    PIR Sensor turning display on/off over and over
    29 Posts 13 Posters 27.2k Views 13 Watching
    • E Offline
      elmerito25 @cowboysdude
      @cowboysdude said in PIR Sensor turning display on/off over and over:
      @Renfield said in PIR Sensor turning display on/off over and over:
      It might be interference. Try installing a ferrite bead. The person whose site I’ve linked below had a very similar problem and describes how he fixed it.
      https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/
      Renfield
      It’s what I had to do with mine… they are very inexpensive…
      Thanks guys! Will try this once I get home tonight!
      E 1 Reply Last reply Reply Quote 1
      • E Offline
        elmerito25 @elmerito25
        @elmerito25 said in PIR Sensor turning display on/off over and over:
        Renfield
        Thanks @Renfield and @cowboysdude ! Followed your advice and found a ferrite bead on unused USB cable and got the PIR sensor working perfectly!
          Renfield
          Great to hear. I love it when a plan comes together.
          Now I need to scrounge up a bead for my build.
          Ren
          • H Offline
            hermlam
            Hi all,
            Thanks for the reactions. I ordered one and will test tomorrow.
            Herman
              cyberphox
              i gave up on my PIR sensor cause this was happening to me…guess who is searching for a Ferrite bead tomorrow!!!
              • johnnyboyJ Offline
                johnnyboy @Renfield
                  phrazelle
                  FWIW, a ferrite bead is a working solution, but I was able to circumvent this issue by keeping the PIR Sensor a good distance from the Pi. Mine is about 3 feet away from the Pi and doesn’t act erratically as it did when it was right next to it during testing.
                  johnnyboyJ H 2 Replies Last reply Reply Quote 3
                    johnnyboy @phrazelle
                      Jay
                      Similar problem here, PIR works like a charm (tested with code of post #4) but after starting the MagicMirror the display is turned off and on over and over even though nothing is changed in front of the sensor. (I use MMM-PIR).
                      • H Offline
                        hermlam @phrazelle
                        @phrazelle Since I am having a ‘cordless’ mirror (power is coming from wall behind mirror) I don’t want to see cables to my mirror. I’ve build the PIR into the frame of my mirror.
                        • H Offline
                          hermlam
                          Even with the bead installed I have various results. Sometimes it’s running ok for an hour or so, but most of the time I’m getting a lot of false positives. And very strange, only with the output timer (2nd yellow knob) on minimal it’s working ok. But then the screen lits up far too short. But output time has nothing to do with it?
                            Jay
                            Basically I had the same error with the display turning on and off over time. All in anger, I deinstalled the MagicMirror from the Pi and began at zero again.
                            After updating and upgrading the Pi and installing the MagicMirror, a new try with the PIR-Module was iniciated. So I installed the PIR-Module and somehow noticed that my GPIO cables were wrong connected (ground connected to GPIO21 and vice-versa).
                            So after this embarassing moment of disbelieve I changed the connections and checked if the sensor is working with a simple python script:
                            from gpiozero import MotionSensor
                            import time
                            pir = MotionSensor(21)
                            while True: #repeat this forever
                                if pir.motion_detected: # if motion is detected print the message
                                    print("Motion detected!")
                                if not pir.motion_detected: # if no motion is detected print the message
                                    print("No motion detected!")
                                time.sleep(1)
                            Note that my pir is using GPIO21.
                            With this script I tested the sensor and it worked like a charm, even though the sensor is placed 5 centimeters away from the raspberry pi 3 (with no case or even a bead installed).
                            In the end, I only had to do a cd MagicMirror again, and install the MagicMirror:
                            npm install. With this setup the MMM-PIR-module works magnificient.
                              deepshades @Jay
                              @Jay
                              Hi Jay, can you reply a link to your PIR module you finaly use?
                                Jay @deepshades
                                @deepshades
                                Basically its just the standard PIR-Sensor shipped with female to female gpio connections (PIR-Sensor Amazon).
                                  deepshades @Jay
                                  @Jay
                                  Ok, so you just use a script to let the sensor deactivate the hdmi output?
                                  Could you tell me the steps to let all work together?
                                    Jay @deepshades
                                    @deepshades
                                    Well ok…
                                    step 1: get nodejs and npm --> sudo apt-get install nodejs then sudo apt-get install npm
                                    step 2: update + upgrade the pi --> sudo apt-get update then sudo apt-get dist-upgrade
                                    step 3: install MagicMirror --> as seen here MagicMirror Github Page
                                    step 4: connect the PIR-Sensor to your Pi --> ground to ground (e.g. Pin 6), VCC to 5V (e.g. Pin 2), Out to GPIO XX (e.g. Pin 16)
                                    step 5: check if PIR-Sensor works --> as seen at my script above (watch your connected GPIO pin, maybe change in script is required) --> some fiddling with sensitivity knobs here is needed
                                    step 6: install MMM-PIR --> MMM-PIR Github Page
                                    step 7: reboot and reinstall MagicMirror in MagicMirror directory --> cd MagicMirror and npm install
                                    this has worked for me…
                                    johnnyboyJ 1 Reply Last reply Reply Quote 1
                                      johnnyboy @Jay
                                        Jay @johnnyboy
                                        @johnnyboy
                                        The steps I described started after a succesfully installation of the operating system on the pi, so with no MagicMirror installed --> step 3 is the first time MM is installed.
                                        These are the steps which worked for me, somehow after the second install of the MagicMirror (step 7) the PIR worked --> this step could be obsolete for others, thats just what i did experience.
                                          johnnyboy @Jay
                                          • jproehlJ Offline
                                            jproehl
                                            Hi: I’m having the same problem with the PIR sensor module - when motion is detected the screen comes on for about 1 sec and then shuts off. It operates like that for a minute or so and then begins to not respond or responds intermittently to motion. I’ve added a magnet ring, updated the OS and the MMM-PIR module, but still have the same issues. Any ideas what I should check? Thx!
