    Display values from a JSON file hosted online
    10 Posts 4 Posters 5.9k Views 4 Watching
    • yawnsY Offline
      yawns Moderator
      Quick and dirty, but should get you going :)
      You have to use the node_helper, because using XMLHttpRequest would result in an “origin error”.
      MMM-backlog.js
      /* global Module */
      /* Magic Mirror
       * Module: MMM-backlog
       * By Stefan Krause http://yawns.de
       * MIT Licensed.
      Module.register('MMM-backlog',{
      	defaults: {
      		units: config.units,
      		animationSpeed: 1000,
      		updateInterval: 1000 * 3600, //update every hour
      		refreshInterval: 1000 * 60 * 10, //refresh every minute
      		timeFormat: config.timeFormat,
      		lang: config.language,
      		initialLoadDelay: 0, // 0 seconds delay
      		retryDelay: 2500,
      		fileUrl: "https://www.dropbox.com/s/k1t6mjjc3knxp3a/dataset.json?raw=1"
      	// Define required scripts.
      	getScripts: function() {
      		return ["moment.js"];
      	// Define requird styles
      	getStyles: function() {
      		return ["font-awesome.css"];
      	start: function() {
      		Log.info('Starting module: ' + this.name);
      		this.loaded = false;
      		this.sendSocketNotification('CONFIG', this.config);
      	getDom: function() {
      		if (!this.loaded) {
      			wrapper.innerHTML = this.translate('LOADING');
      			wrapper.className = "dimmed light small";
      			return wrapper;
      		if (!this.data) {
      			wrapper.innerHTML = "No data";
      			return wrapper;
      		var t = this.data.graph;
      		var content = document.createElement("div");
      		content.innerHTML = "";
      		for (var i in t.datasequences) {
      			content.innerHTML += t.title  + " - " + t.datasequences[i].title + "<br />";
      			for (var j in t.datasequences[i].datapoints) {
      				content.innerHTML += t.datasequences[i].datapoints[j].title + ": " + t.datasequences[i].datapoints[j].value + "<br />";
      		wrapper.appendChild(content);
      		return wrapper;
          		if (notification === "STARTED") {
      				this.updateDom();
      			else if (notification === "DATA") {
      				this.loaded = true;
      				this.processData(JSON.parse(payload));
      				this.updateDom();
      	/* processData(data)
      	 * Uses the received data to set the various values.
      	 * argument data object - tide information received form worldtides.info
      	processData: function(data) {
      		if (!data) {
      			// Did not receive usable new data.
      			// Maybe this needs a better check?
      			return;
      		this.data = data;
      		this.loaded = true;
      		this.updateDom(this.config.animationSpeed);
      node_helper.js
      'use strict';
      /* Magic Mirror
       * MIT Licensed.
      const NodeHelper = require('node_helper');
      var request = require('request');
      	start: function() {
      		this.started = false;
      		this.config = null;
      	getData: function() {
      		var self = this;
      		var myUrl = this.config.fileUrl;
      		request({
      			url: myUrl,
      			method: 'GET',
      		}, function (error, response, body) {
      			if (!error && response.statusCode == 200) {
      				self.sendSocketNotification("DATA", body);
      		setTimeout(function() { self.getData(); }, this.config.refreshInterval);
      		var self = this;
      		if (notification === 'CONFIG' && self.started == false) {
      			self.config = payload;
      			self.sendSocketNotification("STARTED", true);
      			self.getData();
      			self.started = true;
      • L Offline
        looolz
        wow! This looks great! I cant wait to try this out!
        Thank you so much! 👍🏻
        • L Offline
          looolz
          @yawns HAVE MY BABIES!
          It works! Thank you so much! I’ll now start to play around with the CSS! Thank you so much! :)
          • yawnsY Offline
            yawns Moderator @looolz
            Glad it gets you going. Of course you can add more divs/spans or even a table to place your output and adjust proper css to single lines or values.
            If you need explanation of single commands or routines just let us know.
            @looolz said in Display values from a JSON file hosted online:
            I doubt my wife would be happy with that :rofl:
            • L Offline
              looolz
              You are very kind!
              I’ve got a couple of issues so far:
              1: The module doesn’t seem to survive a manual refresh. For some reason, if I hit CTRL R to refresh, all other modules load, but this one is stuck at “loading…” If I do CTRL Q, quit the Magic Mirror and try again, it works. Even more strangely, it does correctly update on it’s own, when the JSON file changes. Just a minor thing.
              2: I’ve been trying to create en separate class for the value, so that I can style the number individually. So I tried to create an element that I can style with xlarge from the css file. But so far I’ve only been able to style the titles. I tried to read up on this on w3schools.com, but it’s evident that I lack a pillar of information to understand the syntax completely.
              How would change the code to make the numbervalue an element I can style in the CSS?
              • yawnsY Offline
                yawns Moderator
                1: This is a know issue. If the module uses a node_helper, it does not survive a manual refresh of the webpage. It requires a restart of the magic mirror process. If someone knows how to get rid of this, I am more than happy to learn. @Module-Developers
                2:
                		if (!this.loaded) {
                			return wrapper;
                		if (!this.data) {
                			return wrapper;
                		var titleDiv = document.createElement("div");
                		var dataDiv = document.createElement("div");
                		var titleDataSpan = document.createElement("span");
                		var valueDataSpan = document.createElement("span");
                			titleDiv.className = "LIST YOUR CLASSES HERE";
                			titleDiv.innerHTML = t.title  + " - " + t.datasequences[i].title;
                			content.appendChild(titleDiv);
                				dataDiv.className = "LIST YOUR CLASSES HERE";
                				titleDataSpan.className = "LIST YOUR CLASSES HERE";
                				titleDataSpan.innerHTML = t.datasequences[i].datapoints[j].title + ":";
                				valueDataSpan.className = "LIST YOUR CLASSES HERE";
                				valueDataSpan.innerHTML = t.datasequences[i].datapoints[j].value;
                				dataDiv.appendChild(titleDataSpan);
                				dataDiv.appendChild(valueDataSpan);
                				content.appendChild(dataDiv);
                		return wrapper;
                You could even use the datapoint title (“amount” in this example), define a css class with this selector and add the datapoint title to the list of classnames ;)
                I did not test it, I just wrote it in notepad++, so there might be a typo. You could also try to add more entries to your JSON file to see if the loops are correct and fetch all data.
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @yawns
                  @yawns i could imagine that the start flag of the node_helper is still true so the getdata call gets skipped
                  yawnsY 1 Reply Last reply Reply Quote 1
                  • yawnsY Offline
                    yawns Moderator @strawberry 3.141
                    @strawberry-3.141
                    good point. Maybe I find some time at the weekend to debug this and check where it is stopping/skipping
                    • E Offline
                      E3V3A @yawns
                      @yawns Was that re-load issue ever resolved? I have my own basic issues and I’m considering using this code instead…
                      "Everything I do (here) is for free – altruism is the way!"
