    Display values from a JSON file hosted online
    10 Posts 4 Posters 5.9k Views 4 Watching
    • yawnsY Offline
      yawns Moderator @looolz
      Glad it gets you going. Of course you can add more divs/spans or even a table to place your output and adjust proper css to single lines or values.
      If you need explanation of single commands or routines just let us know.
      @looolz said in Display values from a JSON file hosted online:
      @yawns HAVE MY BABIES!
      I doubt my wife would be happy with that :rofl:
      • L Offline
        looolz
        You are very kind!
        I’ve got a couple of issues so far:
        1: The module doesn’t seem to survive a manual refresh. For some reason, if I hit CTRL R to refresh, all other modules load, but this one is stuck at “loading…” If I do CTRL Q, quit the Magic Mirror and try again, it works. Even more strangely, it does correctly update on it’s own, when the JSON file changes. Just a minor thing.
        2: I’ve been trying to create en separate class for the value, so that I can style the number individually. So I tried to create an element that I can style with xlarge from the css file. But so far I’ve only been able to style the titles. I tried to read up on this on w3schools.com, but it’s evident that I lack a pillar of information to understand the syntax completely.
        How would change the code to make the numbervalue an element I can style in the CSS?
        • yawnsY Offline
          yawns Moderator
          1: This is a know issue. If the module uses a node_helper, it does not survive a manual refresh of the webpage. It requires a restart of the magic mirror process. If someone knows how to get rid of this, I am more than happy to learn. @Module-Developers
          2:
          	getDom: function() {
          		if (!this.loaded) {
          			wrapper.innerHTML = this.translate('LOADING');
          			wrapper.className = "dimmed light small";
          			return wrapper;
          		if (!this.data) {
          			wrapper.innerHTML = "No data";
          			return wrapper;
          		var t = this.data.graph;
          		var content = document.createElement("div");
          		var titleDiv = document.createElement("div");
          		var dataDiv = document.createElement("div");
          		var titleDataSpan = document.createElement("span");
          		var valueDataSpan = document.createElement("span");
          		for (var i in t.datasequences) {
          			titleDiv.className = "LIST YOUR CLASSES HERE";
          			titleDiv.innerHTML = t.title  + " - " + t.datasequences[i].title;
          			content.appendChild(titleDiv);
          			for (var j in t.datasequences[i].datapoints) {
          				dataDiv.className = "LIST YOUR CLASSES HERE";
          				titleDataSpan.className = "LIST YOUR CLASSES HERE";
          				titleDataSpan.innerHTML = t.datasequences[i].datapoints[j].title + ":";
          				valueDataSpan.className = "LIST YOUR CLASSES HERE";
          				valueDataSpan.innerHTML = t.datasequences[i].datapoints[j].value;
          				dataDiv.appendChild(titleDataSpan);
          				dataDiv.appendChild(valueDataSpan);
          				content.appendChild(dataDiv);
          		wrapper.appendChild(content);
          		return wrapper;
          You could even use the datapoint title (“amount” in this example), define a css class with this selector and add the datapoint title to the list of classnames ;)
          I did not test it, I just wrote it in notepad++, so there might be a typo. You could also try to add more entries to your JSON file to see if the loops are correct and fetch all data.
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @yawns
            @yawns i could imagine that the start flag of the node_helper is still true so the getdata call gets skipped
            yawnsY 1 Reply Last reply Reply Quote 1
            • yawnsY Offline
              yawns Moderator @strawberry 3.141
              @strawberry-3.141
              good point. Maybe I find some time at the weekend to debug this and check where it is stopping/skipping
              • E Offline
                E3V3A @yawns
                @yawns Was that re-load issue ever resolved? I have my own basic issues and I’m considering using this code instead…
                "Everything I do (here) is for free – altruism is the way!"
