    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 31.0k Views 7 Watching
    • E
      EttVenter @yawns
      @yawns
      Ok, I ran all of that. Once I ran the node -v and npm -v commands I was met with:
      pi@raspberrypi:~ $ node -v
      v0.8.16
      pi@raspberrypi:~ $ npm -v
      1.1.69
      So I’m assuming I’m still on super old versions. Any idea why that’s happening? Because if I run npm install && npm start, I’m getting the same errors I was getting before.
      Also - Jessie, not Jessie lite.
      • Y
        yawns Moderator
        But you did not receive any error message during removal and installation?
        • E
          EttVenter @yawns
          @yawns Nope, no errors there.
          • E
            EttVenter
            Anyone else got any ideas? Really want to get this thing going. I bought the Pi yesterday specifically for this :(
              broberg Project Sponsor @EttVenter
              @EttVenter I would suggest a total reformatting of the SD card, get the Jessie lite image and put that on your sd card.
              Then follow these instructions : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
              E 2 Replies Last reply Reply Quote 1
              • E
                EttVenter @broberg
                @broberg
                I’ll give that a shot!
                • E
                  EttVenter @broberg
                  @broberg
                  Ok, so that all went well until I got to:
                  Get and install MagicMirror with the Automatic Installer:
                  curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
                  At which point, I get “No such file or directory”.
                  That feels like a small error that I should be able to figure out, but I just can’t seem to get past that point :/
                    @EttVenter and if you run curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh
                    Without the bash cd command?
                    • E
                      EttVenter @broberg
                      @broberg Then i get this:
                      # This is an installer script for MagicMirror2. It works well enough
                      # that it can detect if you have Node installed, run a binary script
                      # and then download and run MagicMirror2.
                      echo -e "\e[0m"
                      echo '$$\      $$\                     $$\           $$\      $$\ $$\                                          $$$$$$\'
                      echo '$$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\'
                      echo '$$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |'
                      echo '$$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |'
                      echo '$$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/'
                      echo '$$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |'
                      echo '$$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\'
                      echo '\__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|'
                      echo '                       $$\   $$ |'
                      echo '                       \$$$$$$  |'
                      echo '                        \______/'
                      echo -e "\e[0m"
                      # Define the tested version of Node.js.
                      NODE_TESTED="v5.1.0"
                      #Determine which Pi is running.
                      ARM=$(uname -m)
                      #Check the Raspberry Pi version.
                      if [ "$ARM" != "armv7l" ]; then
                      	echo -e "\e[91mSorry, your Raspberry Pi is not supported."
                      	echo -e "\e[91mPlease run MagicMirror on a Raspberry Pi 2 or 3."
                      	echo -e "\e[91mIf this is a Pi Zero, you are in the same boat as the original Raspberry Pi. You must run in server only mode."
                      	exit;
                      fi
                      #define helper methods.
                      function version_gt() { test "$(echo "$@" | tr " " "\n" | sort -V | head -n 1)" != "$1"; }
                      function command_exists () { type "$1" &> /dev/null ;}
                      # Installing helper tools
                      echo -e "\e[96mInstalling helper tools ...\e[90m"
                      sudo apt-get install curl wget git build-essential unzip || exit
                      # Check if we need to install or upgrade Node.js.
                      echo -e "\e[96mCheck current Node installation ...\e[0m"
                      NODE_INSTALL=false
                      if command_exists node; then
                      	echo -e "\e[0mNode currently installed. Checking version number.";
                      	NODE_CURRENT=$(node -v)
                      	echo -e "\e[0mMinimum Node version: \e[1m$NODE_TESTED\e[0m"
                      	echo -e "\e[0mInstalled Node version: \e[1m$NODE_CURRENT\e[0m"
                      	if version_gt $NODE_TESTED $NODE_CURRENT; then
                      		echo -e "\e[96mNode should be upgraded.\e[0m"
                      		NODE_INSTALL=true
                      		#Check if a node process is currenlty running.
                      		#If so abort installation.
                      		if pgrep "node" > /dev/null; then
                      			echo -e "\e[91mA Node process is currently running. Can't upgrade."
                      			echo "Please quit all Node processes and restart the installer."
