    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 31.4k Views 7 Watching
    • E
      EttVenter @theusu5k
      @theusu5k
      Great, thanks! I’ll report back once I’ve updated everything!
      • E
        EttVenter
        That didn’t solve my issues. Tried again, and here’s the result:
        pi@raspberrypi:~/MagicMirror $ npm install && npm start
        npm http GET https://registry.npmjs.org/electron
        npm http GET https://registry.npmjs.org/express-ipfilter
        npm http GET https://registry.npmjs.org/feedme
        npm http GET https://registry.npmjs.org/iconv-lite
        npm http GET https://registry.npmjs.org/moment
        npm http GET https://registry.npmjs.org/request
        npm http GET https://registry.npmjs.org/helmet
        npm http GET https://registry.npmjs.org/rrule
        npm http GET https://registry.npmjs.org/simple-git
        npm http GET https://registry.npmjs.org/socket.io
        npm http GET https://registry.npmjs.org/walk
        npm http GET https://registry.npmjs.org/valid-url
        npm http GET https://registry.npmjs.org/grunt
        npm http GET https://registry.npmjs.org/grunt-eslint
        npm http GET https://registry.npmjs.org/grunt-jsonlint
        npm http GET https://registry.npmjs.org/grunt-stylelint
        npm http GET https://registry.npmjs.org/grunt-markdownlint
        npm http GET https://registry.npmjs.org/grunt-yamllint
        npm http GET https://registry.npmjs.org/stylelint-config-standard
        npm http GET https://registry.npmjs.org/time-grunt
        npm http 304 https://registry.npmjs.org/moment
        npm http 304 https://registry.npmjs.org/feedme
        npm http 304 https://registry.npmjs.org/electron
        npm http 304 https://registry.npmjs.org/iconv-lite
        npm ERR! Error: No compatible version found: electron@'^1.4.7'
        npm ERR! Valid install targets:
        npm ERR! ["0.1.0","0.1.1","0.1.2","0.2.0","0.2.1","0.3.0","0.4.0","0.4.1","1.3.1","1.3.2","1.3.3","1.3.4","1.3.5","1.3.6","1.4.0","1.4.1","1.3.7","1.4.2","1.4.3","1.4.4","1.3.8","1.4.5","1.4.6","1.4.7","1.3.9","1.3.10","1.4.8","1.3.12","1.4.10","1.3.13","1.4.11","1.4.12","1.4.13","1.4.14","1.4.15","1.5.0","1.5.1","1.6.0","1.6.1"]
        npm ERR!     at installTargetsError (/usr/local/lib/node_modules/npm/lib/cache.js:563:10)
        npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:478:10
        npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:138:7)
        npm ERR!     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:218:7
        npm ERR!     at Object.oncomplete (fs.js:297:15)
        npm ERR! If you need help, you may report this log at:
        npm ERR!
        npm ERR! or email it to:
        npm ERR!
        npm ERR! System Linux 4.4.34-v7+
        npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install"
        npm ERR! cwd /home/pi/MagicMirror
        npm ERR! node -v v0.8.16
        npm ERR! npm -v 1.1.69
        npm http 304 https://registry.npmjs.org/request
        npm http 304 https://registry.npmjs.org/express-ipfilter
        npm http 304 https://registry.npmjs.org/helmet
        npm http 304 https://registry.npmjs.org/rrule
        npm http 304 https://registry.npmjs.org/socket.io
        npm http 304 https://registry.npmjs.org/simple-git
        npm http 304 https://registry.npmjs.org/walk
        npm http 304 https://registry.npmjs.org/grunt
        npm http 304 https://registry.npmjs.org/valid-url
        npm http 304 https://registry.npmjs.org/grunt-eslint
        npm http 304 https://registry.npmjs.org/grunt-jsonlint
        npm http 304 https://registry.npmjs.org/grunt-stylelint
        npm http 304 https://registry.npmjs.org/grunt-markdownlint
        npm http 304 https://registry.npmjs.org/grunt-yamllint
        npm http 304 https://registry.npmjs.org/stylelint-config-standard
        npm http 304 https://registry.npmjs.org/time-grunt
        npm WARN package.json moment@2.17.1 No README.md file found!
        npm WARN package.json iconv-lite@0.4.15 No README.md file found!
