    [Closed] Problem since update
    7 Posts 2 Posters 3.1k Views 2 Watching
    • Petal0uP Offline
      Petal0u
      Hello all,
      my first message for a trouble on the forum.
      Since i updated magicmirror to the new version 2.1 i’ve nothing on screen and from local browser (ssh connected)
      looking npm logs, i’ve this :
       node v7.6.0
      30 error npm  v3.10.10
      31 error code ELIFECYCLE
      32 error magicmirror@2.1.0 start: `electron js/electron.js`
      32 error Exit status 1
      33 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      33 error Make sure you have the latest version of node.js and npm installed.
      33 error If you do, this is most likely a problem with the magicmirror package,
      33 error not with npm itself.
      33 error Tell the author that this fails on your system:
      33 error     electron js/electron.js
      33 error You can get information on how to open an issue for this project with:
      33 error     npm bugs magicmirror
      33 error Or if that isn't available, you can get their info via:
      33 error     npm owner ls magicmirror
      33 error There is likely additional logging output above.
      34 verbose exit [ 1, true ]
      i added ipwhitelist like this :
      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.1", "192.168.0.100"]],
      could i have some help to find an issue to my problem ?
        roramirez Core Contributors
        Try:
        DISPLAY=:0 nohup npm start
        Petal0uP 1 Reply Last reply Reply Quote 0
        • Petal0uP Offline
          Petal0u
          i’m added every modules one by one, testing after each one.
          I found twho differents modules (meteo) which were set at the same place. It seems to be the problem.
          • Petal0uP Offline
            Petal0u @roramirez
            @roramirez what effects do i expect from your command ?
              roramirez Core Contributors @Petal0u
              @Petal0u If you are connected by SSH this should work for you.
              Can you tell us what is your output with the command mentioned before?
              • Petal0uP Offline
                Petal0u
                no problem anymore because my sd card crashed.
                I’m reinstalling on a new card.
                I close the topic.
                Thanks for your help
                • Petal0uP Offline
                  Petal0u @Petal0u
                  @Petal0u there were a problem with config.js syntax :-)
                  allways check config.js !!! :-D
                  i close the discussion
