    [Closed] Problem since update
    7 Posts 2 Posters 3.7k Views 2 Watching
      Petal0u
      Hello all,
      my first message for a trouble on the forum.
      Since i updated magicmirror to the new version 2.1 i’ve nothing on screen and from local browser (ssh connected)
      looking npm logs, i’ve this :
       node v7.6.0
      30 error npm  v3.10.10
      31 error code ELIFECYCLE
      32 error magicmirror@2.1.0 start: `electron js/electron.js`
      32 error Exit status 1
      33 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      33 error Make sure you have the latest version of node.js and npm installed.
      33 error If you do, this is most likely a problem with the magicmirror package,
      33 error not with npm itself.
      33 error Tell the author that this fails on your system:
      33 error     electron js/electron.js
      33 error You can get information on how to open an issue for this project with:
      33 error     npm bugs magicmirror
      33 error Or if that isn't available, you can get their info via:
      33 error     npm owner ls magicmirror
      33 error There is likely additional logging output above.
      34 verbose exit [ 1, true ]
      i added ipwhitelist like this :
      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.1", "192.168.0.100"]],
      could i have some help to find an issue to my problem ?
        roramirez Core Contributors
        Try:
        DISPLAY=:0 nohup npm start
          Petal0u
          i’m added every modules one by one, testing after each one.
          I found twho differents modules (meteo) which were set at the same place. It seems to be the problem.
            Petal0u @roramirez
            @roramirez what effects do i expect from your command ?
              roramirez Core Contributors @Petal0u
              @Petal0u If you are connected by SSH this should work for you.
              Can you tell us what is your output with the command mentioned before?
                Petal0u
                no problem anymore because my sd card crashed.
                I’m reinstalling on a new card.
                I close the topic.
                Thanks for your help
                  Petal0u @Petal0u
                  @Petal0u there were a problem with config.js syntax :-)
                  allways check config.js !!! :-D
                  i close the discussion