        npm WARN package.json feedme@0.3.3 No README.md file found!
        npm WARN package.json express-ipfilter@0.2.3 No README.md file found!
        npm WARN package.json rrule@2.1.0 No README.md file found!
        npm WARN package.json walk@2.3.9 No README.md file found!
        npm WARN package.json grunt@1.0.1 No README.md file found!
        npm WARN package.json grunt-jsonlint@1.1.0 No README.md file found!
        npm WARN package.json grunt-stylelint@0.7.0 No README.md file found!
        npm WARN package.json grunt-eslint@19.0.0 No README.md file found!
        npm WARN package.json grunt-yamllint@0.2.0 No README.md file found!
        npm WARN package.json time-grunt@1.4.0 No README.md file found!
        npm WARN package.json stylelint-config-standard@16.0.0 No README.md file found!
        npm ERR!
        npm ERR! Additional logging details can be found in:
        npm ERR!     /home/pi/MagicMirror/npm-debug.log
        npm ERR! not ok code 0
        • Y
          yawns Moderator
          Your node is still old. Did you run
          apt-get update
          apt-get upgrade
          or
          sudo apt-get update
          sudo apt-get upgrade
          ? Without sudo (root rights) apt-get will not install anything and just throw out errors.
          E 1 Reply Last reply
          • E
            EttVenter @yawns
            @yawns I ran it with sudo
            Here’s the result of sudo apt-get upgrade after I ran sudo apt-get update:
            pi@raspberrypi:~ $ sudo apt-get upgrade
            Reading package lists... Done
            Building dependency tree
            Calculating upgrade... The following packages were automatically installed and are no longer required:
              libc-ares2 libv8-3.14.5
            Use 'apt-get autoremove' to remove them.
            Done
            The following packages have been kept back:
              chromium-browser libgl1-mesa-dri pprompt rpi-chromium-mods sonic-pi
              xserver-xorg-input-all
            0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
            Then, if I do:
            git clone https://github.com/MichMich/MagicMirror
            as suggested above, I’m met with:
            npm ERR!
            npm ERR!
            npm ERR!
            • Y
              yawns Moderator
              Very weird indeed. Did you install Jessie or Jessie Lite?
              If I run the version commands, I get this on my pi:
              npm -v: 3.10.8
              node -v: 6.9.1
              nodejs -v: 6.9.1
              Please try this:
              sudo apt-get remove nodered -y
              sudo apt-get remove nodejs nodejs-legacy -y
              sudo apt-get remove npm -y
              sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
              sudo apt-get install -y nodejs
              node -v
              npm -v
              and then try to run the npm install && npm start again in your MagicMirror folder
              • E
                EttVenter @yawns
                @yawns
                Ok, I ran all of that. Once I ran the node -v and npm -v commands I was met with:
                pi@raspberrypi:~ $ node -v
                v0.8.16
                pi@raspberrypi:~ $ npm -v
                1.1.69
                So I’m assuming I’m still on super old versions. Any idea why that’s happening? Because if I run npm install && npm start, I’m getting the same errors I was getting before.
                Also - Jessie, not Jessie lite.
                • Y
                  yawns Moderator
                  But you did not receive any error message during removal and installation?
                  • E
                    EttVenter @yawns
                    @yawns Nope, no errors there.
                    • E
                      EttVenter
                      Anyone else got any ideas? Really want to get this thing going. I bought the Pi yesterday specifically for this :(
                      B 1 Reply Last reply
                        broberg Project Sponsor @EttVenter
                        @EttVenter I would suggest a total reformatting of the SD card, get the Jessie lite image and put that on your sd card.
                        Then follow these instructions : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
                        E 2 Replies Last reply
                        • E
                          EttVenter @broberg
                          @broberg
                          I’ll give that a shot!
                          • E
                            EttVenter @broberg
                            @broberg
                            Ok, so that all went well until I got to:
                            Get and install MagicMirror with the Automatic Installer:
                            curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
                            At which point, I get “No such file or directory”.
                            That feels like a small error that I should be able to figure out, but I just can’t seem to get past that point :/
                              @EttVenter and if you run curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh
                              Without the bash cd command?
