Error by install MMM-Swipe
7 Posts 2 Posters 2.6k Views 1 Watching
  • F Offline
    fischi87
    Hello im new in this forum. My name is Axel and im from Germany so my english ist not the yellow from the egg :-) i hope u can understand me. first of all, a really great thanks for the boys who create the magic mirror, its really unbelievable, respect!!!
    i installed already the magic mirror 2 and same modules witch work really nice and everything is good but today i tried to install the model Swipe and i get a error, this one:
    pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ npm install
    > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-Swipe
    > electron-rebuild -e ../../node_modules/electron-prebuilt
    An unhandled error occurred inside electron-rebuild
    Unable to find electron-prebuilt's version number, either install it or specify an explicit version
    Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
        at _callee$ (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:74:17)
        at tryCatch (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
        at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
        at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
        at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/util.js:16:23)
        at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:97:49)
        at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:201:15
        at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:197:4)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions..js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        at Module.runMain (module.js:604:10)
        at run (bootstrap_node.js:394:7)
        at startup (bootstrap_node.js:149:9)
    npm ERR! Linux 4.4.38-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
    npm ERR! node v6.10.0
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
    npm ERR! Exit status 255
    npm ERR!
    npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
    npm ERR! If you do, this is most likely a problem with the MMM-Swipe package,
    npm ERR! not with npm itself.
    npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
    npm ERR!     npm bugs MMM-Swipe
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls MMM-Swipe
    npm ERR!     /home/pi/MagicMirror/modules/MMM-Swipe/npm-debug.log
    someone a idea? i hope someone can help me.
    thank u very much!!!
    B 1 Reply Last reply Feb 23, 2017, 8:36 PM Reply Quote 0
      broberg Project Sponsor @fischi87
      @fischi87 did you read and follow the instructions correctly for MMM-swipe?
      I e did you run npm install in the MMM-swipe folder?
      • F Offline
        fischi87
        yes of course, u don’t see it in the code?
        B 1 Reply Last reply Feb 23, 2017, 8:39 PM Reply Quote 0
          @fischi87 to me it looks like the dependecies isn’t installed at all
          • F Offline
            fischi87
            ? and what i have to do right now?
            when i run
            sudo npm start
            i get back
            pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ sudo npm start
            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
            npm ERR! missing script: start
            npm ERR!
            npm ERR! If you need help, you may report this error at:
            npm ERR!     <https://github.com/npm/npm/issues>
            what is here wrong?!
              You are in the wrong folder if you want to start the mirror with sudo npm start
              F 1 Reply Last reply Feb 23, 2017, 10:41 PM Reply Quote 0
              • F Offline
                fischi87 @broberg
                @broberg
                i get the same in the MagicMirror folder
                pi@Magic-Mirror:~/MagicMirror $ sudo npm start
                > magicmirror@2.1.0 start /home/pi/MagicMirror
                > electron js/electron.js
                npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                npm ERR!     electron js/electron.js
                npm ERR!     npm bugs magicmirror
                npm ERR!     npm owner ls magicmirror
                npm ERR!     /home/pi/MagicMirror/npm-debug.log
