    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 400.5k Views 23 Watching
      joanaz @d3r
      @d3r yeah! awesome! you just need to tell my module to close my module
      • L
        lucallmon @joanaz
        @joanaz Where are your guides? The README.md is the only file I have to go on from your github page.
          d3r @lucallmon
          @lucallmon said in MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images:
          There are two github repos. One is for the alexa skill and the other is for the module. You need to check both.
          • L
            lucallmon @d3r
            @d3r I see that, and that is my problem. There is no guide on how to install it. If you want people to use it, help them install it. Sounds like a great product that I would love to have, but it’s not user friendly.
              janner6
              I’m working my way through the setup of the AWS IoT. I’m up to stage 11 on the walkthrough where it says:
              “11.copy all your credential files, then go to your local copy of this repo, and paste them inside the certs folder (which is inside the src folder)”
              Where do I find the credentials that need to be copied?
                joanaz @janner6
                @janner6 those are the files you downloaded from the last step
                  Journeytojah
                  Just a quick and final update.
                  Considering the recent revelations made by Wikileaks #Vault7, I have decided to stay away from Alexa; at least for now.
                  Already found two possible alternatives, I will not compromise my or anyone else’s privacy.
                  Best of luck,
                  • E
                    elblogbruno @Journeytojah
                    @Journeytojah which are they?
                      Journeytojah @elblogbruno
                      @elblogbruno You can find them here: https://wikileaks.org/ciav7p1/cms/index.html
                      And you can read about what this means pretty much anywhere online.
                      Also see this : https://www.youtube.com/watch?v=tNGFp2tUweI .
                      PS: for a long time I’ve been an advocate of security on IoT devices, shortly after the realease of Shodan serach engine; I cannot stress enough how important it is to keep your devices safe from prying eyes or ears, or keep them from being part of a botnet.
                      I will not hijack this thread and @joanaz’s work any more. Great job for the module, it’s just not what i need :)
                        d3r
                        @Journeytojah I see what you’re saying.
                        The alexa devices sold by amazon are always listening but the code amazon have shared on their website is not. The alexa version available on their github is only activated on button press or can be voice ativated through snowboy or sensory. My understanding is that snowboy works offline and doesn’t require an internet connection. So yes, alexa could be spying on you but all alexa devices might not be. I am 90% sure mine isn’t but I could be wrong.
                        • E
                          @Journeytojah I meant the other Assistants like alexa you talked about?
                          But thanks for the info!
                          • romainR
                            romain
                            Hello. I have follow the guide multiple time now. At first I had trouble to get an answer from the Alexa skill (turned out it was because of the region, choosing us east Virginia wasn’t doing the trick for me. I needed to creat my lambda as eu ireland and to change the region value to eu-west-1 within the MirrorMirror.js in both folder).
                            Now my issue is that nothing is happening even though there is no error what so ever in the log.
                            I read this entire thread so I may have an idea on what the issue is but I rather ask to be sure.
                            Is the module isn’t enough by itself ? do I to install some third party thing in order to use it ? (I saw “AlexaPi” mention here and there). Is it why I can’t use this module ?
                            • A
                              arthurross
                              I got it partly working. It’s just not showing anything on the mirror. I may have sudo npm installed it.
                                pepemujica
                                Hi @joanaz !
                                The module looks great! Thanks for developing it.
                                Could you help me with this?
                                I’m stuck over this step:
                                0_1495801708131_upload-97f2b27a-03b5-4725-adda-277d52f00d15
                                Can’t find the way to install the dependencies.
                                1 Reply Last reply Reply Quote -1
                                  manojjena78 @Gunwoody
                                  @savage_gr1nd - Do you able to make it work?? I have an issue where the Magic mirror and Alexa module does not interact each other, but individually works fine. I can ask Alexa- then I get answer. My magic mirror also works fine. But when I say Alexa show me video of X , nothing happens and no text message is shown on the Mirror. Also when I test Simulator with hello then I get a response back. But when I use log work , it gives error . ("The remote endpoint could not be called, or the response it returned was invalid.). Anyone please guide.
                                  Thanks,
                                  MK
                                  • T
                                    torresfm
                                    Hi! @joanaz, @savage_gr1nd , @Journeytojah
                                    I’ve been trying to get this skill to work, but I’m stuck with a Lambda error that doesn’t really give me much to work on. My AWS IoT dashboard does show successful connections and I’ve followed every step in the readme to a T (I’ve even read this most of this thread to go make sure I didn’t make the common mistakes), but when I try to run a test on the Lambda function I get this error below. Thanks for the help in advance!