                              • E
                                EttVenter @broberg
                                @broberg Then i get this:
                                # This is an installer script for MagicMirror2. It works well enough
                                # that it can detect if you have Node installed, run a binary script
                                # and then download and run MagicMirror2.
                                echo -e "\e[0m"
                                echo '$$\      $$\                     $$\           $$\      $$\ $$\                                          $$$$$$\'
                                echo '$$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\'
                                echo '$$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |'
                                echo '$$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |'
                                echo '$$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/'
                                echo '$$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |'
                                echo '$$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\'
                                echo '\__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|'
                                echo '                       $$\   $$ |'
                                echo '                       \$$$$$$  |'
                                echo '                        \______/'
                                echo -e "\e[0m"
                                # Define the tested version of Node.js.
                                NODE_TESTED="v5.1.0"
                                #Determine which Pi is running.
                                ARM=$(uname -m)
                                #Check the Raspberry Pi version.
                                if [ "$ARM" != "armv7l" ]; then
                                	echo -e "\e[91mSorry, your Raspberry Pi is not supported."
                                	echo -e "\e[91mPlease run MagicMirror on a Raspberry Pi 2 or 3."
                                	echo -e "\e[91mIf this is a Pi Zero, you are in the same boat as the original Raspberry Pi. You must run in server only mode."
                                	exit;
                                fi
                                #define helper methods.
                                function version_gt() { test "$(echo "$@" | tr " " "\n" | sort -V | head -n 1)" != "$1"; }
                                function command_exists () { type "$1" &> /dev/null ;}
                                # Installing helper tools
                                echo -e "\e[96mInstalling helper tools ...\e[90m"
                                sudo apt-get install curl wget git build-essential unzip || exit
                                # Check if we need to install or upgrade Node.js.
                                echo -e "\e[96mCheck current Node installation ...\e[0m"
                                NODE_INSTALL=false
                                if command_exists node; then
                                	echo -e "\e[0mNode currently installed. Checking version number.";
                                	NODE_CURRENT=$(node -v)
                                	echo -e "\e[0mMinimum Node version: \e[1m$NODE_TESTED\e[0m"
                                	echo -e "\e[0mInstalled Node version: \e[1m$NODE_CURRENT\e[0m"
                                	if version_gt $NODE_TESTED $NODE_CURRENT; then
                                		echo -e "\e[96mNode should be upgraded.\e[0m"
                                		NODE_INSTALL=true
                                		#Check if a node process is currenlty running.
                                		#If so abort installation.
                                		if pgrep "node" > /dev/null; then
                                			echo -e "\e[91mA Node process is currently running. Can't upgrade."
                                			echo "Please quit all Node processes and restart the installer."
                                			exit;
                                		fi
                                	else
                                		echo -e "\e[92mNo Node.js upgrade nessecery.\e[0m"
                                	fi
                                else
                                	echo -e "\e[93mNode.js is not installed.\e[0m";
                                	NODE_INSTALL=true
                                fi
                                # Install or upgrade node if necessary.
                                if $NODE_INSTALL; then
                                	echo -e "\e[96mInstalling Node.js ...\e[90m"
                                	#Fetch the latest version of Node.js from the selected branch
                                	#The NODE_STABLE_BRANCH variable will need to be manually adjusted when a new branch is released. (e.g. 7.x)
                                	#Only tested (stable) versions are recommended as newer versions could break MagicMirror.
                                	NODE_STABLE_BRANCH="6.x"
                                	curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
                                	echo -e "\e[92mNode.js installation Done!\e[0m"
                                fi
                                #Install magic mirror
                                cd ~
                                if [ -d "$HOME/MagicMirror" ] ; then
                                	echo -e "\e[93mIt seems like MagicMirror is already installed."
                                	echo -e "To prevent overwriting, the installer will be aborted."
                                	echo -e "Please rename the \e[1m~/MagicMirror\e[0m\e[93m folder and try again.\e[0m"
                                	echo ""
                                	echo -e "If you want to upgrade your installation run \e[1m\e[97mgit pull\e[0m from the ~/MagicMirror directory."
                                	echo ""
                                	exit;
                                fi
                                echo -e "\e[96mCloning MagicMirror ...\e[90m"
                                if git clone https://github.com/MichMich/MagicMirror.git; then
                                	echo -e "\e[92mCloning MagicMirror Done!\e[0m"
                                else
                                	echo -e "\e[91mUnable to clone MagicMirror."
