    adjusting reloadInterval
    6 Posts 3 Posters 2.6k Views 2 Watching
      Richard238
      If a realoadInterval of 60*1000 = one minute, how do I change it to reload at different intervals?
      I’ve tried various combinations of 3/10/30*1000, even change 1000 to 100.
      Save the .js and then ‘npm start’, but the refresh is still one minute.
      Is refresh controlled from elsewhere?
      Thank you.
        Richard238 @Richard238
        Resolved.
        Changed setting in config.js, module now updating at the frequency required.
        Thank you.
        • CatoC Offline
          Cato Module Developer
          Have you configured to start mirror with pm2? If so you have to restart with pm2 restart mm
            Richard238 @Cato
            @Cato No, I’m not using PM2
            • brobergB Offline
              broberg Project Sponsor @Richard238
              @Richard238 many modules have set a minimum reloadinterval to 10seconds and that can’t be changed unless you change the if statement that controls it.
              And if you are working directly on the pi you can just reload the page by pressing ctrl+r
              The only time I have needed to restart it completly is when messing with the code of the node_helper file
                Richard238
                It’s in a bespoke module, created by Gordon(izanbard)
                Module.register("MMM-MyTemps", {
                    defaults: {
                        host: "192.168.1.41",
                        path: "/temp2mcf.php?format=json",
                        reloadInterval: 60 * 1000 //1 min
                Module works fine, but I’d like it to reload more frequently.
                  Resolved.
                  Thank you.
