    New modules, don´t load
    5 Posts 3 Posters 3.4k Views 3 Watching
    • piedanielP Offline
      piedaniel
      Hello everyone,
      When I insert new modules into the config.js, the MagicMirror don´t load nothing, just black screen. When I took out this new code, everything work fine.
      Ex: Copy the MMM-meteoblueCurrent repository into modules folder. Then on config.js insert the new code like this:
      ~~modules: [
      module: ‘alert’,
      module: ‘clock’,
      position: ‘top_left’
      module: ‘calendar’,
      header: ‘US Holidays’,
      position: ‘top_left’,
      symbol: 'calendar-check-o ',
      url: ‘webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics’
      module: ‘compliments’,
      position: ‘lower_third’
      module: ‘currentweather’,
      position: ‘top_right’,
      locationID: ‘’, //ID from bulk.openweather.org/sample/
      appid: ‘YOUR_OPENWEATHER_API_KEY’
      module: ‘weatherforecast’,
      header: ‘Weather Forecast’,
      locationID: ‘5128581’, //ID from bulk.openweather.org/sample/
      		module: 'newsfeed',
      		position: 'bottom_bar',
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      		module: 'MMM-meteoblueCurrent',
      		position: 'bottom_left',
      			apikey: '123456789', // private; don't share!
      			city: 'Oberrieden',
      			lat: '47.2744',
      			lon: '8.5784',
      			asl: '464'
      Result black screen without nothing. Take out the metroblue module code, everything work fine.
      			city: 'Oberrieden',
      			lat: '47.2744',
      			lon: '8.5784',
      			asl: '464'
      What I are missing??
      • BangeeB Offline
        Bangee Module Developer
        Can you show maybe show some error’s from the logs: pm2 logs mm
        Or do you use firebug when your testing you MM in your webbrowser?
        • mochmanM Offline
          mochman Module Developer
          @piedaniel Just quickly looking at your config.js, it looks like MMM-meteoblueCurrent module is the last one. Try taking out that last comma after you close out the module with the bracket.
            piedaniel
            Here you have my log. I don´t know why is not loading the Meteoblue with a error server. I´m with MacOs.
            logger.js:20 Load script: modules/default/newsfeed//newsfeed.js
            logger.js:20 Module registered: newsfeed
            logger.js:17 Bootstrapping module: newsfeed
            logger.js:20 File already loaded: moment.js
            logger.js:20 Scripts loaded for: newsfeed
            logger.js:20 Styles loaded for: newsfeed
            logger.js:20 Translations loaded for: newsfeed
            logger.js:20 Load script: modules/MMM-meteoblueCurrent//MMM-meteoblueCurrent.js
            http://localhost:8080/modules/MMM-meteoblueCurrent//MMM-meteoblueCurrent.js Failed to load resource: the server responded with a status of 404 (Not Found)
            • BangeeB Offline
              Are you sure, that the files are there?
              If the are, let’s try to restart pm2 restart mm or sudo reboot.