                      			exit;
                      		fi
                      	else
                      		echo -e "\e[92mNo Node.js upgrade nessecery.\e[0m"
                      	fi
                      else
                      	echo -e "\e[93mNode.js is not installed.\e[0m";
                      	NODE_INSTALL=true
                      fi
                      # Install or upgrade node if necessary.
                      if $NODE_INSTALL; then
                      	echo -e "\e[96mInstalling Node.js ...\e[90m"
                      	#Fetch the latest version of Node.js from the selected branch
                      	#The NODE_STABLE_BRANCH variable will need to be manually adjusted when a new branch is released. (e.g. 7.x)
                      	#Only tested (stable) versions are recommended as newer versions could break MagicMirror.
                      	NODE_STABLE_BRANCH="6.x"
                      	curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
                      	sudo apt-get install -y nodejs
                      	echo -e "\e[92mNode.js installation Done!\e[0m"
                      fi
                      #Install magic mirror
                      cd ~
                      if [ -d "$HOME/MagicMirror" ] ; then
                      	echo -e "\e[93mIt seems like MagicMirror is already installed."
                      	echo -e "To prevent overwriting, the installer will be aborted."
                      	echo -e "Please rename the \e[1m~/MagicMirror\e[0m\e[93m folder and try again.\e[0m"
                      	echo ""
                      	echo -e "If you want to upgrade your installation run \e[1m\e[97mgit pull\e[0m from the ~/MagicMirror directory."
                      	echo ""
                      	exit;
                      fi
                      echo -e "\e[96mCloning MagicMirror ...\e[90m"
                      if git clone https://github.com/MichMich/MagicMirror.git; then
                      	echo -e "\e[92mCloning MagicMirror Done!\e[0m"
                      else
                      	echo -e "\e[91mUnable to clone MagicMirror."
                      	exit;
                      fi
                      cd ~/MagicMirror  || exit
                      echo -e "\e[96mInstalling dependencies ...\e[90m"
                      if npm install; then
                      	echo -e "\e[92mDependencies installation Done!\e[0m"
                      else
                      	echo -e "\e[91mUnable to install dependencies!"
                      	exit;
                      fi
                      # Check if plymouth is installed (default with PIXEL desktop environment), then install custom splashscreen.
                      echo -e "\e[96mCheck plymouth installation ...\e[0m"
                      if command_exists plymouth; then
                      	THEME_DIR="/usr/share/plymouth/themes"
                      	echo -e "\e[90mSplashscreen: Checking themes directory.\e[0m"
                      	if [ -d $THEME_DIR ]; then
                      		echo -e "\e[90mSplashscreen: Create theme directory if not exists.\e[0m"
                      		if [ ! -d $THEME_DIR/MagicMirror ]; then
                      			sudo mkdir $THEME_DIR/MagicMirror
                      		fi
                      		if sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script; then
                      			echo -e "\e[90mSplashscreen: Theme copied successfully.\e[0m"
                      			if sudo plymouth-set-default-theme -R MagicMirror; then
                      				echo -e "\e[92mSplashscreen: Changed theme to MagicMirror successfully.\e[0m"
                      			else
                      				echo -e "\e[91mSplashscreen: Couldn't change theme to MagicMirror!\e[0m"
                      			fi
                      		else
                      			echo -e "\e[91mSplashscreen: Copying theme failed!\e[0m"
                      		fi
                      	else
                      		echo -e "\e[91mSplashscreen: Themes folder doesn't exist!\e[0m"
                      	fi
                      else
                      	echo -e "\e[93mplymouth is not installed.\e[0m";
                      fi
                      echo " "
                      echo -e "\e[92mWe're ready! Run \e[1m\e[97mDISPLAY=:0 npm start\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m"
                      echo " "
                      echo " "
                      Literally no idea what happened there. But, if I navigate to the magicmirror folder now and do an “npm install”, I get:
                      pi@raspberrypi:~/MagicMirror $ npm install
                      npm WARN engine deep-extend@0.4.1: wanted: {"node":">=0.12.0","iojs":">=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
                      > electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      sh: 1: node: not found
                      npm WARN This failure might be due to the use of legacy binary "node"
                      npm WARN For further explanations, please read
                      /usr/share/doc/nodejs/README.Debian
                      npm ERR! electron@1.4.15 postinstall: `node install.js`
                      npm ERR! Exit status 127
                      npm ERR!
