    Weather Underground Forecast (wuforecast)
    14 Posts 9 Posters 15.1k Views 6 Watching
      mattlugar
      I was thinking about doing a dual-mod, but honestly there’s no advantage over having two separate mods. The json streams for the current weather and the forecast are separate on Weather Underground, so there’s no advantage on reducing the number of network/API calls. Secondly, it reduces flexibility as far as screen positioning of the mods goes (you’d have to keep them together in the same part of the screen).
      I’m pretty close to finishing my mod for getting current conditions from WU as well. I’m using JSON right now, but I’m trying to see if there’s a way to tap into the ‘realtime’ stream that they use for their flash gadgets that you can put on websites. Not sure if it is possible yet though.
      RedNaxR 1 Reply Last reply Reply Quote 0
      • RedNaxR Offline
        RedNax Module Developer @mattlugar
        @mattlugar
        No they’re not… They CAN be if you so desire, but you can combine several queries into one request…
        mine is /conditions/forecast10day/astronomy/ Which will give you current conditions, 10 day forecast and sun-/moon rise/set info in one payload.
          mattlugar @RedNax
          @RedNax Oh cool, didn’t even realize you could embed multiple API calls at the same time!!! :)
            jamesbond0
            do you have an example of the custom.css for the different colors (sun, rain, etc.).
            I did not get.
            greeting
            Stephan
              jghansen09
              I am very new to this (only have experience with VBA, simple C+ from using MATLAB, you get the point).
              I used git clone https://github.com/MattLugar/wuforecast to download the files to my modules directory then changed the default weather module to the wuforecast module in the config.js file. However, when I run the Mirror program I get a completely black screen.
              All of the files appear to have been downloaded correctly to the directory and I cant find any syntax errors in the config.js file. I wrote everything exactly as follows:
                      module: 'wuforecast',
                      position: 'top_right',  // This can be any of the regions.
                                                  // Best results in left or right regions.
                          appid: 'abcde12345abcde12345abcde12345ab' //wunderground.com API key.
              Any help?
              Thank you!
              • RedNaxR Offline
                If this is your entire config file, than it’s to be expected it doesn’t work…
                Should be something like this (using thhe sample as an …example):
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                    port: 8080,
                    language: 'en',
                    timeFormat: 24,
                    units: 'metric',
                    modules: [{
                        module: 'alert',
                        module: ‘wuforecast’,
                        position: ‘top_right’, // This can be any of the regions.
                            // See ‘Configuration options’ for more information.
                            appid: ‘abcde12345abcde12345abcde12345ab’ //wunderground.com API key.
                        module: 'clock',
                        position: 'top_left'
                        module: 'calendar',
                        header: 'US Holidays',
                        position: 'top_left',
                            calendars: [{
                                symbol: 'calendar-check-o ',
                        module: 'compliments',
                        position: 'lower_third'
                        module: 'currentweather',
                            locationID: '', //ID from bulk.openweather.org/sample/
                            appid: 'YOUR_OPENWEATHER_API_KEY'
                        module: 'weatherforecast',
                        header: 'Weather Forecast',
                            locationID: '5128581', //ID from bulk.openweather.org/sample/
                        module: 'newsfeed',
                        position: 'bottom_bar',
                            feeds: [{
                                title: "New York Times",
                            showSourceTitle: true,
                            showPublishDate: true
                if (typeof module !== 'undefined') {
                    module.exports = config;
                  jghansen09 @RedNax
                  @RedNax
                  That was not my entire config file, just the part inserting the wuforecast module. However I deleted and cloned the wuforecast files again without changing my config file and it works fine now. Any idea as to why that might have been?
                  Thank you for the reply!
                    Andrew
                    I had the same problem, but I found the solution:
                    You had to put the api key wuforecast and the location in config file and in wuforecast.js file .
                    After that worked.
                      cloudzombie
                      Anybody that can help me config this for a US city would be much obliged, I have tried several different ways of displaying the city based on whats in the README, but it doesn’t work since I have a single name city the README says to list it as
                      ‘NY/New_York’
                      I am in Portland, Oregon, and have tried:
                      Portland/Oregon
                      portland/oregon
                      portland/Oregon
                      None of the above work. IS their some secret city code buried somewhere I can’t find?
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @cloudzombie
                        @cloudzombie it must be the state and then the city try OR/Portland