                                	exit;
                                fi
                                cd ~/MagicMirror  || exit
                                echo -e "\e[96mInstalling dependencies ...\e[90m"
                                if npm install; then
                                	echo -e "\e[92mDependencies installation Done!\e[0m"
                                else
                                	echo -e "\e[91mUnable to install dependencies!"
                                	exit;
                                fi
                                # Check if plymouth is installed (default with PIXEL desktop environment), then install custom splashscreen.
                                echo -e "\e[96mCheck plymouth installation ...\e[0m"
                                if command_exists plymouth; then
                                	THEME_DIR="/usr/share/plymouth/themes"
                                	echo -e "\e[90mSplashscreen: Checking themes directory.\e[0m"
                                	if [ -d $THEME_DIR ]; then
                                		echo -e "\e[90mSplashscreen: Create theme directory if not exists.\e[0m"
                                		if [ ! -d $THEME_DIR/MagicMirror ]; then
                                			sudo mkdir $THEME_DIR/MagicMirror
                                		fi
                                		if sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script; then
                                			echo -e "\e[90mSplashscreen: Theme copied successfully.\e[0m"
                                			if sudo plymouth-set-default-theme -R MagicMirror; then
                                				echo -e "\e[92mSplashscreen: Changed theme to MagicMirror successfully.\e[0m"
                                			else
                                				echo -e "\e[91mSplashscreen: Couldn't change theme to MagicMirror!\e[0m"
                                			fi
                                		else
                                			echo -e "\e[91mSplashscreen: Copying theme failed!\e[0m"
                                		fi
                                	else
                                		echo -e "\e[91mSplashscreen: Themes folder doesn't exist!\e[0m"
                                	fi
                                else
                                	echo -e "\e[93mplymouth is not installed.\e[0m";
                                fi
                                echo " "
                                echo -e "\e[92mWe're ready! Run \e[1m\e[97mDISPLAY=:0 npm start\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m"
                                echo " "
                                echo " "
                                Literally no idea what happened there. But, if I navigate to the magicmirror folder now and do an “npm install”, I get:
                                npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                                > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                                > node install.js
                                sh: 1: node: not found
                                npm WARN This failure might be due to the use of legacy binary "node"
                                npm WARN For further explanations, please read
                                /usr/share/doc/nodejs/README.Debian
                                npm ERR! electron@1.4.15 postinstall: `node install.js`
                                npm ERR! Exit status 127
                                npm ERR!
                                npm ERR! Failed at the electron@1.4.15 postinstall script.
                                npm ERR! This is most likely a problem with the electron package,
                                npm ERR! not with npm itself.
                                npm ERR!     node install.js
                                npm ERR! You can get their info via:
                                npm ERR!     npm owner ls electron
                                npm ERR! System Linux 4.4.38-v7+
                                npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
                                npm ERR! node -v v0.10.29
                                npm ERR! npm -v 1.4.21
                                npm ERR! code ELIFECYCLE
                                npm ERR!
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @EttVenter
                                  @EttVenter you have to use the | bash part, because what is doing is the following, curl will load the script from github and then you pipe it right into the bash command to execute the script otherwise you would just load the file
                                  • E
                                    EttVenter @strawberry 3.141
                                    @strawberry-3.141 Ok so what do I do then? Because if I run the command with the bash part of the command, it tells me “No such file or directory”. So how do I solve that?
                                    • strawberry 3.141S
                                      @EttVenter did you probably start the command from a wrong directory? do cd ~ first
                                      • E
                                        @strawberry-3.141
                                        pi@raspberrypi:~ $ cd ~
                                        pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
                                        bash: cd: No such file or directory
                                        pi@raspberrypi:~ $
                                        Then I even went ahead and manually created that directory, and it still doesn’t work:
                                        pi@raspberrypi:~ $ mkdir MagicMirror
                                        pi@raspberrypi:~ $ ls
                                        Desktop  Documents  Downloads  MagicMirror  Music  Pictures  Public  Templates  Videos
                                        pi@raspberrypi:~ $
                                        • strawberry 3.141S
                                          @EttVenter just remove the directory magicmirror again that you created and run the command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash as it is in the readme after it was successful do cd MagicMirror
                                          • E
                                            @strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
                                            cd MagicMirror
                                            That was going well until:
                                            npm ERR! cb() never called!
                                            Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
                                            I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
