    Alexa or Jasper?
    6 Posts 2 Posters 6.2k Views 3 Watching
    • MitchfarinoM Offline
      Mitchfarino Module Developer
      Does anyone have any experience of setting up either of these services on your pi?
      Would you recommend either of them?
      I have only found out of date tutorials for jasper, and not sure if Alexa will work in the UK
      Any feedback or comments you have would be appreciated
      mochmanM 1 Reply Last reply Reply Quote 0
      • mochmanM Offline
        mochman Module Developer @Mitchfarino
        @Mitchfarino I set up my pi like in the video from this post.
        I used this switch, since it has a RGB led built into the ring for display indications. Alexa works pretty well, but I haven’t tried to integrate that into the magicmirror program. I’m just using it as a separate feature.
        There is another post that talks about voice control. Near the end they have a link with someone setting up Jasper on their raspberry pi.
        Obviously they’re two different services. I like Alexa since it’s not always listening (Hence the button). Some people like the Jasper “always on” feature much like “ok google” or whatever you say to start siri. I recommend taking a look at both to see which better suits you.
        MitchfarinoM 1 Reply Last reply Reply Quote 0
          I’m thinking Alexa, just so I can get it to play music through my prime subscription.
          I don’t have a button yet.
          I’m not looking to integrate it in to the mirror, just have it running in the background if possible.
          I tried installing Jasper last night, but the links on that howchoo site are out of date so I gave up.
            Mitchfarino Module Developer @mochman
            @mochman Could you use your Swipe module instead of a button?
            • mochmanM Offline
              @Mitchfarino Yeah, I’m going to have to tweak the code for the the swipe module though. Right now it puts out a press for 1 second. Alexa needs you to hold down the button for your entire question.
                @mochman Check this out too - https://forum.magicmirror.builders/topic/257/raspberrypi_ai