                                      "errorMessage": "Invalid connect options supplied.",
                                      "errorType": "Error",
                                      "stackTrace": []
                                    Log output:
                                    START RequestId: 4b366259-601e-11e7-899b-8dd5d86aa5dd Version: $LATEST
                                    module initialization error: Error
                                        at Module.require (module.js:497:17)
                                    END RequestId: 4b366259-601e-11e7-899b-8dd5d86aa5dd
                                    REPORT RequestId: 4b366259-601e-11e7-899b-8dd5d86aa5dd	Duration: 0.37 ms	Billed Duration: 100 ms 	Memory Size: 128 MB	Max Memory Used: 33 MB
                                    I copied and pasted the Lambda request from the Alexa Skill config simulator for the test in Lambda: (I’ve redacted the id keys)
                                    Request:
                                      "session": {
                                        "sessionId": "SessionId.xxxx",
                                        "application": {
                                          "applicationId": "amzn1.ask.skill.xxxx"
                                        "attributes": {},
                                        "user": {
                                          "userId": "amzn1.ask.account.xxxx"
                                        "new": true
                                      "request": {
                                        "type": "IntentRequest",
                                        "requestId": "EdwRequestId.xxxx",
                                        "locale": "en-US",
                                        "timestamp": "2017-07-03T18:55:38Z",
                                        "intent": {
                                          "name": "MirrorMirrorHelloIntent",
                                          "slots": {}
                                      "version": "1.0"
                                    Response:
                                    edit:
                                    I think I found a few areas in aws-iot-device-sdk in device/index.js where the error is coming from, but not sure how to fix it.
                                       if (isUndefined(options) ||
                                          Object.keys(options).length === 0) {
                                          throw new Error(exceptions.INVALID_CONNECT_OPTIONS);
                                    if (isUndefined(options.host)) {
                                    if (!isUndefined(options.host)) {
                                             var pattern =/[a-zA-Z0-9]+\.iot\.([a-z]+-[a-z]+-[0-9]+)\.amazonaws\.com/;
                                             var region = pattern.exec(options.host);
                                             if (region === null) {
                                                console.log('Host endpoint is not valid');
                                             } else {
                                                options.region = region[1];
                                    My folder struct:
                                    +--certs/
                                    |     +----keys_sample.json
                                    |     +----MagicMirror.cert.pem
                                    |     +----MagicMirror.private.key
                                    |     +----MagicMirror.public.key
                                    |     +----root-CA.crt
                                    +----index.js
                                    +----MirrorMirror.js
                                    +----node_modules/
                                    +----package.json
                                    The index.js and mirrormirror.js are stock, I haven’t changed a thing.
                                    • T
                                      torresfm
                                      I found the issue, please look at my other ports for the solution. Thanks.
                                        dugemaniac @joanaz
                                        @joanaz hi Joanaz, sorry to bother you. first of all, thanks for this great module. Need your help, i got the same error. skills works, i can see card in alexa app, but it didnt shown on MM.
                                        I look at terminal and it said
                                        Attempt to connect to AWS
                                        { Error: getaddrinfo ENOTFOUND arn:aws:lambda:us-east-1:xxxxxxxxxxxxxxx:function:AlfaMirror arn:aws:lambda:us-east-1:xxxxxxxxxxxxxxx:function:AlfaMirror:8883
                                            at errnoException (dns.js:28:10)
                                            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:73:26)
                                          code: 'ENOTFOUND',
                                          errno: 'ENOTFOUND',
                                          syscall: 'getaddrinfo',
                                          hostname: 'arn:aws:lambda:us-east-1:xxxxxxxxxxx:function:AlfaMirror',
                                          host: 'arn:aws:lambda:us-east-1:xxxxxxxxxxxxx:function:AlfaMirror',
                                          port: 8883 }
                                        MagicMirror will not quit
                                        Kindly need your help. Cheers :)
                                          dugemaniac @dugemaniac
                                          @joanaz found out the problem, my ISP block port 8883, using other ISP works flawlessly. Thanks alot for such a great module for MM. Cheers have a great day
                                          @torresfm Thank too for the solution over end point not found. Cheers
                                            SpaceKitten @savage_gr1nd
                                            @savage_gr1nd Got The Same Error “Unable To Upload Index File” ,So My Question Is While Installing Dependencies In /src Directory I Performed "sudo npm For sdk and kit So While Testing The Skill Its Showing Me Error In Lambda Response And In Lambda Logs Its Saying “Index File” Error Mentioned In This Post. So Is “Sudo Npm” The Cause? Because u Said It Blocks Amazon Access. And i Did The Zip Procedure Perfectly. Please Guide. ThankYou
                                            • 10
                                            • 9 / 10
