    New windows, NOT full size
    7 Posts 3 Posters 4.2k Views 2 Watching
    • brobergB Offline
      broberg Project Sponsor @mortenbirkelund
      @mortenbirkelund why not use an iframe? That way you could still have a lot of the other modules visible as well and you could put a timer on it so if you don’t close it it closes itself.
        roramirez Core Contributors @mortenbirkelund
        @mortenbirkelund There are options of Electron when you did run
        npm start
        Check out the item for electronOptions
        https://github.com/MichMich/MagicMirror/tree/develop#configuration
          mortenbirkelund @broberg
          @broberg As far as I could see, Iframe was not and option, due to cross-origin limitations…
            mortenbirkelund @roramirez
            @roramirez but isnt that only for the MagicMirror window? I still want the MagicMirror window to to be fullscreen. I would just like to be able of opening a window that is not full screen.
            Or have i misunderstood the electronOptions?
              @roramirez said in New windows, NOT full size:
              Electron
              Could you please elaborate on ow i could use the Electron to open a browser window that is not full size, even though the magic Mirror browser is in full size?
                Well, It’s something at now I dont know how figure out.
                If main Electron MagicMIrrror app is starter in FullScreen Mode, without menu bar, etc… I think is not possible -maybe yes- create a new window with these attributes and not full screen.
                Please can you check this
                https://github.com/electron/electron/blob/master/docs/api/window-open.md
                Also, by a way is necessary set the Node Integration
