    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 363.1k Views 23 Watching
      joanaz @janner6
      @janner6 those are the files you downloaded from the last step
        Journeytojah
        Just a quick and final update.
        Considering the recent revelations made by Wikileaks #Vault7, I have decided to stay away from Alexa; at least for now.
        Already found two possible alternatives, I will not compromise my or anyone else’s privacy.
        Best of luck,
        • E Offline
          elblogbruno @Journeytojah
          @Journeytojah which are they?
            Journeytojah @elblogbruno
            @elblogbruno You can find them here: https://wikileaks.org/ciav7p1/cms/index.html
            And you can read about what this means pretty much anywhere online.
            Also see this : https://www.youtube.com/watch?v=tNGFp2tUweI .
            PS: for a long time I’ve been an advocate of security on IoT devices, shortly after the realease of Shodan serach engine; I cannot stress enough how important it is to keep your devices safe from prying eyes or ears, or keep them from being part of a botnet.
            I will not hijack this thread and @joanaz’s work any more. Great job for the module, it’s just not what i need :)
              d3r
              @Journeytojah I see what you’re saying.
              The alexa devices sold by amazon are always listening but the code amazon have shared on their website is not. The alexa version available on their github is only activated on button press or can be voice ativated through snowboy or sensory. My understanding is that snowboy works offline and doesn’t require an internet connection. So yes, alexa could be spying on you but all alexa devices might not be. I am 90% sure mine isn’t but I could be wrong.
              • E Offline
                @Journeytojah I meant the other Assistants like alexa you talked about?
                But thanks for the info!
                • romainR Offline
                  romain
                  Hello. I have follow the guide multiple time now. At first I had trouble to get an answer from the Alexa skill (turned out it was because of the region, choosing us east Virginia wasn’t doing the trick for me. I needed to creat my lambda as eu ireland and to change the region value to eu-west-1 within the MirrorMirror.js in both folder).
                  Now my issue is that nothing is happening even though there is no error what so ever in the log.
                  I read this entire thread so I may have an idea on what the issue is but I rather ask to be sure.
                  Is the module isn’t enough by itself ? do I to install some third party thing in order to use it ? (I saw “AlexaPi” mention here and there). Is it why I can’t use this module ?
                    arthurross
                    I got it partly working. It’s just not showing anything on the mirror. I may have sudo npm installed it.
                      pepemujica
                      Hi @joanaz !
                      The module looks great! Thanks for developing it.
                      Could you help me with this?
                      I’m stuck over this step:
                      0_1495801708131_upload-97f2b27a-03b5-4725-adda-277d52f00d15
                      Can’t find the way to install the dependencies.
                      1 Reply Last reply Reply Quote -1
                        manojjena78 @Gunwoody
                        @savage_gr1nd - Do you able to make it work?? I have an issue where the Magic mirror and Alexa module does not interact each other, but individually works fine. I can ask Alexa- then I get answer. My magic mirror also works fine. But when I say Alexa show me video of X , nothing happens and no text message is shown on the Mirror. Also when I test Simulator with hello then I get a response back. But when I use log work , it gives error . ("The remote endpoint could not be called, or the response it returned was invalid.). Anyone please guide.
                        Thanks,
                        MK
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 17 / 19
