    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 30.8k Views 7 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @EttVenter
      @EttVenter just remove the directory magicmirror again that you created and run the command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash as it is in the readme after it was successful do cd MagicMirror
      • E Offline
        EttVenter @strawberry 3.141
        @strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
        cd MagicMirror
        That was going well until:
        Cloning MagicMirror Done!
        Installing dependencies ...
        npm ERR! cb() never called!
        Unable to install dependencies!
        Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
        I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
        • E Offline
          EttVenter
          Good morning, folks.
          Anyone got any ideas?
            @EttVenter can you go into the cloned directory and run npm install manually, hopefully we get a more detailed error log then
            • E Offline
              @strawberry-3.141
              Sure thing. Here’s the result:
              pi@raspberrypi:~/MagicMirror $ npm install
              • E Offline
                EttVenter
                Ok guys. So I nuked my previous raspbian install, and got a new one going. Managed to get an update node install, so things SEEM to be going better. Tried to install magic mirror again, and it went well until right at the end, when I got this:
                npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                npm WARN prefer global colorguard@1.2.0 should be installed with -g
                And when I try to do a npm start, I get:
                > magicmirror@2.1.0 start /home/pi/MagicMirror
                > electron js/electron.js
                /home/pi/MagicMirror/node_modules/electron/index.js:9
                  throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                    at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                    at Module._compile (module.js:570:32)
                    at Object.Module._extensions..js (module.js:579:10)
                    at Module.load (module.js:487:32)
                    at tryModuleLoad (module.js:446:12)
                    at Function.Module._load (module.js:438:3)
                    at Module.require (module.js:497:17)
                    at require (internal/module.js:20:19)
                    at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                npm ERR! Linux 4.4.34-v7+
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                npm ERR! node v6.10.0
                npm ERR! npm  v3.10.10
                npm ERR! code ELIFECYCLE
                npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                npm ERR! not with npm itself.
                npm ERR!     electron js/electron.js
                npm ERR!     npm bugs magicmirror
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!     npm owner ls magicmirror
                npm ERR!     /home/pi/MagicMirror/npm-debug.log
                I feel like I’m getting closer to making this thing actually work though. Any ideas?
                Thanks!
                • T Offline
                  TonyOtokia @EttVenter
                  @EttVenter You are not alone this last set of errors is the same as I get, a have tried a number of times and get the same result
                  • T Offline
                    TonyOtokia
                    I don’t know why but after I got the same errors as your last post I did a reinstall and a firmware update and it worked.
                    • mpiresM Offline
                      mpires
                      Hi, same issue over here :(
                      Tony, did you wipe the SDcard and start all over? i’m about to do that, i have try a butch of things and i can’t pass this same error.
                      • mpiresM Offline
                        mpires
                        :D after fresh install the mirror did came to life :P
