    After reboot RPI no changes are saved?
    15 Posts 5 Posters 6.5k Views 5 Watching
    • W Offline
      wizz
      Hi all.
      I got a strange issue.
      When i reboot (Sudo reboot) the RPI after changes in the config.js and saved the config file it gets back to the same status that i hade befor changes was made.
      Like if i delete a module from the config and save tha file it works fine but if i do a sudo reboot after this it is back to latest version and the module are back ?
      Aslo i got som issues with the MM freezes and nothing can be done just power off the RPI and restart it all.
      I dont run the latest MM 2.1.1 as i got problems updating.
      Is the best way to re install the full MM or is it a solution to this?
      Well hope that i can get some help if some one have hade the same kind of issue and solved it.
      daenickD P 2 Replies Last reply Reply Quote 0
      • daenickD Offline
        daenick @wizz
        @wizz I have the same problema. When sudo reboot my config.txt is lost. I have to edit it everytime I shutdown too.
          Blackmirror
          @wizz
          Have you found a solution?
          I have the same problem now.
            sdetweil @Blackmirror
            @Blackmirror i would try sudo shutdown now -r (r=reboot)
            I have worried about sudo reboot not saving files, but it has never happened to me… (on 8 different systems with MM running)
              Plainbroke 0
              I am having this problem of any config changes do not stay after reboot.
              I am editing config.js and custom.css like I have for the last year or so.
              Any work around?
              S P 2 Replies Last reply Reply Quote 0
                Plainbroke 0
                Having the same issue, if I “sudo reboot” or “sudo shutdown now -r” I loose the changes in my config.js and my custom.css they will not save for some reason. Problem JUST started Monday.
                Anyone have a solution?
                  sdetweil @Plainbroke 0
                  @Plainbroke-0 are u using docker or MagicMirrorOS
                    Plainbroke 0 @sdetweil
                    Magic Mirror on Pi4 2gb version 2.12
                      @Plainbroke-0 are u accidentally running two instances
                      pm2 status
                        nope just one:
                        id │ name │ mode │ ↺ │ status │ cpu │ memory │
                        │ 0 │ mm │ fork │ 1 │ online │ 0% │ 2.4mb
                          @Plainbroke-0 ok, i have two instances installed for testing, and today was confused by a similar problem… changes I made didn’t take affect…
                          I was editing the file in the wrong instance… took me about 15 minutes before I figured it out… so many files open in the editor it only showed the last part of the filename (config.js) not the path
                            Plainbroke 0 @wizz
                            @wizz
                            Did you ever find a fix for this problem… ?
                              Plainbroke 0 @daenick
                              @daenick
                              Did you ever find a fix? I am now having exact same issue.
                                Plainbroke 0 @Plainbroke 0
                                @Plainbroke-0 said in After reboot RPI no changes are saved?:
                                Any work around?
                                Turned out to be a bad Mem Card must have exceeded the amount of rewrites it was capable of.
                                Luckily I could just Make an image of the disk and transfer it to a brand new card now I am able to edit again.
                                  @daenick @wizz
                                  Mine was a bad mem card. I created an image of it with win32Diskimager, Now I can just write the complete setup to a new card anytime I need to. In my case it requires a lot of redoing the image since I cant leave well enough alone. Constant changing things on my MagicMirror.
