    Total n00b and can't get this thing to work. Please help!
    35 Posts 8 Posters 31.6k Views 7 Watching
    • E
      EttVenter @strawberry 3.141
      @strawberry-3.141
      pi@raspberrypi:~ $ cd ~
      pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash cd ~/MagicMirror
      bash: cd: No such file or directory
      pi@raspberrypi:~ $
      Then I even went ahead and manually created that directory, and it still doesn’t work:
      pi@raspberrypi:~ $ mkdir MagicMirror
      pi@raspberrypi:~ $ ls
      Desktop  Documents  Downloads  MagicMirror  Music  Pictures  Public  Templates  Videos
      pi@raspberrypi:~ $
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @EttVenter
        @EttVenter just remove the directory magicmirror again that you created and run the command curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash as it is in the readme after it was successful do cd MagicMirror
        E 1 Reply Last reply
        • E
          @strawberry-3.141 said in Total n00b and can’t get this thing to work. Please help!:
          cd MagicMirror
          That was going well until:
          Cloning MagicMirror Done!
          Installing dependencies ...
          npm ERR! cb() never called!
          Unable to install dependencies!
          Honestly, this process is awful. “All you need to do is run 1 command!”. 1 command my ass. I’ve been fidgeting with this thing for a full day and I haven’t even got this frikken thing installed yet.
          I’m really, really stoked that you guys are all helping me. Really. And I know that we’ll get this thing working. But the “packaging” kinda lied to me.
          • E
            EttVenter
            Good morning, folks.
            Anyone got any ideas?
            • strawberry 3.141S
              @EttVenter can you go into the cloned directory and run npm install manually, hopefully we get a more detailed error log then
              • E
                @strawberry-3.141
                Sure thing. Here’s the result:
                pi@raspberrypi:~/MagicMirror $ npm install
                • E
                  EttVenter
                  Ok guys. So I nuked my previous raspbian install, and got a new one going. Managed to get an update node install, so things SEEM to be going better. Tried to install magic mirror again, and it went well until right at the end, when I got this:
                  npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                  npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                  npm WARN prefer global colorguard@1.2.0 should be installed with -g
                  And when I try to do a npm start, I get:
                  > magicmirror@2.1.0 start /home/pi/MagicMirror
                  > electron js/electron.js
                  /home/pi/MagicMirror/node_modules/electron/index.js:9
                    throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
                  Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                      at Module._compile (module.js:570:32)
                      at Object.Module._extensions..js (module.js:579:10)
                      at Module.load (module.js:487:32)
                      at tryModuleLoad (module.js:446:12)
                      at Function.Module._load (module.js:438:3)
                      at Module.require (module.js:497:17)
                      at require (internal/module.js:20:19)
                      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                  npm ERR! Linux 4.4.34-v7+
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                  npm ERR! node v6.10.0
                  npm ERR! npm  v3.10.10
                  npm ERR! code ELIFECYCLE
                  npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  npm ERR! not with npm itself.
                  npm ERR!     electron js/electron.js
                  npm ERR!     npm bugs magicmirror
                  npm ERR! Or if that isn't available, you can get their info via:
                  npm ERR!     npm owner ls magicmirror
                  npm ERR!     /home/pi/MagicMirror/npm-debug.log
                  I feel like I’m getting closer to making this thing actually work though. Any ideas?
                  Thanks!
                  T 1 Reply Last reply
                  • T
                    TonyOtokia @EttVenter
                    @EttVenter You are not alone this last set of errors is the same as I get, a have tried a number of times and get the same result
                    • T
                      TonyOtokia
                      I don’t know why but after I got the same errors as your last post I did a reinstall and a firmware update and it worked.
                      • mpiresM
                        mpires
                        Hi, same issue over here :(
                        Tony, did you wipe the SDcard and start all over? i’m about to do that, i have try a butch of things and i can’t pass this same error.
                        • mpiresM
                          mpires
                          :D after fresh install the mirror did came to life :P
