    Where to run a Script?
    11 Posts 2 Posters 6.0k Views 2 Watching
    • johnnyboyJ
      johnnyboy
        mochman Module Developer
        Are you physically connected or VNC’ed to the raspberryPi? If so, open up a terminal window and then type
        sudo python /path/to/your/alexapi/folder/auth_web.py
        then open up your browser (the one in the pi) and go to http://localhost:3000
        log in with your Amazon login/pass. The script should update your settings.py file for you.
        If you are using an ssh program to access the pi. Run the first command as normal, then open up a browser and go to http://your.pi.ip.addr:3000
        The rest should be the same.
        johnnyboyJ 2 Replies Last reply
        Reply Quote 2
        • johnnyboyJ
          johnnyboy @mochman
          johnnyboyJ 1 Reply Last reply
          • johnnyboyJ
            johnnyboy @johnnyboy
              Okay I thought you were using alexaPi, looks like alexa-client. In that case, have you run
              cd /home/pi/MagicMirror/alexa-client/
              pip install -r requirements.txt
              python setup.py install
              sudo pip install -r auth_web_requirements.txt
              already? If so, try
              python auth_web.py
              In this application you will need to add the token you get from the website to your settings.py file. After you get the token, run nano settings.py and paste the token where it says
              REFRESH_TOKEN= ``
              so it will say something like
              REFRESH_TOKEN= `yourTokenGoesHere`
              • johnnyboyJ
                johnnyboy @mochman
                • johnnyboyJ
                  johnnyboy @mochman
                  • johnnyboyJ
                    • johnnyboyJ
                      • johnnyboyJ
                        johnnyboy
                        • johnnyboyJ
                          johnnyboy @mochman
