node.js. echo -e "\e[96mCheck current Node installation ...\e[0m" NODE_INSTALL=false if command_exists node; then echo -e "\e[0mNode currently installed. Checking version number."; NODE_CURRENT=$(node -v) echo -e "\e[0mMinimum Node version: \e[1m$NODE_TESTED\e[0m" echo -e "\e[0mInstalled Node version: \e[1m$NODE_CURRENT\e[0m" if version_gt $NODE_TESTED $NODE_CURRENT; then echo -e "\e[96mNode should be upgraded.\e[0m" NODE_INSTALL=true #Check if a node process is currenlty running. #If so abort installation. if pgrep "node" > /dev/null; then echo -e "\e[91mA Node process is currently running. Can't upgrade." echo "Please quit all Node processes and restart the installer." exit; fi else echo -e "\e[92mNo Node.js upgrade nessecery.\e[0m" fi else echo -e "\e[93mNode.js is not installed.\e[0m"; NODE_INSTALL=true fi # Install or upgrade node if necessary. if $NODE_INSTALL; then echo -e "\e[96mInstalling Node.js ...\e[90m" #Fetch the latest version of Node.js from the selected branch #The NODE_STABLE_BRANCH variable will need to be manually adjusted when a new branch is released. (e.g. 7.x) #Only tested (stable) versions are recommended as newer versions could break MagicMirror. NODE_STABLE_BRANCH="6.x" curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash - sudo apt-get install -y nodejs echo -e "\e[92mNode.js installation Done!\e[0m" fi #Install magic mirror cd ~ if [ -d "$HOME/MagicMirror" ] ; then echo -e "\e[93mIt seems like MagicMirror is already installed." echo -e "To prevent overwriting, the installer will be aborted." echo -e "Please rename the \e[1m~/MagicMirror\e[0m\e[93m folder and try again.\e[0m" echo "" echo -e "If you want to upgrade your installation run \e[1m\e[97mgit pull\e[0m from the ~/MagicMirror directory." echo "" exit; fi echo -e "\e[96mCloning MagicMirror ...\e[90m" if git clone https://github.com/MichMich/MagicMirror.git; then echo -e "\e[92mCloning MagicMirror Done!\e[0m" else echo -e "\e[91mUnable to clone MagicMirror." exit; fi cd ~/MagicMirror || exit echo -e "\e[96mInstalling dependencies ...\e[90m" if npm install; then echo -e "\e[92mDependencies installation Done!\e[0m" else echo -e "\e[91mUnable to install dependencies!" exit; fi # Check if plymouth is installed (default with PIXEL desktop environment), then install custom splashscreen. echo -e "\e[96mCheck plymouth installation ...\e[0m" if command_exists plymouth; then THEME_DIR="/usr/share/plymouth/themes" echo -e "\e[90mSplashscreen: Checking themes directory.\e[0m" if [ -d $THEME_DIR ]; then echo -e "\e[90mSplashscreen: Create theme directory if not exists.\e[0m" if [ ! -d $THEME_DIR/MagicMirror ]; then sudo mkdir $THEME_DIR/MagicMirror fi if sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script; then echo -e "\e[90mSplashscreen: Theme copied successfully.\e[0m" if sudo plymouth-set-default-theme -R MagicMirror; then echo -e "\e[92mSplashscreen: Changed theme to MagicMirror successfully.\e[0m" else echo -e "\e[91mSplashscreen: Couldn't change theme to MagicMirror!\e[0m" fi else echo -e "\e[91mSplashscreen: Copying theme failed!\e[0m" fi else echo -e "\e[91mSplashscreen: Themes folder doesn't exist!\e[0m" fi else echo -e "\e[93mplymouth is not installed.\e[0m"; fi echo " " echo -e "\e[92mWe're ready! Run \e[1m\e[97mDISPLAY=:0 npm start\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m" echo " " echo " "
Literally no idea what happened there. But, if I navigate to the magicmirror folder now and do an “npm install”, I get:
pi@raspberrypi:~/MagicMirror $ npm install npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"}) / > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js sh: 1: node: not found npm WARN This failure might be due to the use of legacy binary "node" npm WARN For further explanations, please read /usr/share/doc/nodejs/README.Debian npm ERR! electron@1.4.15 postinstall: `node install.js` npm ERR! Exit status 127 npm ERR! npm ERR! Failed at the electron@1.4.15 postinstall script. npm ERR! This is most likely a problem with the electron package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node install.js npm ERR! You can get their info via: npm ERR! npm owner ls electron npm ERR! There is likely additional logging output above. npm ERR! System Linux 4.4.38-v7+ npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v0.10.29 npm ERR! npm -v 1.4.21 npm ERR! code ELIFECYCLE npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0
@EttVenter you have to use the
| bash
part, because what is doing is the following, curl will load the script from github and then you pipe it right into the bash command to execute the script otherwise you would just load the file -
@strawberry-3.141 Ok so what do I do then? Because if I run the command with the bash part of the command, it tells me “No such file or directory”. So how do I solve that?
@EttVenter did you probably start the command from a wrong directory? do
cd ~
first -
pi@raspberrypi:~ $ cd ~ pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror bash: cd: No such file or directory pi@raspberrypi:~ $
Then I even went ahead and manually created that directory, and it still doesn’t work:
pi@raspberrypi:~ $ mkdir MagicMirror pi@raspberrypi:~ $ ls Desktop Documents Downloads MagicMirror Music Pictures Public Templates Videos pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror bash: cd: No such file or directory pi@raspberrypi:~ $
@EttVenter just remove the directory magicmirror again that you created and run the command
as it is in the readme after it was successful docd MagicMirror
@strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
cd MagicMirror
That was going well until:
Cloning MagicMirror Done! Installing dependencies ... npm ERR! cb() never called! Unable to install dependencies!
Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
