    MMM-PrayerTime
    Scheduled Pinned Locked Moved Education
    55 Posts 14 Posters 46.8k Views 14 Watching
    • slametpsS Offline
      slametps
      Description:
      A MM-module to display moslem praying time from https://aladhan.com.
      Download:
      [card:slametps/MMM-PrayerTime]
      Screenshot
      Initial Version
      regards,
      Slamet PS
      A Z 2 Replies Last reply Reply Quote 1
        AAPS @slametps
        @slametps While looking at this on GitHub, it seems like it plays Adhan as well. Is this correct? If so, could I make it not play Adhan, or does it come standard with the module?
        I’ve been looking for a module like this since I started. Thank you. :grinning:
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @AAPS
          @AAPS you can set config playAdzan as following to tell module NOT to play adzan:
          playAdzan: [],
          regards,
          Slamet PS
            AAPS @slametps
            @slametps Thanks! This’ll work much better than the calendar method.
            • Z Offline
              zzaidi148 @slametps
              @slametps Thank you for making this module. I just wanted to ask you why my config wouldn’t validate. I am in central north america. This is my config:
              			module: 'MMM-PrayerTime',
              			position: 'bottom_right',
              			apiVersion: '1.0'
              			lat: 38.033184,
              			lon: -86.625225,
              			timezone: true,
              			method: 5,
              			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
              			notDisplayed: ['midnight', 'sunset'],
              			useUpdateInterval: true,
              			updateInterval: 86400 * 1000,
              			animationSpeed: 2.5 * 1000,
              			language: config.language,
              			showAdzanAlert: true,
              			alertTimer: 15000
              • yawnsY Offline
                yawns Moderator @zzaidi148
                @zzaidi148
                There is a comma missing after apiVersion: '1.0'
                Z 1 Reply Last reply Reply Quote 0
                • Z Offline
                  zzaidi148 @yawns
                  @yawns tried that but didn’t work. I think it has to be something with the timezone.
                  • slametpsS Offline
                    slametps @zzaidi148
                    @zzaidi148 said in MMM-PrayerTime:
                    There is a missing comma after apiVersion: '1.0'. What does not work? What you get on your mirror? Or in pm/mm log?
                    regards,
                    Slamet PS
                    • N Offline
                      noorm91
                      I am having trouble with my module…
                                                      apiVersion: '1.0',
                                                      lat: 55.841727,
                                                      lon: 13.303381,
                                                      timezone: Europe/Stockholm,
                                                      method: 3,
                                                      alertTimer: 15000
                      can you see anything wrong?
                      • slametpsS Offline
                        slametps @noorm91
                        @noorm91 said in MMM-PrayerTime:
                                                       apiVersion: '1.0',
                                                       lat: 55.841727,
                                                       lon: 13.303381,
                                                       method: 3,
                                                       alertTimer: 15000
                        It should be timezone: 'Europe/Stockholm'.
                        regards,
                        Slamet PS
                        • 1 / 6
