    Display what would you buy?
    26 Posts 6 Posters 19.2k Views 5 Watching
    • W
      wizz
      Why do i need a VGA to HDMI adapter? As my RPI got HDMI and the controller board have that to as you see in the description of the screen.
      I dont have Newegg in Sweden so thats not an option.
      slametpsS O 2 Replies Last reply Reply Quote 0
      • slametpsS
        slametps @wizz
        @wizz no, You don’t need VGA-HDMI adapter. Bigger, Better?
        regards,
        Slamet PS
        • W
          wizz
          Ok than i go for the 17,3 inch display.
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS
            slametps @wizz
            @wizz said in Display what would you buy?:
            mine is 24".
            regards,
            Slamet PS
            • W
              wizz
              Was looking at this but about this? LCDs Normally White vs Normally Black as the bigger is normaly white and the smaller is normaly black ? Can some one explain if this is an issue using it for an Magic Mirror?
                Sultan91
                How do you thing is it safe to buy power supply separately from monitor, could you provide some links to them?
                • W
                  wizz
                  You can use any one that is like this image
                  https://ae01.alicdn.com/img/pb/240/342/905/905342240_520.jpg
                  Or just buy this one.
                  https://www.aliexpress.com/item/CE-Approval-Universal-12V-4A-Power-Supply-Adapter-Transformer-With-LED-EU-Plug-Cord-Esp-for/32610160065.html?spm=2114.13010208.99999999.268.hCoDaW
                  • O
                    ottobot @wizz
                    @wizz I was mentioning the vga adapter if you went with one of the cheaper monitors that don’t have hdmi input…
                    • W
                      wizz
                      Ok that wold work for me to.
                      Have to check as it is hard do find the separate parts that i need.
                      @ottobot do you got some links for me on Aliexpress that you think wold be good for my project?
                        broberg Project Sponsor
                        https://www.proshop.se/Bildskaerm/Neovo-17-Bildskaerm-C-17P-Svart-3-ms-/2496928?utm_source=prisjakt&utm_medium=cpc&utm_campaign=pricesite
                        Buying bigger things outside the EU you will have to pay toll and taxes on it. Not worth it.
                        Or Try finding a used monitor with hdmi on www.blocket.se
                        The small ones usually are dirt cheap!
                        The LED monitors often has a stronger light output/contrast are therefor better suited for a magicmirror, but a normal tft/ccfl screen works also. It’s more up to the lighttransmissin of your mirror in the end.
                        • W
                          wizz
                          @broberg That i know and the thing is that i want the mirror to be only seven centimeters thick as the location where it will hang it on the wall don´t let me have a thicker frame so this is why i try to find the best solution.
                            broberg Project Sponsor @wizz
                            @wizz okey, so a maximum depth of 5cm for the screen then? what is the maximum width and height for the screen?
                            And about the color of the frame, it should not be an issue, if it is, just use some “eltejp” or black vinyl, or just paint it black.
                            • W
                              wizz
                              @broberg thats right and the width maximum is 40 - 42 cm and height is 80 - 85cm it will hang in my kitchen beside the door on a small wall where i also got the kitchen cabinet whit a door that have to be possible to open so it is a small area i have.
                                @wizz Okey, so how about this one then :
                                https://www.dustinhome.se/product/5010887463/gw2470h?ssel=false&utm_campaign=prisjakt&utm_source=prisjakt.nu&utm_medium=pricecompare&utm_content=5637146247
                                51mm thick, 553mm wide and 329mm high.
                                Turn it on it’s side and you get 329mm wide and 553mm high.
                                And it will cost you the same (or less if we count the toll costs) as the aliexpress 17.3 lcd panel
                                  @wizz or maybe this one :
                                  https://www.webhallen.com/se-sv/datorer_och_tillbehor/215664-aoc_e2476vwm6_236-1ms-vga_hdmi-vesa&atcl=external:ref
                                  41mm deep, 558mm by 335mm
                                  And it was cheaper still :D
                                  • W
                                    wizz
                                    @broberg Thanks for the links will try to get by Webhallen today on my way home from work :)
                                    • W
                                      wizz
                                      @broberg what do you think about this? https://www.netonnet.se/art/dator/bildskarm/23-24tum/aoc-e2470swda/220402.8903/
                                      I can not find how deep it is?
                                        @wizz neither can I the manufacturer doesn’t even specify it. But it doesn’t have a hdmi input, so it would need an adapter.
                                        • W
                                          wizz
                                          @broberg Yes i found out that to so it will not be that one.
                                          • W
                                            wizz
                                            @broberg got a Benq to a nice price at Inet.se they had one for 20% lower price than the regular 1199:-
