    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 30.8k Views 7 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @EttVenter
      @EttVenter you have to use the | bash part, because what is doing is the following, curl will load the script from github and then you pipe it right into the bash command to execute the script otherwise you would just load the file
      E 1 Reply Last reply Reply Quote 1
      • E Offline
        EttVenter @strawberry 3.141
        @strawberry-3.141 Ok so what do I do then? Because if I run the command with the bash part of the command, it tells me “No such file or directory”. So how do I solve that?
          @EttVenter did you probably start the command from a wrong directory? do cd ~ first
          • E Offline
            @strawberry-3.141
            pi@raspberrypi:~ $ cd ~
            pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
            bash: cd: No such file or directory
            pi@raspberrypi:~ $
            Then I even went ahead and manually created that directory, and it still doesn’t work:
            pi@raspberrypi:~ $ mkdir MagicMirror
            pi@raspberrypi:~ $ ls
            Desktop  Documents  Downloads  MagicMirror  Music  Pictures  Public  Templates  Videos
            pi@raspberrypi:~ $
              @EttVenter just remove the directory magicmirror again that you created and run the command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash as it is in the readme after it was successful do cd MagicMirror
              • E Offline
                @strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
                cd MagicMirror
                That was going well until:
                Cloning MagicMirror Done!
                Installing dependencies ...
                npm ERR! cb() never called!
                Unable to install dependencies!
                Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
                I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
                • E Offline
                  EttVenter
                  Good morning, folks.
                  Anyone got any ideas?
                    @EttVenter can you go into the cloned directory and run npm install manually, hopefully we get a more detailed error log then
                    • E Offline
                      @strawberry-3.141
                      Sure thing. Here’s the result:
                      pi@raspberrypi:~/MagicMirror $ npm install
                      • E Offline
                        EttVenter
                        Ok guys. So I nuked my previous raspbian install, and got a new one going. Managed to get an update node install, so things SEEM to be going better. Tried to install magic mirror again, and it went well until right at the end, when I got this:
                        npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                        npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                        npm WARN prefer global colorguard@1.2.0 should be installed with -g
                        And when I try to do a npm start, I get:
                        > magicmirror@2.1.0 start /home/pi/MagicMirror
                        > electron js/electron.js
                        /home/pi/MagicMirror/node_modules/electron/index.js:9
                          throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                        Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                            at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                            at Module._compile (module.js:570:32)
                            at Object.Module._extensions..js (module.js:579:10)
                            at Module.load (module.js:487:32)
                            at tryModuleLoad (module.js:446:12)
                            at Function.Module._load (module.js:438:3)
                            at Module.require (module.js:497:17)
                            at require (internal/module.js:20:19)
                            at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                        npm ERR! Linux 4.4.34-v7+
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                        npm ERR! node v6.10.0
                        npm ERR! npm  v3.10.10
                        npm ERR! code ELIFECYCLE
                        npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                        npm ERR! not with npm itself.
                        npm ERR!     electron js/electron.js
                        npm ERR!     npm bugs magicmirror
                        npm ERR! Or if that isn't available, you can get their info via:
                        npm ERR!     npm owner ls magicmirror
                        npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        I feel like I’m getting closer to making this thing actually work though. Any ideas?
                        Thanks!
                        • T Offline
                          TonyOtokia @EttVenter
                          @EttVenter You are not alone this last set of errors is the same as I get, a have tried a number of times and get the same result
                          • T Offline
                            TonyOtokia
                            I don’t know why but after I got the same errors as your last post I did a reinstall and a firmware update and it worked.
                            • mpiresM Offline
                              mpires
                              Hi, same issue over here :(
                              Tony, did you wipe the SDcard and start all over? i’m about to do that, i have try a butch of things and i can’t pass this same error.
                              • mpiresM Offline
                                mpires
                                :D after fresh install the mirror did came to life :P
