    IR Frame doesn't rotate
    24 Posts 7 Posters 22.1k Views 8 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Snille
      @Snille
      Edit the file:
      sudo crontab -e
      Add line to file (here a python script):
      @reboot python3 /home/pi/Desktop/example.py &
      SnilleS peemoellerP 2 Replies Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @cowboysdude
        @cowboysdude It worked when added to a sh script! Good call! :) Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
        nano ~/xin.sh
        Then added
        DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
        There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
        You can actually find the “name” of the device with this command DISPLAY=:0.0 xinput list
        Shows something like this:
        ⎡ Virtual core pointer id=2 [master pointer (3)]
        ⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
        ⎜ ↳ Multi touch Multi touch overlay device id=6 [slave pointer (2)]
        ⎣ Virtual core keyboard id=3 [master keyboard (2)]
        ↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
        Depending on what you have connected to your RPi. :)
        So, after creating the xin.sh I added that to the autostart file for LXDE:
        Like this:
        nano ~/.config/lxsession/LXDE/autostart
        Added at the end of the file.
        @/home/pi/xin.sh
        Restarted and it works. :)
          @Snille Oddly enough you may have accidently solved my problem too! :) I’m getting a 32" IR touch frame… this may work for me as well!! So Thank you! :)
          What kind of IR touch frame do you have and where did you get it?
          Thanks!
          SnilleS 1 Reply Last reply Reply Quote 0
          • SnilleS Offline
            @cowboysdude I bought this one: https://www.aliexpress.com/item/32-points-32-Inch-IR-Multi-touch-overlay-kit-without-glass-for-Interactive-Table-Multi-Touch/1195149819.html
            And I can actually “zoom” the on the mirror (in the electron browser) which means that multitouch works (at least for two points). :)
              @Snille said in IR Frame doesn’t rotate:
              That’s AWESOME … Thank you soooooooooo much… That’s the one I am ordering too!! WOW that’s just amazing how things work out…
              What kind of glass did you get for it?
              • SnilleS Offline
                @cowboysdude Hehe, I’m still waiting for my mirror. Have not yet tested with any glass, just have it leaned against the monitor right now. :) I hope my work can supply a Pilkington MirrorView mirror, if not that’s what I’m going to buy.
                  OH that’ll be very cool! I have a 7" touch clock and bathroom mirror already built. This is a 32" ‘command center’ for the house… so no mirror but as I have read I need to use tempered glass so when the frame comes in I’ll take it there and get the glass for it :)
                  How long did it take to get after you ordered it?
                  • SnilleS Offline
                    @cowboysdude Actually it was quite fast only 8 days! :)
                      @Snille I’m happy :) Thank you!
                        spacevolt
                        Hi guys!
                        So I am ordering this one soon
                        https://www.aliexpress.com/store/product/Free-Shipping-32-Infrared-Touch-screen-Frame-with-4-point-Touches-Quick-Response/922495_32752894952.html?spm=2114.12010612.0.0.F1YMw5
                        Is it the same frame model as the one you guys got? (just smaller) Can one of you confirm? Excited to add touchscreen to the mirror! Thanks!
                          cowboysdude Module Developer @spacevolt
                          @spacevolt Not sure it’s the same model but it should work the same :) If you’re running raspberry pi [Linux] you’ll only have one point of touch… under windows it’s more but Linux is one. But one should be enough.
                          • peemoellerP Offline
                            peemoeller @cowboysdude
                            @cowboysdude I have the IR frame and xinput installed but not sure where to edit the crontab -e. I am a little new to this, are you able to give me some step by step directions to help rotate my IR touch frame?
                            Appreciate any help! Thanks :)
