    Display what would you buy?
    26 Posts 6 Posters 16.8k Views 5 Watching
    • slametpsS Offline
      slametps @wizz
      @wizz no, You don’t need VGA-HDMI adapter. Bigger, Better?
      regards,
      Slamet PS
      • W Offline
        wizz
        Ok than i go for the 17,3 inch display.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @wizz
          @wizz said in Display what would you buy?:
          mine is 24".
          regards,
          Slamet PS
          • W Offline
            wizz
            Was looking at this but about this? LCDs Normally White vs Normally Black as the bigger is normaly white and the smaller is normaly black ? Can some one explain if this is an issue using it for an Magic Mirror?
              Sultan91
              How do you thing is it safe to buy power supply separately from monitor, could you provide some links to them?
              • W Offline
                wizz
                You can use any one that is like this image
                https://ae01.alicdn.com/img/pb/240/342/905/905342240_520.jpg
                Or just buy this one.
                https://www.aliexpress.com/item/CE-Approval-Universal-12V-4A-Power-Supply-Adapter-Transformer-With-LED-EU-Plug-Cord-Esp-for/32610160065.html?spm=2114.13010208.99999999.268.hCoDaW
                • O Offline
                  ottobot @wizz
                  @wizz I was mentioning the vga adapter if you went with one of the cheaper monitors that don’t have hdmi input…
                  • W Offline
                    wizz
                    Ok that wold work for me to.
                    Have to check as it is hard do find the separate parts that i need.
                    @ottobot do you got some links for me on Aliexpress that you think wold be good for my project?
                    • brobergB Offline
                      broberg Project Sponsor
                      https://www.proshop.se/Bildskaerm/Neovo-17-Bildskaerm-C-17P-Svart-3-ms-/2496928?utm_source=prisjakt&utm_medium=cpc&utm_campaign=pricesite
                      Buying bigger things outside the EU you will have to pay toll and taxes on it. Not worth it.
                      Or Try finding a used monitor with hdmi on www.blocket.se
                      The small ones usually are dirt cheap!
                      The LED monitors often has a stronger light output/contrast are therefor better suited for a magicmirror, but a normal tft/ccfl screen works also. It’s more up to the lighttransmissin of your mirror in the end.
                      • W Offline
                        wizz
                        @broberg That i know and the thing is that i want the mirror to be only seven centimeters thick as the location where it will hang it on the wall don´t let me have a thicker frame so this is why i try to find the best solution.
