    Error by install MMM-Swipe
    7 Posts 2 Posters 2.7k Views 1 Watching
    • F Offline
      fischi87
      Hello im new in this forum. My name is Axel and im from Germany so my english ist not the yellow from the egg :-) i hope u can understand me. first of all, a really great thanks for the boys who create the magic mirror, its really unbelievable, respect!!!
      i installed already the magic mirror 2 and same modules witch work really nice and everything is good but today i tried to install the model Swipe and i get a error, this one:
      pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ npm install
      > MMM-Swipe@1.1.1 postinstall /home/pi/MagicMirror/modules/MMM-Swipe
      > electron-rebuild -e ../../node_modules/electron-prebuilt
      An unhandled error occurred inside electron-rebuild
      Unable to find electron-prebuilt's version number, either install it or specify an explicit version
      Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
          at _callee$ (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:74:17)
          at tryCatch (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
          at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
          at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
          at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/util.js:16:23)
          at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:97:49)
          at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/bluebird/js/release/generators.js:201:15
          at Object. (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/cli.js:197:4)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.runMain (module.js:604:10)
          at run (bootstrap_node.js:394:7)
          at startup (bootstrap_node.js:149:9)
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! node v6.10.0
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
      npm ERR! If you do, this is most likely a problem with the MMM-Swipe package,
      npm ERR! not with npm itself.
      npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
      npm ERR!     npm bugs MMM-Swipe
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls MMM-Swipe
      npm ERR!     /home/pi/MagicMirror/modules/MMM-Swipe/npm-debug.log
      someone a idea? i hope someone can help me.
      thank u very much!!!
      • brobergB Offline
        broberg Project Sponsor @fischi87
        @fischi87 did you read and follow the instructions correctly for MMM-swipe?
        I e did you run npm install in the MMM-swipe folder?
        • F Offline
          fischi87
          yes of course, u don’t see it in the code?
          • brobergB Offline
            @fischi87 to me it looks like the dependecies isn’t installed at all
            • F Offline
              fischi87
              ? and what i have to do right now?
              when i run
              sudo npm start
              i get back
              pi@Magic-Mirror:~/MagicMirror/modules/MMM-Swipe $ sudo npm start
              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
              npm ERR! missing script: start
              npm ERR!
              npm ERR! If you need help, you may report this error at:
              npm ERR!     <https://github.com/npm/npm/issues>
              what is here wrong?!
              • brobergB Offline
                You are in the wrong folder if you want to start the mirror with sudo npm start
                • F Offline
                  fischi87 @broberg
                  @broberg
                  i get the same in the MagicMirror folder
                  pi@Magic-Mirror:~/MagicMirror $ sudo npm start
                  > magicmirror@2.1.0 start /home/pi/MagicMirror
                  > electron js/electron.js
                  npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                  npm ERR!     electron js/electron.js
                  npm ERR!     npm bugs magicmirror
                  npm ERR!     npm owner ls magicmirror
                  npm ERR!     /home/pi/MagicMirror/npm-debug.log