                      npm ERR! Failed at the electron@1.4.15 postinstall script.
                      npm ERR! This is most likely a problem with the electron package,
                      npm ERR! not with npm itself.
                      npm ERR!     node install.js
                      npm ERR! You can get their info via:
                      npm ERR!     npm owner ls electron
                      npm ERR! System Linux 4.4.38-v7+
                      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
                      npm ERR! cwd /home/pi/MagicMirror
                      npm ERR! node -v v0.10.29
                      npm ERR! npm -v 1.4.21
                      npm ERR! code ELIFECYCLE
                      npm ERR!
                      npm ERR! Additional logging details can be found in:
                      npm ERR!     /home/pi/MagicMirror/npm-debug.log
                      npm ERR! not ok code 0
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @EttVenter
                        @EttVenter you have to use the | bash part, because what is doing is the following, curl will load the script from github and then you pipe it right into the bash command to execute the script otherwise you would just load the file
                        E 1 Reply Last reply Reply Quote 1
                        • E
                          EttVenter @strawberry 3.141
                          @strawberry-3.141 Ok so what do I do then? Because if I run the command with the bash part of the command, it tells me “No such file or directory”. So how do I solve that?
                          • strawberry 3.141S
                            @EttVenter did you probably start the command from a wrong directory? do cd ~ first
                            • E
                              @strawberry-3.141
                              pi@raspberrypi:~ $ cd ~
                              pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
                              bash: cd: No such file or directory
                              pi@raspberrypi:~ $
                              Then I even went ahead and manually created that directory, and it still doesn’t work:
                              pi@raspberrypi:~ $ mkdir MagicMirror
                              pi@raspberrypi:~ $ ls
                              Desktop  Documents  Downloads  MagicMirror  Music  Pictures  Public  Templates  Videos
                              pi@raspberrypi:~ $
                              • strawberry 3.141S
                                @EttVenter just remove the directory magicmirror again that you created and run the command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash as it is in the readme after it was successful do cd MagicMirror
                                • E
                                  @strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
                                  cd MagicMirror
                                  That was going well until:
                                  npm ERR! cb() never called!
                                  Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
                                  I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
                                  • E
                                    EttVenter
                                    Good morning, folks.
                                    Anyone got any ideas?
                                    • strawberry 3.141S
                                      @EttVenter can you go into the cloned directory and run npm install manually, hopefully we get a more detailed error log then
                                      • E
                                        @strawberry-3.141
                                        Sure thing. Here’s the result:
                                        • E
                                          EttVenter
                                          Ok guys. So I nuked my previous raspbian install, and got a new one going. Managed to get an update node install, so things SEEM to be going better. Tried to install magic mirror again, and it went well until right at the end, when I got this:
                                          npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                                          npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                                          npm WARN prefer global colorguard@1.2.0 should be installed with -g
                                          And when I try to do a npm start, I get:
                                          > magicmirror@2.1.0 start /home/pi/MagicMirror
                                          > electron js/electron.js
                                          /home/pi/MagicMirror/node_modules/electron/index.js:9
                                            throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                                          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                                              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                                              at Module._compile (module.js:570:32)
                                              at Object.Module._extensions..js (module.js:579:10)
                                              at Module.load (module.js:487:32)
                                              at tryModuleLoad (module.js:446:12)
                                              at Function.Module._load (module.js:438:3)
                                              at Module.require (module.js:497:17)
                                              at require (internal/module.js:20:19)
                                              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                                          npm ERR! Linux 4.4.34-v7+
                                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                          npm ERR! node v6.10.0
                                          npm ERR! npm  v3.10.10
                                          npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                                          npm ERR!
                                          npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                                          npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                          npm ERR!     electron js/electron.js
                                          npm ERR!     npm bugs magicmirror
                                          npm ERR! Or if that isn't available, you can get their info via:
                                          npm ERR!     npm owner ls magicmirror
                                          I feel like I’m getting closer to making this thing actually work though. Any ideas?
                                          Thanks!
                                          • T
                                            TonyOtokia @EttVenter
                                            @EttVenter You are not alone this last set of errors is the same as I get, a have tried a number of times and get the same result
